Author Topic: GDT keeps on killing IGBTs  (Read 9050 times)
Offline ritaismyconscience
Re: GDT keeps on killing IGBTs
« Reply #120 on: April 26, 2020, 05:48:25 AM »
Looks like I didn't set it correctly.
Here's a simulation. I added a bit of inductance and resistance between the square wave output and the inductor to simulate the parasitic inductance of the wire:
Seems to have some phase lead.
« Reply #121 on: April 26, 2020, 06:43:27 AM »
Probing there makes it difficult to know phase accurately, as the scope signal depends mostly on parasitic resistance and inductance (20m and 200nH).  Probing at the high-voltage node, between the 22uH and 100m-ohm, will give you a more accurate measure of mmc voltage, which will be more accurately 90 degrees from current.
« Reply #122 on: April 26, 2020, 09:39:09 PM »
I can't seem to get it work with your method. The controller does a really good job keeping the current constant, so waveform just looks like sine wave:
I'm measuring it at the highest voltage, which should also correspond to the highest current.
Edit: Here's a zoomed in version of the previous picture. There does seem to be a small bump right before the peak. Not sure if this is where the transistors are switching.
Edit 2: Tried a new way. I took the sine wave and subtracted the H bridge output, and it looks like this:
I'm only testing it at low voltage, but it's enough to trip the overcurrent.
« Last Edit: April 26, 2020, 10:09:31 PM by ritaismyconscience »
« Reply #123 on: April 26, 2020, 10:10:36 PM »
You could probe the H-Bridge-to-MMC connection to verify that there's still a square-wave there.  Just in case one side of the H-Bridge fried, or the bus voltage is collapsing during the burst, then there wouldn't be the step on the MMC-to-primary connection.  If the MMC side of the H-Bridge has a good square-wave signal, then those same steps will show up on the high-voltage (primary winding) end of the MMC on top of it's higher-voltage sine-wave component.  (Check in your simulation too, probe the 50nF to 22uH node.  I think your simulation likely has less loss than real life, so you may see over 12kV, but there will still be the step on top.)
« Reply #124 on: April 26, 2020, 10:13:12 PM »
I tried probing it and there is a square wave. I think the capacitor method doesn't work very well for the H bridge for some reason. I also tried measuring through a 10M resistor, and I got the same waveform (a sine wave with some ridges). I onl y got a square wave when I connected the probe directly to the output.
« Reply #125 on: April 26, 2020, 10:38:04 PM »
At low bus voltage, the H-Bridge output square-wave will be low amplitude.  With bursts long enough to ramp current to your 500A limit, then the MMC-to-primary node will still have max voltage.  Perhaps the H-Bridge output steps are just too small to see on the full MMC voltage.
Today at 02:12:16 AM
Today at 01:04:06 AM
post Re: Moving to a new lab!
Today at 12:55:12 AM
August 13, 2020, 10:59:27 PM
August 13, 2020, 09:55:27 PM
August 13, 2020, 09:45:58 PM
August 13, 2020, 08:26:56 PM
August 13, 2020, 07:02:24 PM
August 13, 2020, 06:23:24 PM
August 13, 2020, 06:15:16 PM
August 13, 2020, 05:26:47 PM
August 13, 2020, 05:25:43 PM
August 13, 2020, 05:23:40 PM
August 13, 2020, 05:23:37 PM
August 13, 2020, 01:44:24 PM
August 13, 2020, 01:09:16 PM
Yak
August 13, 2020, 12:41:06 PM
August 13, 2020, 11:01:46 AM
August 13, 2020, 02:09:13 AM
August 12, 2020, 11:08:35 PM
August 12, 2020, 10:49:52 PM
August 12, 2020, 10:30:54 PM
August 12, 2020, 09:00:50 PM
August 12, 2020, 07:16:43 PM
August 12, 2020, 02:54:33 PM
August 12, 2020, 12:42:50 PM
August 12, 2020, 12:23:58 PM
August 12, 2020, 11:15:07 AM
August 12, 2020, 04:41:24 AM
August 12, 2020, 04:06:09 AM
August 12, 2020, 01:58:47 AM
August 12, 2020, 12:56:02 AM
August 11, 2020, 11:24:18 PM
August 11, 2020, 06:34:05 PM
Lightning On Demand
August 11, 2020, 04:19:01 AM
Lightning On Demand
August 11, 2020, 04:17:27 AM
Lightning On Demand
August 11, 2020, 04:10:34 AM
August 11, 2020, 03:33:02 AM
August 10, 2020, 12:23:05 PM
August 10, 2020, 12:18:04 PM
August 10, 2020, 10:24:54 AM
August 10, 2020, 06:20:04 AM
RoadReaper
August 10, 2020, 05:40:19 AM
August 10, 2020, 02:07:26 AM
August 10, 2020, 01:27:22 AM
TheFreq
August 09, 2020, 09:02:32 PM
August 08, 2020, 10:22:04 PM
August 08, 2020, 03:36:40 PM
August 08, 2020, 02:07:52 AM
LesWright
August 06, 2020, 10:20:12 PM
