Author Topic: GM tube hv transformer  (Read 1138 times)
Offline AlexanderHun
« on: January 24, 2020, 06:24:25 PM »
Hello!
I managed to get two pieces of Geiger Müller tubes, museum pieces, unfortunately they are operating at a high enough voltage. I need a switch with adjustable output voltage of 1200-1500 volts to test them. Anyone have any ideas?
Offline haversin
Re: GM tube hv transformer
« Reply #1 on: January 24, 2020, 10:29:14 PM »
I use three parts from a microwave oven  (The Hv transformer, Hv diode and Hv capacitor) and power it with a variac to control the voltage. Most DMM's can measure the output voltage directly. Don't forget a 10 meg anode resistor (some tubes use less) on the GM tube.
« Reply #2 on: January 24, 2020, 10:53:42 PM »
To get 2000 V for detector bias,
my first try was a small variac + tiny NST + diode, capacitor, permanently connected kV meter, and a weakening resistor between variac and NST.
Too much ripple voltage ( a volt at 60 Hz?  Some mV at 120 Hz with bridge rectifier & bigger capacitor ) for the Charge Sensitive Preamplifier and my proportional counter tube.  When checking ripple voltage with your oscilloscope in AC-coupled mode, mind the kilovolts.
Then I went out and bought an old NIM Bin, and a 0 to 5000 volt bias generator module to plug into it.
The 1960's or 1970's design has an 8 or 10 stage voltage multiplier, following a small transformer running at 25 kHz, driven by a multivibrator made from discrete transistors.  The size of capacitors in voltage multiplier makes the output impedance about 5 megohms.
That's how I would go for a scratch-built bias supply.  As found online in many GM counter projects.
See also the HV power circuits in battery-powered civil defense instruments.
If ripple voltage is not a big concern, you might try a mains-frequency voltage multiplier, optionally following a step-up transformer.  Haversin's MOT approach is probably easier & better.  Small MOT might not need active cooling if operated at 1/3 or 1/2 of nominal voltage.
« Last Edit: January 24, 2020, 11:35:35 PM by klugesmith »
Offline haversin
« Reply #3 on: January 25, 2020, 01:15:21 AM »
GM tubes are generally operated in the middle of the Geiger-Muller region where there is a plateau in the counting rate verses voltage response curve. Voltage regulation within a few volts is perfectly acceptable in this region. Operation in the proportional region is at a lower voltage and close voltage regulation is required.
« Last Edit: January 25, 2020, 01:28:47 AM by haversin »
« Reply #4 on: January 25, 2020, 11:01:24 AM »
I built a geiger counter for high school project using Wenzel's ferrite choke HV supply. It uses 555 monostable for pulse detection and electrolytic capacitor for "counting" pulses per minute
http://www.techlib.com/electronics/graphics/geiger2ind.gif
Power consumption is amazingly low, less than 1 mA, my counter still has original 2011 batteries
« Last Edit: January 25, 2020, 11:14:08 AM by futurist »
Offline shrad
« Reply #5 on: January 28, 2020, 12:32:39 PM »
CFL inverters make good small power supplies for GM tubes
Today at 05:50:56 PM
Today at 02:59:47 PM
post Re: VTTC on GU-81M
Continuum
Today at 12:18:10 PM
Today at 09:49:57 AM
Today at 09:18:53 AM
Today at 09:13:12 AM
Today at 06:45:24 AM
post Re: DRSSTC driver
September 20, 2020, 08:37:58 PM
September 20, 2020, 05:31:25 PM
GKnapp
September 20, 2020, 05:20:51 PM
September 20, 2020, 03:46:15 PM
post Re: How do you all pronounce kluge or kludge?
September 20, 2020, 03:25:48 PM
September 20, 2020, 02:12:35 PM
GKnapp
September 20, 2020, 02:02:34 PM
September 20, 2020, 01:27:52 PM
September 20, 2020, 11:58:14 AM
friday
September 20, 2020, 07:53:30 AM
September 20, 2020, 06:09:20 AM
September 20, 2020, 05:58:46 AM
September 20, 2020, 04:40:21 AM
September 20, 2020, 02:22:28 AM
post Re: Cheapest source so far for step adjustable DC power for ZVS induction heaters
September 20, 2020, 02:06:56 AM
September 19, 2020, 11:34:01 PM
post How do you all pronounce kluge or kludge?
September 19, 2020, 11:21:11 PM
September 19, 2020, 10:13:44 PM
post Re: Fat wire for facility (a house)
September 19, 2020, 09:40:56 PM
post steam engine
September 19, 2020, 07:54:41 PM
post DRSSTC driver
September 19, 2020, 04:50:28 PM
post Re: Join Kaizer Power Electronics, Youtube channel now has memberships
[Crowdfunding]
September 19, 2020, 04:50:23 PM
September 19, 2020, 03:27:57 PM
post DRSSTC Tuning for Music vs Big Sparks?
GKnapp
September 19, 2020, 01:41:14 PM
September 19, 2020, 11:09:16 AM
post Am I Misunderstanding of DC Blocking Capacitors
werd
September 19, 2020, 08:13:55 AM
September 19, 2020, 01:31:34 AM
post Cheapest source so far for step adjustable DC power for ZVS induction heaters
September 18, 2020, 11:58:14 PM
post Fat wire for facility (a house)
September 18, 2020, 10:35:59 PM
September 18, 2020, 05:29:24 PM
September 18, 2020, 03:52:08 PM
September 18, 2020, 02:49:05 PM
post Re: IGBT Temperature
September 18, 2020, 11:56:58 AM
September 18, 2020, 10:31:58 AM
post Re: Eensy weensy switchmode power supplies
September 18, 2020, 08:19:19 AM
post Re: Upper audio frequency interruption of HFSSTC
September 17, 2020, 11:18:25 PM
September 17, 2020, 10:26:57 PM
September 17, 2020, 09:13:40 PM
uzzors2k
September 17, 2020, 09:02:42 PM
September 17, 2020, 07:46:08 PM
September 17, 2020, 07:43:00 PM
September 17, 2020, 10:23:29 AM
September 17, 2020, 06:56:59 AM
