Author Topic: F***-ups varnishing secondary  (Read 774 times)
Offline Zipdox
    • Zipdox
« on: March 17, 2020, 07:25:45 PM »
So I bought some PU varnish and did the first coat early this afternoon using a rotating LEGO contraption.
Since you're reading this post I just messed up doing the second coat. I should probably have waited longer for the first coat to dry. I also found out that the varnish is meant to be sprayed on...
RIP surface finish.
Tomorrow I'll see how it looks and hopefully a third coat will cover the roughness a bit.
Re: F***-ups varnishing secondary
« Reply #1 on: March 17, 2020, 07:35:31 PM »
You don't have to spray varnish. You can use a brush. I have always used a brush with excellent results. The trick is that you have to continuously rotate the secondary until each coat is dry. You can use a hair dryer to speed things up.
« Reply #2 on: March 17, 2020, 08:48:24 PM »
The best results come with more thin layers when using polyurethane varnish. Even letting it harden up enough to give it a light sanding between layers will give a more even result as well.
I have very bad experience with spray on varnish, I only use brush on as well.
Sand it down before your 3rd coating if you want to even the surface, just be careful not to damage the original coating of the wire!
  • All the gear, no idea. UK
« Reply #3 on: March 17, 2020, 09:57:50 PM »
Does that mean its doomed to arc over when powered up now?
Offline Zipdox
    • Zipdox
« Reply #4 on: March 18, 2020, 12:35:25 AM »
Probably not, I can add more varnish.
Offline Zipdox
    • Zipdox
« Reply #5 on: March 18, 2020, 12:36:33 AM »
I will see if sanding is required. And I'll use a hot air station to pop bubbles and hair dryer to make it cure faster.
post Re: COHERENT transformerless 81mHz amplifier schematic ?
dreamth
Today at 01:48:05 PM
Today at 01:18:44 PM
Today at 11:15:01 AM
post COHERENT transformerless 81mHz amplifier schematic ?
dreamth
Today at 10:42:41 AM
post Interrupter frequency?
Today at 10:08:39 AM
dreamth
Today at 09:34:59 AM
post Re: TIG welder teardown. ESAB TIG Caddy 1500i.
Bouaziz
Today at 09:34:05 AM
ChrisBlis
Today at 09:30:38 AM
dreamth
Today at 09:08:55 AM
Today at 07:16:23 AM
Today at 05:08:32 AM
Today at 04:47:32 AM
dreamth
March 03, 2021, 11:20:38 PM
AeraCura_
March 03, 2021, 11:15:32 PM
March 03, 2021, 10:30:40 PM
dreamth
March 03, 2021, 10:03:26 PM
post Re: Need Help w/Build - Lightning Pulse Generator
March 03, 2021, 09:45:28 PM
March 03, 2021, 09:44:17 PM
post First power on tests
March 03, 2021, 06:26:23 PM
March 03, 2021, 05:54:58 PM
dreamth
March 03, 2021, 03:13:30 PM
dreamth
March 03, 2021, 01:18:22 PM
dreamth
March 03, 2021, 12:25:52 PM
dreamth
March 03, 2021, 12:24:40 PM
ChrisBlis
March 03, 2021, 10:43:20 AM
March 03, 2021, 09:05:02 AM
March 03, 2021, 05:53:33 AM
March 03, 2021, 04:22:01 AM
March 03, 2021, 04:00:14 AM
March 03, 2021, 01:21:15 AM
post Re: Just a noob with some HV concerns...
March 03, 2021, 12:36:05 AM
dreamth
March 03, 2021, 12:35:57 AM
March 02, 2021, 11:40:16 PM
dreamth
March 02, 2021, 11:29:28 PM
March 02, 2021, 10:48:04 PM
March 02, 2021, 10:33:13 PM
dreamth
March 02, 2021, 10:20:22 PM
March 02, 2021, 10:18:05 PM
March 02, 2021, 09:38:45 PM
March 02, 2021, 08:54:33 PM
post Re: WTS [EU] Vici DM4070 LCR meter with SMD tweezers
March 02, 2021, 08:53:31 PM
March 02, 2021, 05:04:44 PM
March 02, 2021, 03:16:25 PM
March 02, 2021, 09:41:31 AM
ChrisBlis
March 02, 2021, 08:26:30 AM
hightemp1
March 02, 2021, 07:05:01 AM
March 02, 2021, 06:22:52 AM
post Re: Interesting RF air-core transformer construction
March 02, 2021, 05:24:46 AM
hightemp1
March 02, 2021, 05:21:16 AM
March 02, 2021, 04:37:50 AM
