Author Topic: 833C versus 833A vacuum tube  (Read 182 times)
« on: February 09, 2020, 09:16:13 PM »
My VTTC currently uses an Amperex 833A tube. As most of you know, you have to be careful of the power level when running in CW mode (non-interrupter). When in CW mode you have to pay careful attention to the plate color. If it gets too hot it will melt. Because of this I can't operate my VTTC at full power in CW mode, only in interrupter (staccato) mode.
I have been considering replacing the 833A with a 833C. My understanding is that the graphite plate of the 833C will allow me to operate it at a higher power level in CW mode. I have never used a 833C. My understanding is that the graphite plate never changes color regardless of power level. My concern is that I will no longer have that visual feedback to know if I am over-powering the plate. I wouldn't want to accidentally destroy an expensive 833C.
Does anyone have any experience using a 833C in this application? Do I need to worry about the plate temperature?
Re: 833C versus 833A vacuum tube
« Reply #1 on: February 10, 2020, 11:41:55 PM »
Without experience here,
I would expect plate color to be roughly the same for blackened steel and graphite that are radiating the same power.  People with practical experience may know otherwise.
Any difference would come from the surfaces having different emissivity (with respect to blackbody).
Hypothetical blackbody surface, radiating a given amount of power, has an easily predictable temperature and color.
Other materials at the same power level have higher actual temperature, because their e < 1.
They can have color different from blackbody at that higher temperature, because e varies with wavelength.
Here's a picture from
https://rbellew.wordpress.com/2014/05/04/vacuum-tubes-magic-1940/
« Last Edit: February 10, 2020, 11:43:33 PM by klugesmith »
« Reply #2 on: February 10, 2020, 11:55:21 PM »
I know that for the 833A the plate can operate safely at any color up to reddish-orange. One you start getting into reddish-yellow, its time to back off.  It may be that the 833C can safely operate at reddish-yellow and beyond because its graphite plate will not melt at those temperatures. I don't know.
This is only a problem in CW mode. I can operate at full power in interrupter mode. This is the mode of operation that I usually use.
« Reply #3 on: February 11, 2020, 02:12:31 PM »
Yes, as klugesmith says, a shiny surface radiates much less power than a black one.
Consider a shiny surface placed next to a black one. They will stay at the same temperature (if neither one is heated), even though the black one will absorb much more of the heat radiation between them, than the shiny one. That can only happen, if also the black one radiates much more than the shiny one.
That might be another reason for the choice of a graphite anode aside from the melting point.
post Re: NST
post FPS4000
Hoser415
spacecabbie
post Re: 230 volts spark gap
[Smart Phones]
dj.cosmo.esq
Quentief
Quentief
Quentief
Peregrine
Peregrine
Peregrine
warmania
latethannever
Peregrine
