Author Topic: GM tube hv transformer  (Read 1233 times)
Offline AlexanderHun
« on: January 24, 2020, 06:24:25 PM »
Hello!
I managed to get two pieces of Geiger Müller tubes, museum pieces, unfortunately they are operating at a high enough voltage. I need a switch with adjustable output voltage of 1200-1500 volts to test them. Anyone have any ideas?
Offline haversin
Re: GM tube hv transformer
« Reply #1 on: January 24, 2020, 10:29:14 PM »
I use three parts from a microwave oven  (The Hv transformer, Hv diode and Hv capacitor) and power it with a variac to control the voltage. Most DMM's can measure the output voltage directly. Don't forget a 10 meg anode resistor (some tubes use less) on the GM tube.
« Reply #2 on: January 24, 2020, 10:53:42 PM »
To get 2000 V for detector bias,
my first try was a small variac + tiny NST + diode, capacitor, permanently connected kV meter, and a weakening resistor between variac and NST.
Too much ripple voltage ( a volt at 60 Hz?  Some mV at 120 Hz with bridge rectifier & bigger capacitor ) for the Charge Sensitive Preamplifier and my proportional counter tube.  When checking ripple voltage with your oscilloscope in AC-coupled mode, mind the kilovolts.
Then I went out and bought an old NIM Bin, and a 0 to 5000 volt bias generator module to plug into it.
The 1960's or 1970's design has an 8 or 10 stage voltage multiplier, following a small transformer running at 25 kHz, driven by a multivibrator made from discrete transistors.  The size of capacitors in voltage multiplier makes the output impedance about 5 megohms.
That's how I would go for a scratch-built bias supply.  As found online in many GM counter projects.
See also the HV power circuits in battery-powered civil defense instruments.
If ripple voltage is not a big concern, you might try a mains-frequency voltage multiplier, optionally following a step-up transformer.  Haversin's MOT approach is probably easier & better.  Small MOT might not need active cooling if operated at 1/3 or 1/2 of nominal voltage.
« Last Edit: January 24, 2020, 11:35:35 PM by klugesmith »
Offline haversin
« Reply #3 on: January 25, 2020, 01:15:21 AM »
GM tubes are generally operated in the middle of the Geiger-Muller region where there is a plateau in the counting rate verses voltage response curve. Voltage regulation within a few volts is perfectly acceptable in this region. Operation in the proportional region is at a lower voltage and close voltage regulation is required.
« Last Edit: January 25, 2020, 01:28:47 AM by haversin »
« Reply #4 on: January 25, 2020, 11:01:24 AM »
I built a geiger counter for high school project using Wenzel's ferrite choke HV supply. It uses 555 monostable for pulse detection and electrolytic capacitor for "counting" pulses per minute
http://www.techlib.com/electronics/graphics/geiger2ind.gif
Power consumption is amazingly low, less than 1 mA, my counter still has original 2011 batteries
« Last Edit: January 25, 2020, 11:14:08 AM by futurist »
Offline shrad
« Reply #5 on: January 28, 2020, 12:32:39 PM »
CFL inverters make good small power supplies for GM tubes
post Re: DIY current transformer for measuring primary current?
Daniel Uhrenholt
Today at 09:41:48 AM
Today at 01:46:20 AM
October 24, 2020, 11:12:37 PM
Daniel Uhrenholt
October 24, 2020, 11:07:33 PM
Daniel Uhrenholt
October 24, 2020, 10:45:41 PM
Daniel Uhrenholt
October 24, 2020, 10:12:37 PM
October 24, 2020, 09:29:06 PM
October 24, 2020, 09:20:37 PM
October 24, 2020, 09:07:24 PM
post Re: Software for playing MIDIs
October 24, 2020, 07:29:57 PM
October 24, 2020, 07:02:13 PM
Daniel Uhrenholt
October 24, 2020, 06:38:42 PM
October 24, 2020, 05:42:49 PM
post Software for playing MIDIs
October 24, 2020, 04:37:26 PM
Daniel Uhrenholt
October 24, 2020, 03:51:52 PM
October 24, 2020, 02:25:00 PM
Daniel Uhrenholt
October 24, 2020, 12:12:41 PM
post MOVED: DIY current transformer for scoping primary current?
Kizmo
October 24, 2020, 11:45:58 AM
post DIY current transformer for measuring primary current?
Daniel Uhrenholt
October 24, 2020, 11:22:24 AM
post Re: Ping pong (and pumpkin?) cannons - split from ferrite-core QCW topic
October 24, 2020, 04:16:06 AM
October 24, 2020, 04:07:24 AM
October 23, 2020, 11:39:35 PM
October 23, 2020, 07:10:22 PM
October 23, 2020, 05:36:02 PM
October 23, 2020, 05:34:39 PM
post MOVED: Ping pong (and pumpkin?) cannons - split from ferrite-core QCW topic
October 23, 2020, 05:27:45 PM
October 23, 2020, 03:03:28 PM
post Re: RC snubbers
October 23, 2020, 12:27:42 AM
October 22, 2020, 10:06:59 PM
October 22, 2020, 09:05:22 PM
October 22, 2020, 07:17:16 PM
October 22, 2020, 05:33:39 PM
October 22, 2020, 02:07:27 PM
post RC snubbers
October 22, 2020, 11:42:26 AM
SAMGO
October 22, 2020, 11:21:19 AM
October 22, 2020, 09:14:24 AM
October 22, 2020, 06:19:28 AM
October 22, 2020, 04:21:50 AM
October 22, 2020, 01:23:15 AM
October 21, 2020, 08:31:51 PM
October 21, 2020, 08:21:55 PM
October 21, 2020, 07:17:07 PM
October 21, 2020, 01:30:19 PM
October 21, 2020, 05:00:34 AM
October 21, 2020, 04:46:55 AM
October 21, 2020, 04:42:19 AM
October 21, 2020, 02:29:54 AM
October 20, 2020, 11:50:25 PM
SAMGO
October 20, 2020, 10:50:25 PM
October 20, 2020, 09:38:42 PM
