Author Topic: part number  (Read 371 times)
Offline thedoc298
part number
« on: March 24, 2020, 05:54:36 PM »
I was on loneoceans web site and was reading again, the clip below. The article referenced two Fair Rite cores. The first core Fair-rite 5977006401 type 77, no problem finding that one. The next one referenced he says is the 5000-1 Fair-Rite. That is the one I can not find, any insight on the part number...? Thanks for any help
IGBT with a 1N5819 and 5.1R gate resistor per IGBT. It is important to select a suitable ferrite core, and this was tested by wrapping several turns of test wire on it, and checking its output with a square input from a signal generator at around 60 to 70 kHz. The output should be as square looking as possible (as can be seen on the right photo with the input being a square wave). The current transformers were also made, giving a 1023:1 step down ratio. Cores used were the Fair-Rite 5977006401 Type 77 and 5000-1 Fair-Rite cores. Note that I stacked them to reduce the number of cores.
Re: part number
« Reply #1 on: March 24, 2020, 09:55:10 PM »
It does not have to be the exact type or manufacturer, you can use a wide selection of ferrite cores.
This is the one you can find data on: https://www.fair-rite.com/product/toroids-5977006401-2/
Notice the electrical properties:
Code: [Select]
AL(nH) 2700 ±25%
and the mechanical:
Code: [Select]
Dim mm mm tol nominal inch inch misc.
Outer 25.4 ±0.60 1 _
Inner 15.5 ±0.50 0.61 _
Thick 12.7 ±0.50 0.5 _
Find any core of similar size and made from a material with a AL value around 2000-5000 and it will work fine.
Offline thedoc298
Re: part number
« Reply #2 on: March 25, 2020, 04:53:15 AM »
Thanks for another answered question.  I get it now and thanks.
Re: part number
Today at 02:12:16 AM
Today at 01:04:06 AM
post Re: Moving to a new lab!
Today at 12:55:12 AM
August 13, 2020, 10:59:27 PM
August 13, 2020, 09:55:27 PM
August 13, 2020, 09:45:58 PM
August 13, 2020, 08:26:56 PM
August 13, 2020, 07:02:24 PM
August 13, 2020, 06:23:24 PM
August 13, 2020, 06:15:16 PM
August 13, 2020, 05:26:47 PM
August 13, 2020, 05:25:43 PM
August 13, 2020, 05:23:40 PM
August 13, 2020, 05:23:37 PM
August 13, 2020, 01:44:24 PM
August 13, 2020, 01:09:16 PM
Yak
August 13, 2020, 12:41:06 PM
August 13, 2020, 11:01:46 AM
August 13, 2020, 02:09:13 AM
August 12, 2020, 11:08:35 PM
August 12, 2020, 10:49:52 PM
August 12, 2020, 10:30:54 PM
August 12, 2020, 09:00:50 PM
August 12, 2020, 07:16:43 PM
August 12, 2020, 02:54:33 PM
August 12, 2020, 12:42:50 PM
August 12, 2020, 12:23:58 PM
August 12, 2020, 11:15:07 AM
August 12, 2020, 04:41:24 AM
August 12, 2020, 04:06:09 AM
August 12, 2020, 01:58:47 AM
August 12, 2020, 12:56:02 AM
August 11, 2020, 11:24:18 PM
August 11, 2020, 06:34:05 PM
Lightning On Demand
August 11, 2020, 04:19:01 AM
Lightning On Demand
August 11, 2020, 04:17:27 AM
Lightning On Demand
August 11, 2020, 04:10:34 AM
August 11, 2020, 03:33:02 AM
August 10, 2020, 12:23:05 PM
August 10, 2020, 12:18:04 PM
August 10, 2020, 10:24:54 AM
August 10, 2020, 06:20:04 AM
RoadReaper
August 10, 2020, 05:40:19 AM
August 10, 2020, 02:07:26 AM
August 10, 2020, 01:27:22 AM
TheFreq
August 09, 2020, 09:02:32 PM
August 08, 2020, 10:22:04 PM
August 08, 2020, 03:36:40 PM
August 08, 2020, 02:07:52 AM
LesWright
August 06, 2020, 10:20:12 PM
