Author Topic: Skm100 coil  (Read 2669 times)
Offline nevermore1983
Re: Skm100 coil
« Reply #20 on: April 12, 2020, 02:48:18 PM »
Great stuff i cant wait to get started with my Skm 100 build now. Still just getting all my parts together so its going to be a few weeks be for i can make a start on it.
Re: Skm100 coil
« Reply #21 on: April 12, 2020, 03:39:21 PM »
nice,
from what i've experienced these bricks seem robust.... that works well for me because i'm rough haha. Looking forward to your build
Offline flyglas
Re: Skm100 coil
« Reply #22 on: April 12, 2020, 04:56:30 PM »
Hi oneKone,
do you know the input power of te coil? Is this coil useable at a 230V / 16A power outlet?
Re: Skm100 coil
« Reply #23 on: April 13, 2020, 12:20:53 AM »
Hi oneKone,
It's actually running off a 230v/25a outlet. Although the current draw is under 8-9a, I should actually get a proper reading
Re: Skm100 coil
« Reply #24 on: April 13, 2020, 03:19:37 PM »
last major update!
I made a 500mm toroid for the coil, it really didn't make much of a difference and also just looked wrong! so i put the 400mm toroid back on, buttoned up the mounting and for the most part finished the coil. There will be small changes to it along the way.
final specs:
Fullbridge of aliexpress skm100gb125dn igbts (active cooling)
bus capacitance: epcos 4700uf 400v
mmc: 2 X kemet 330nf 3kv dc capacitors in series for 165nf tank capacitance
Profdc9 tht ud2.7c driver
3.175mm diameter primary coil, 100mm starting diameter, 8mm pitch, 7 turns - tapped at 6 turns (for the time being)
secondary: 80mm diameter, 400mm winding length, wound with temco 32awg magnet wire
400mm toroid made from semi rigid aluminium ducting
320v dc bus voltage, 550A current limit.
There are some things i wouldn't mind changing on the coil, but then to me it takes away from the character of the build... it's not perfect and it never will be, it simply just is. I do have a spare identical secondary i wound, so maybe it will be built into a similar coil just to get my construction more honed in. As for my bigger drsstc build... that will be on hold until everything around the world settles down and also i can make sure the industry i work for doesn't go quiet aka i don't want to spend "big money" on a project right now. but it does leave me to ponder my next build -or experiment?
secondary diameter: 230mm, winding length 560mm with 22awg temco wire.
i'm thinking of getting profdc9 ud2.9 pcb boards made to have a go at a pulse skipped coil with 2 X skm100gb in parallel half bridge?
Re: Skm100 coil
Today at 02:12:16 AM
Today at 01:04:06 AM
post Re: Moving to a new lab!
Today at 12:55:12 AM
August 13, 2020, 10:59:27 PM
August 13, 2020, 09:55:27 PM
August 13, 2020, 09:45:58 PM
August 13, 2020, 08:26:56 PM
August 13, 2020, 07:02:24 PM
August 13, 2020, 06:23:24 PM
August 13, 2020, 06:15:16 PM
August 13, 2020, 05:26:47 PM
August 13, 2020, 05:25:43 PM
August 13, 2020, 05:23:40 PM
August 13, 2020, 05:23:37 PM
August 13, 2020, 01:44:24 PM
August 13, 2020, 01:09:16 PM
Yak
August 13, 2020, 12:41:06 PM
August 13, 2020, 11:01:46 AM
August 13, 2020, 02:09:13 AM
August 12, 2020, 11:08:35 PM
August 12, 2020, 10:49:52 PM
August 12, 2020, 10:30:54 PM
August 12, 2020, 09:00:50 PM
August 12, 2020, 07:16:43 PM
August 12, 2020, 02:54:33 PM
August 12, 2020, 12:42:50 PM
August 12, 2020, 12:23:58 PM
August 12, 2020, 11:15:07 AM
August 12, 2020, 04:41:24 AM
August 12, 2020, 04:06:09 AM
August 12, 2020, 01:58:47 AM
August 12, 2020, 12:56:02 AM
August 11, 2020, 11:24:18 PM
August 11, 2020, 06:34:05 PM
Lightning On Demand
August 11, 2020, 04:19:01 AM
Lightning On Demand
August 11, 2020, 04:17:27 AM
Lightning On Demand
August 11, 2020, 04:10:34 AM
August 11, 2020, 03:33:02 AM
August 10, 2020, 12:23:05 PM
August 10, 2020, 12:18:04 PM
August 10, 2020, 10:24:54 AM
August 10, 2020, 06:20:04 AM
RoadReaper
August 10, 2020, 05:40:19 AM
August 10, 2020, 02:07:26 AM
August 10, 2020, 01:27:22 AM
TheFreq
August 09, 2020, 09:02:32 PM
August 08, 2020, 10:22:04 PM
August 08, 2020, 03:36:40 PM
August 08, 2020, 02:07:52 AM
LesWright
August 06, 2020, 10:20:12 PM
