Author Topic: A hydroelectric system getting built  (Read 178 times)
Offline plasma
« on: January 11, 2020, 11:26:31 PM »
Hi just thought I'll post a hydroelectric system I'm building, its taking awhile, but the relative I'm building it for isn't in a rush.
Below is the blades with the skirt yet to be finished.
Re: A hydroelectric system getting built
« Reply #1 on: January 12, 2020, 01:53:35 AM »
Nice.
Can you tell us the intended flow rate and pressure head?
Offline plasma
« Reply #2 on: January 12, 2020, 02:03:03 AM »
Its a river, using 1meter head, the flow rate is guessmaite of 0.1m/sec ,but that could be miles off ;), its about 1-2m deep.
1000kg/m3 * 0.1m3/sec * 1m = 100watt
The https://www.powerspout.com/collections/complete-smart-drive-pmas/products/complete-42pole-pma-1-2kw Genny.
« Last Edit: January 12, 2020, 02:09:10 AM by plasma »
« Reply #3 on: January 12, 2020, 04:02:42 AM »
I can't make sense of your arithmetic, because kilogram meter per second is dimensionally different from power.  Acceleration of gravity (g) is missing.  But the bottom line seems not too crazy.
Power = pressure x flow.
Water head of 1 meter is the same as pressure of about 10000 N/m^2 = 10 kPa.
Flow for 100 watts before losses: 0.01 m^3/s = 10 liters/s.
That's the flow in a cross-sectional area of 0.1 square meter at velocity of 0.1 m/s.
But velocity of free flowing stream isn't relevant, is it?  Will your weldment go at the end of a penstock, or flume and penstock, connecting places where the river surface elevation is different by a meter?
« Last Edit: January 12, 2020, 04:16:49 AM by klugesmith »
Offline plasma
« Reply #4 on: January 12, 2020, 05:01:29 AM »
Its a free flowing stream, I justed used 1m but the gradient on there property might be that over the whole thing.
The foumla used was power = density * flow * gravity * head ,as there's no head I removed gravity and head??
« Reply #5 on: January 12, 2020, 01:35:20 PM »
The formula is fine. In your calculation
you left out "gravity" or more precisely the gravitational acceleration, which is about 10m/s². So you get:
power = 1000kg/m³ * 0.1m³/s * 10m/s² * 1m = 1000 kg m²/s³ = 1000 W.
« Reply #6 on: January 12, 2020, 06:23:30 PM »
Yup. But Plasma gave numbers without stating the problem, so we have to guess.
The thousand-watt answer is for a flow of 0.1m³/s dropping vertically by 1 meter.
How do either of those factors relate to the river and the pictured hydroelectric part?
It will be nice to see more progress on the project.  Congratulations for doing things instead of talking about other people's things.
I have a buddy whose electric bill is offset by power from a little creek in hilly terrain.  A penstock made from plastic pipe brings water from far upstream, where the creek level is (IIRC) more than 20 meters higher.  Enough that a Pelton wheel is the appropriate kind of turbine; some are listed in Plasma's product link.
January 25, 2020, 11:01:24 AM
January 25, 2020, 06:44:21 AM
January 25, 2020, 06:37:47 AM
January 25, 2020, 02:22:09 AM
January 25, 2020, 01:15:21 AM
January 24, 2020, 10:53:42 PM
January 24, 2020, 10:52:48 PM
January 24, 2020, 10:29:14 PM
bozidar
January 24, 2020, 08:16:12 PM
post GM tube hv transformer
AlexanderHun
January 24, 2020, 06:24:25 PM
January 24, 2020, 05:17:01 PM
post Re: My 833A VTTC
January 24, 2020, 04:37:25 PM
justin66
January 24, 2020, 04:15:41 PM
January 24, 2020, 01:15:46 PM
January 24, 2020, 01:10:38 PM
January 24, 2020, 12:39:01 PM
justin66
January 24, 2020, 11:43:08 AM
kilovolt
January 24, 2020, 11:10:55 AM
January 24, 2020, 10:11:51 AM
kilovolt
January 24, 2020, 09:03:52 AM
January 23, 2020, 11:50:22 PM
January 23, 2020, 11:42:56 PM
January 23, 2020, 11:35:07 PM
justin66
January 23, 2020, 11:15:12 PM
January 23, 2020, 10:42:22 PM
January 23, 2020, 10:03:17 PM
kilovolt
January 23, 2020, 09:55:05 PM
January 23, 2020, 08:39:10 PM
January 23, 2020, 08:37:43 PM
January 23, 2020, 08:16:02 PM
justin66
January 23, 2020, 07:48:39 PM
kilovolt
January 23, 2020, 05:07:46 PM
kilovolt
January 23, 2020, 05:05:40 PM
kilovolt
January 23, 2020, 05:01:27 PM
January 23, 2020, 04:34:34 PM
post Re: My X-Ray Machine
Agent Smith
January 23, 2020, 03:47:06 PM
January 23, 2020, 02:24:07 PM
January 23, 2020, 01:29:01 PM
January 23, 2020, 12:45:40 PM
January 23, 2020, 11:38:18 AM
January 23, 2020, 10:43:36 AM
January 23, 2020, 08:32:56 AM
January 23, 2020, 06:06:20 AM
January 23, 2020, 05:57:18 AM
post Doorknob vs Ceramic Disk
January 23, 2020, 03:57:09 AM
January 23, 2020, 12:33:44 AM
January 22, 2020, 11:45:26 PM
January 22, 2020, 11:30:26 PM
post Small DIY plasma globe using ZVS oscillator
January 22, 2020, 06:21:31 AM
January 22, 2020, 05:54:17 AM
