Author Topic: GDT keeps on killing IGBTs  (Read 6549 times)
Offline ritaismyconscience
« Reply #100 on: April 03, 2020, 04:27:08 AM »
Looks like I found the answer
https://www.microsemi.com/document-portal/doc_download/14696-igbt-tutorial
Pages 2-3 say that high collector current could cause the IGBT to latch on.
I'm wondering if I should go back to using 100nf for primary capacitor since the primary current rises really fast
« Last Edit: April 04, 2020, 05:42:31 AM by ritaismyconscience »
« Reply #101 on: April 04, 2020, 05:37:11 AM »
Got it to work at full voltage without blowing up. Set overcurrent to 500A.
I'm only getting 1 foot arcs, which means that my coil is probably a bit out of tune.
Online davekni
« Reply #102 on: April 04, 2020, 08:01:11 PM »
Yes, for 500A and ~150kHz, 100nF MMC is probably better.  Hopefully that will increase your arc length.
« Reply #103 on: April 06, 2020, 05:09:29 AM »
Looks like you're right.
Tested at half voltage, already working really well. Will have to go somewhere bigger to test.
Edit: This one's probably better. Moved the breakout point up a bit so it doesn't get cut off by the door.
Thanks for your help davekni!
« Last Edit: April 06, 2020, 05:44:20 AM by ritaismyconscience »
Online davekni
« Reply #104 on: April 06, 2020, 06:23:27 PM »
Great to see success!  When you can test in a larger space, you'll find that higher pulse repetition rate extends the streamer length well beyond that of single pulses.  Hopefully everything is robust enough to handle higher rates for an impressive show.
You are certainly welcome.  I'm glad to have been of help.
« Reply #105 on: April 07, 2020, 10:24:16 PM »
Just out of curiosity, is there a reason why 100nF works better than 200nF?
Online davekni
« Reply #106 on: April 07, 2020, 10:54:57 PM »
Yes.  For your fixed frequency and fixed 500A current limit, 100nF has twice the impedance, so twice the primary voltage and twice the primary energy.  It also takes longer to ramp up to the 500A limit.  The short ramp at 200nF may not be long enough for the primary energy to transfer to the secondary, besides having less primary energy available to transfer.
Are you still hitting your 500A limit on most pulses?  If so, even lower than 100nF might be better.  Of course, going lower requires your primary to handle higher voltage.  An arc across the primary coil will destroy IGBTs when the MMC suddenly discharges into the H-bridge.  Also be careful of running longer pulses, as the IGBTs may not handle just under 500A for the longer times.
« Reply #107 on: April 08, 2020, 01:05:28 AM »
I'm already tripping the 500A limit at around half voltage. I'll try reducing the tank capacitor to 50nF.
Online davekni
« Reply #108 on: April 08, 2020, 04:15:12 AM »
50nF sounds good, but do be careful to have sufficient voltage capability.  At 150kHz, 50nF has 21.2 ohms impedance, so will have 10.6kV at 500A.  Plan for at least 12kV to have margin for any delay in over-current shutdown.
« Reply #109 on: April 10, 2020, 05:19:24 AM »
I changed it to 50nF and it seems to work better. Haven't tested it at half voltage yet.
Some pictures:
I guess one of the things I could change is moving the FB and CT coils onto the lower voltage side of the MMC. However that means my leads have to be longer.
« Last Edit: April 10, 2020, 07:36:46 AM by ritaismyconscience »
Online davekni
« Reply #110 on: April 10, 2020, 09:15:17 PM »
Yes, the current transformers should definitely be on one of the H-Bridge outputs, not on the MMC-to-primary connection!  Don't want to rely on CT insulation holding up to 10-12kV!  CT lead length isn't as critical as for gate-drive, but I'd  still suggest seeing if you can rearrange your layout to keep leads short.
« Reply #111 on: April 18, 2020, 05:51:48 AM »
It seems like there's a few problems with my phase lead circuit. First of all, at low currents(~40A), the duty cycle is a few percent less than 50 because one of the diodes (the one connected to 0V) clamps more often than the other. Also, my circuit seems to also be current dependent (higher current results in smaller phase lead). I'll probably have to adjust it while testing at higher current.
I can't use the other circuit for phase lead because the rising and falling edges are not really steep, and the extra time it takes to reach the HIGH threshold basically offsets the phase lead.
edit: tried measuring, ended up having a spark form between primary and oscilloscope probe. Nothing broke (pretty sure there's a MOV inside the oscilloscope that saved it)
« Last Edit: April 18, 2020, 06:18:30 AM by ritaismyconscience »
« Reply #112 on: April 22, 2020, 09:19:36 AM »
The current transformers (FB/OCD) should be on the primary lead from inverter to primary coil. As Dave mentions, between primary coil and MMC there is a very high voltage present due to resonant LC voltage ring up. But even on the inverter to MMC connection you have some higher voltages than on the other leg.
40A or low test voltages are not sufficient for testing a Tesla coil. You need to have the system in a state of consistent energy transfer where different components minimum values for "linear" behavior is met. Like low voltages across a IGBT gives you a much higher output impedance or feedback signal is too weak for the driver to properly lock on in the heavy EMI.
Some 100-200 VDC bus and at least 100-200A in the primary circuit to even begin to think about looking at phase lead, you just risk adjusting the phase lead for the low voltage test conditions that are far from what you see at full power. Often you have your primary circuit detuned lower for longest sparks, as the secondary circuit goes down in frequency as the sparks grow longer (presenting a capacitive load).
You need to use a differential probe when measuring on inverter outputs to avoid damaging your oscilloscope. You risk high voltage transients or grounding the power circuit through your probe.
Online davekni
« Reply #113 on: April 23, 2020, 12:38:24 AM »
Mads,
When you said "But even on the inverter to MMC connection you have some higher voltages than on the other leg.", are you referring to the other H-Bridge leg?  Hopefully the two H-Bridge outputs have the same voltage (180 degrees out-of-phase) or some electronics has fried.  The only difference that comes to mind is parasitic wiring inductance and the MMC's parasitic capacitance to ground, which wouldn't matter if the CT is close to the H-Bridge.
Separately, ritaismyconscience, have you measured your scope probe input impedance?  I had a probe fry in a way that it still functioned, except that it had about 600 ohms from tip to ground.  Took a while and some confusion on my part to figure out the probe issue.  Was initially using it probing a low-impedance signal source, so didn't notice any problem.  Moved it to a higher-impedance node, and results got confusing for a while.
« Reply #114 on: April 23, 2020, 06:08:02 AM »
Checked and no change in impedance. Think I got lucky becuase I accidentally left it on 50 ohms when it hit. Anyways my scope should have input protection (it's fairly old though).
I measured the voltage by insulating a section with tape and putting a wire next to it (basically I made a capacitive dropper). It ended up arcing over an inch around the tape and onto the probe, but nothing bad happened. Also, I'm having a bit of trouble determining the phase lead with the current setup because the current ramps up in a few cycles and just stays there, and during the part where the current is constant, I can't really tell when the IGBTs are switching and when they aren't. It just looks like a normal sine wave.
Online davekni
« Reply #115 on: April 23, 2020, 10:28:17 PM »
That inch arc explains why current-sense transformers should be on one of the H-Bridge outputs and not on the MMC-primary junction. :)
For phasing, if one channel is measuring current, you need another measuring H-Bridge output voltage.  Using a single probe works when measuring the MMC-primary junction (capacitively since you don't have a HV probe).  Perhaps you should put a small glass jar (or test tube or ...) over the end of the probe for better insulation.  That capacitive-coupling probe method is for high-impedance scope input.  With 50 ohm scope input, you'd get the derivative of the voltage (high-pass-filter).
« Reply #116 on: April 25, 2020, 07:26:37 AM »
Think I got phase lead set correctly
Here's my setup. I probed the H-bridge to Primary wire.
Online davekni
« Reply #117 on: April 25, 2020, 07:51:57 PM »
Is that a current or voltage waveform?  If current, the only slight glitch that might indicate switching time is at peak current rather than zero.  If a voltage waveform, the H-Bridge output should be a square-wave, not a sine wave.  The sine-wave voltage I'd suggested probing for phasing is at the MMC-to-primary node, probed through good insulation (ie. small glass jar).
« Reply #118 on: April 25, 2020, 08:30:43 PM »
I'm measuring voltage, not current. I think I probed the two H bridge outputs with the method you described, and one of them looks like the sum of a square and sine wave, and the other just looks like a sine wave.
Online davekni
« Reply #119 on: April 26, 2020, 02:04:23 AM »
Both H-Bridge outputs should be square waves, except for the vary tail end of ring-down after a burst ends.  The sine + square is the junction between MMC and primary coil.  That's where the voltage is high and you can get the 1" arc, so why good insulation is necessary.
Today at 03:55:56 PM
Today at 10:25:50 AM
post Re: SSTC Micro
Today at 04:59:02 AM
Today at 04:32:26 AM
post Re: SSTC Micro
Rowdy
Today at 04:12:23 AM
Rowdy
Today at 03:41:17 AM
Rowdy
Today at 03:40:25 AM
post Re: SSTC Micro
jockoFergy
Today at 02:42:23 AM
May 27, 2020, 06:21:39 PM
fnordest
May 27, 2020, 12:11:06 PM
May 27, 2020, 11:51:19 AM
May 26, 2020, 07:55:03 PM
May 26, 2020, 07:40:48 PM
iraquois
May 26, 2020, 05:12:42 PM
May 26, 2020, 03:57:04 PM
May 26, 2020, 01:52:26 PM
May 26, 2020, 11:52:33 AM
May 26, 2020, 09:40:52 AM
May 26, 2020, 08:56:01 AM
May 26, 2020, 08:45:40 AM
May 26, 2020, 08:27:58 AM
May 26, 2020, 06:31:59 AM
May 26, 2020, 05:24:41 AM
May 26, 2020, 02:01:33 AM
iraquois
May 26, 2020, 01:12:46 AM
May 26, 2020, 12:37:32 AM
May 25, 2020, 10:35:49 PM
May 25, 2020, 09:30:41 PM
May 25, 2020, 08:17:18 PM
iraquois
May 25, 2020, 07:43:30 PM
May 25, 2020, 03:32:54 PM
May 25, 2020, 12:52:38 PM
May 25, 2020, 10:34:56 AM
kilohercas
May 25, 2020, 06:38:15 AM
May 25, 2020, 03:24:49 AM
post Re: SSTC Micro
May 25, 2020, 03:24:20 AM
Rowdy
May 25, 2020, 03:23:33 AM
May 25, 2020, 03:06:20 AM
May 25, 2020, 01:33:47 AM
post MMC for a 32kvac load
Rowdy
May 25, 2020, 01:02:34 AM
Rowdy
May 24, 2020, 11:47:26 PM
post Re: GDT cable specs
May 24, 2020, 11:09:44 PM
Rowdy
May 24, 2020, 10:39:45 PM
station240
May 24, 2020, 09:55:49 PM
May 24, 2020, 09:55:48 PM
May 24, 2020, 08:16:40 PM
thecyberman
May 24, 2020, 05:38:27 PM
Rowdy
May 24, 2020, 02:33:55 PM
hip424
May 24, 2020, 02:31:39 PM
iraquois
May 24, 2020, 02:08:53 PM
