Author Topic: Small 65Kv X Ray Transformer hosuing build  (Read 666 times)
Offline DashApple
« on: December 14, 2019, 10:52:49 PM »
Hi All ,
Just wanted to share the small project I have worked on for a while now , my goal was to make small cases for the few x ray transformers I have so I can safely run them .
The transformer in use here is rated 230V Primary and 65Kv @ 8mA secondary .
The housing is made from  150 x 150 x 3mm aluminium box section , I tig welded a base and cut and welded the flange on the top .
Lid is made from polycarbonate , feed throughs are 16mm Diameter pure PTFE ( Teflon ) rods with a 3mm copper bar though the centre , this is then held in place to the lid with a nylon cable gland , both having a tight fit to minimize gaps  .
Transformer was vacuumed for 4 days under slight vibration in transformer grade mineral oil , The box is lined with 2mm Teflon sheet to help improve insulation between the case and wires .
Overall it turned out well : )
Offline ElectroXa
Re: Small 65Kv X Ray Transformer hosuing build
« Reply #1 on: December 17, 2019, 08:08:47 AM »
Hi
it's a nice project, I've a few questions:
what brand of tig welder did you use ?  (because I plan to weld aluminum to make xfmr case and others projects)
and where did you find this small transformer ?  :)
Offline DashApple
« Reply #2 on: December 18, 2019, 07:38:30 AM »
I have an oxford tig welder , I haven't used it much but its nice .
The transformer was from a small x ray head , they show up now and then online .
August 10, 2020, 12:23:05 PM
August 10, 2020, 12:18:04 PM
August 10, 2020, 10:24:54 AM
August 10, 2020, 06:20:04 AM
RoadReaper
August 10, 2020, 05:40:19 AM
August 10, 2020, 02:07:26 AM
August 10, 2020, 01:27:22 AM
TheFreq
August 09, 2020, 09:02:32 PM
August 08, 2020, 10:22:04 PM
August 08, 2020, 03:36:40 PM
acmq
August 08, 2020, 02:07:52 AM
LesWright
August 06, 2020, 10:20:12 PM
August 06, 2020, 08:45:59 PM
August 06, 2020, 05:41:04 PM
post Re: Dual MOT tesla coil
August 06, 2020, 03:53:58 PM
LesWright
August 06, 2020, 03:28:14 PM
August 06, 2020, 12:59:03 PM
August 06, 2020, 10:51:43 AM
UB_Serpent
August 06, 2020, 08:40:57 AM
August 06, 2020, 03:22:38 AM
August 05, 2020, 11:48:55 PM
August 05, 2020, 11:37:13 PM
August 05, 2020, 08:01:11 PM
Lightning On Demand
August 05, 2020, 06:34:08 PM
August 05, 2020, 12:56:32 PM
August 05, 2020, 12:55:52 PM
August 04, 2020, 09:21:09 PM
August 04, 2020, 09:16:55 PM
August 04, 2020, 05:53:03 PM
August 04, 2020, 05:51:03 PM
Lightning On Demand
August 04, 2020, 05:17:26 PM
August 04, 2020, 02:14:56 PM
August 04, 2020, 02:08:07 PM
August 04, 2020, 10:48:35 AM
UB_Serpent
August 04, 2020, 10:02:39 AM
August 04, 2020, 08:47:07 AM
August 04, 2020, 08:43:00 AM
August 04, 2020, 08:33:47 AM
August 04, 2020, 05:09:26 AM
August 04, 2020, 01:54:49 AM
post Fun with wireless power
Lightning On Demand
August 03, 2020, 11:55:41 PM
August 03, 2020, 09:17:40 PM
August 03, 2020, 08:30:38 PM
post Re: Budget USB cameras
missoum0514
August 03, 2020, 06:56:08 PM
August 03, 2020, 05:23:15 PM
nielsquake
August 03, 2020, 05:02:26 PM
August 03, 2020, 04:31:04 PM
August 03, 2020, 10:05:59 AM
August 03, 2020, 08:21:26 AM
nielsquake
August 02, 2020, 11:45:38 PM
