Author Topic: Small DIY plasma globe using ZVS oscillator  (Read 477 times)
« on: January 22, 2020, 06:21:31 AM »
This is my latest little project - only 20 watts.  Made a plasma ball from a plastic wine glass filled with about 15kPa of argon.  Works some with air at lower pressure, around 5kPa.  Experimented with argon/helium mixtures, but plain argon was the brightest.  Don't have neon nor xenon around (due to expense), the normal gasses inside plasma balls.  Mine isn't as bright and doesn't have multiple colors.  Still fun.
For the HV transformer, I used a pair of small already-potted transformers from EBay:
https://www.ebay.com/itm/20KV-high-frequency-high-voltage-transformer-ignition-coil-inverter-driver-bNWUS/323974762353?hash=item4b6e668f71:m:mg4RAb8mo-3R0Me2JUcxcfw
The pair are electrically and magnetically in series, both primary and secondary.  Magnetic path is closed with some NiZn ferrite pieces (low electrical conductivity type).  Still some gap due to the potting.  Driving circuit consists of a normal hard-switched buck converter using the same inductor as the ZVS input inductor, 19V to 15V(adjustable), with ~1.2A current limit.  Separate buck and ZVS boards, still connected with clip leads in the pictures:
The HV winding capacitance and load (plasma ball) capacitance alone makes a ~25kHz resonant frequency.  So, I added only a little bit more primary-side capacitance.  This creates an issue with the two possible resonant modes, one at ~25kHz and another (with primary and secondary voltages opposite) at ~530kHz.  To keep the ZVS oscillation from locking to 530kHz, I added a series LRC notch filter across the ZVS output (transformer primary).  Schematic is:
Here are a few waveforms of the ZVS outputs (transformer primary terminals).  First is with low load (nothing touching the plasma ball).  Second and third are with load (hand on plasma ball), showing lower voltage (due to buck-converter current limit) and a cycle or two of high-frequency mode ring at each zero-crossing.  Without the notch filter, the ZVS locks to the high frequency and stays there.
Any suggestions for improvements?
2/2020 update:  After a longer run, the little transformers developed an arc path between the two, burning through the potting material.  I've replaced them with two identical parts glued end-to-end instead, avoiding the series HV being adjacent.  Haven't ran that configuration for long yet.
« Last Edit: February 20, 2020, 05:17:40 AM by davekni »
Offline John123
  • All the gear, no idea. UK
Re: Small DIY plasma globe using ZVS oscillator
« Reply #1 on: April 07, 2020, 02:29:21 AM »
Very cool! Wish I could help with your question for suggestions but I'm not at that level of skill yet, maybe some ferrite beads could help with the spiking on the primary waveforms?
Aw I hate it when hv transformers have insulation breakdown during the fun.
Today at 03:55:56 PM
Today at 10:25:50 AM
post Re: SSTC Micro
Today at 04:59:02 AM
Today at 04:32:26 AM
post Re: SSTC Micro
Rowdy
Today at 04:12:23 AM
Rowdy
Today at 03:41:17 AM
Rowdy
Today at 03:40:25 AM
post Re: SSTC Micro
jockoFergy
Today at 02:42:23 AM
May 27, 2020, 06:21:39 PM
fnordest
May 27, 2020, 12:11:06 PM
May 27, 2020, 11:51:19 AM
May 26, 2020, 07:55:03 PM
May 26, 2020, 07:40:48 PM
iraquois
May 26, 2020, 05:12:42 PM
May 26, 2020, 03:57:04 PM
May 26, 2020, 01:52:26 PM
May 26, 2020, 11:52:33 AM
May 26, 2020, 09:40:52 AM
May 26, 2020, 08:56:01 AM
May 26, 2020, 08:45:40 AM
May 26, 2020, 08:27:58 AM
May 26, 2020, 06:31:59 AM
May 26, 2020, 05:24:41 AM
May 26, 2020, 02:01:33 AM
iraquois
May 26, 2020, 01:12:46 AM
May 26, 2020, 12:37:32 AM
May 25, 2020, 10:35:49 PM
May 25, 2020, 09:30:41 PM
May 25, 2020, 08:17:18 PM
iraquois
May 25, 2020, 07:43:30 PM
May 25, 2020, 03:32:54 PM
May 25, 2020, 12:52:38 PM
May 25, 2020, 10:34:56 AM
kilohercas
May 25, 2020, 06:38:15 AM
May 25, 2020, 03:24:49 AM
post Re: SSTC Micro
May 25, 2020, 03:24:20 AM
Rowdy
May 25, 2020, 03:23:33 AM
May 25, 2020, 03:06:20 AM
May 25, 2020, 01:33:47 AM
post MMC for a 32kvac load
Rowdy
May 25, 2020, 01:02:34 AM
Rowdy
May 24, 2020, 11:47:26 PM
post Re: GDT cable specs
May 24, 2020, 11:09:44 PM
Rowdy
May 24, 2020, 10:39:45 PM
station240
May 24, 2020, 09:55:49 PM
May 24, 2020, 09:55:48 PM
May 24, 2020, 08:16:40 PM
thecyberman
May 24, 2020, 05:38:27 PM
Rowdy
May 24, 2020, 02:33:55 PM
hip424
May 24, 2020, 02:31:39 PM
iraquois
May 24, 2020, 02:08:53 PM
