Author Topic: DRSSTC with parts from computer PSU  (Read 687 times)
Offline Zipdox
« on: December 16, 2019, 10:08:56 PM »
Computer power supplies contain a lot of high voltage components like rectifiers, capacitors, MOSFETs, diodes as well as loads of inductors. I was wondering if it was realistic to build a DRSSTC with components from a PSU.
Re: DRSSTC with parts from computer PSU
« Reply #1 on: December 16, 2019, 10:21:58 PM »
Depends, i think you have no chance of doing that if you want a high power DRSSTC, since you need IGBTs to switch very high currents, even a small DRSSTC runs 200A+ on primary. And in computer PSU you probably will not find any IGBTs. All of the computer PSUs i've dissassembled used MOSFETs, and as far as i know, you would fry MOSFETs when switching high currents. Also for DRSSTC you need way bigger bus capacitance than computer PSU capacitors can provide.
« Last Edit: December 16, 2019, 10:23:39 PM by AstRii »
Offline Zipdox
« Reply #2 on: December 16, 2019, 10:40:05 PM »
Most PSU's contain 2 MOSFETS to switch rectify mains voltage. The one I disassembled had 2 21NM60N's which are rated for up to 600 volts. Would it be possible to utilize those in some way?
« Reply #3 on: December 16, 2019, 11:11:56 PM »
You would at most be able to make a small SSTC from a computer PSU, not a DRSSTC.
You would still need to buy some components like a suitable ferrite ring core for the GDT and some MOSFET driver ICs.
The only things to use from the PSU would be: bridge rectifier, electrolytic capacitor, MOSFETs, maybe heat sink, the rest is of no real use.
Offline Zipdox
« Reply #4 on: December 16, 2019, 11:27:39 PM »
These are all the power semiconductors I found inside
  • 2x GBU606
  • 2x F21NM60N
  • 4x FCP20N60
  • 7x YM303045N
The F21NM60N and FCP20N60 seem very similar if you look in the datasheet. I was thinking maybe I could put 2 FCP20N60's in parallel and create a half bridge with a pair of those.
Today at 02:04:42 PM
Today at 01:07:31 PM
Today at 01:06:03 PM
Today at 01:03:45 PM
Today at 12:38:11 PM
Today at 12:28:18 PM
Yak
Today at 11:55:43 AM
Today at 04:47:06 AM
Today at 12:01:20 AM
August 14, 2020, 11:01:58 PM
August 14, 2020, 10:49:26 PM
August 14, 2020, 09:46:53 PM
August 14, 2020, 09:22:35 PM
August 14, 2020, 09:17:50 PM
August 14, 2020, 09:16:38 PM
August 14, 2020, 07:01:47 PM
August 14, 2020, 06:56:46 PM
August 14, 2020, 06:38:45 PM
August 14, 2020, 06:25:31 PM
post Re: Moving to a new lab!
August 14, 2020, 10:54:59 AM
August 14, 2020, 10:14:21 AM
Yak
August 14, 2020, 07:26:11 AM
August 14, 2020, 02:12:16 AM
August 14, 2020, 01:04:06 AM
August 14, 2020, 12:55:12 AM
August 13, 2020, 10:59:27 PM
August 13, 2020, 09:55:27 PM
August 13, 2020, 09:45:58 PM
August 13, 2020, 08:26:56 PM
August 13, 2020, 07:02:24 PM
August 13, 2020, 06:23:24 PM
August 13, 2020, 06:15:16 PM
August 13, 2020, 05:26:47 PM
August 13, 2020, 05:25:43 PM
August 13, 2020, 05:23:40 PM
August 13, 2020, 05:23:37 PM
August 13, 2020, 01:44:24 PM
August 13, 2020, 01:09:16 PM
Yak
August 13, 2020, 12:41:06 PM
August 13, 2020, 11:01:46 AM
August 13, 2020, 02:09:13 AM
August 12, 2020, 11:08:35 PM
August 12, 2020, 10:49:52 PM
August 12, 2020, 10:30:54 PM
August 12, 2020, 09:00:50 PM
August 12, 2020, 07:16:43 PM
August 12, 2020, 02:54:33 PM
August 12, 2020, 12:42:50 PM
August 12, 2020, 12:23:58 PM
August 12, 2020, 11:15:07 AM
