Author Topic: Full bridge much "weaker" than half bridge?  (Read 803 times)
Offline nick
« on: December 11, 2019, 01:10:57 PM »
I have a half bridge of 2x IGBTs driven by a GDT.
I also have a full bridge of exactly the same IGBTs - everything else is identical except for the GDT.
The half bridge works well - big sparks, etc. However literally only swapping out the bridge and GDT, the sparks are puny and form only at higher voltage.
Other than the GDT (I will investigate whether using the same core between the 2 bridges helps), has anyone seen similar issues / could something else be the problem?
Thanks
Offline Fumeaux
Re: Full bridge much "weaker" than half bridge?
« Reply #1 on: December 11, 2019, 03:11:42 PM »
try switching the connections of the gdt on the driver side. It sounds like a polarity issue
Offline nick
« Reply #2 on: December 12, 2019, 11:17:36 AM »
I tried this and as I'm turning the knob on my variac, I see/hear an explosion :) one of the IGBTs and protection diodes literally had scorch marks on them. I was sure they were gonners, but having desoldered and checked them, they still worked - these are some hard ass components. I suspect the explosion was because my half-ass negative power connection was done with thin crocodile clips (connected to 3rd leg of that IGBT) and it accidentally shorted C-E.
I put that aside and connected back my half bridge. It worked great (as usual) for a short while and then an even bigger explosion happened. The inrush current limiting thermistor that I half-assed connected to my bus caps literally blew apart.
I interpreted these 2 events as a sign from god and went to bed. Will pick this project back up on the weekend.
Today at 11:15:01 AM
post COHERENT transformerless 81mHz amplifier schematic ?
dreamth
Today at 10:42:41 AM
post Interrupter frequency?
Today at 10:08:39 AM
dreamth
Today at 09:34:59 AM
post Re: TIG welder teardown. ESAB TIG Caddy 1500i.
Bouaziz
Today at 09:34:05 AM
ChrisBlis
Today at 09:30:38 AM
dreamth
Today at 09:08:55 AM
Today at 07:16:23 AM
Today at 05:08:32 AM
Today at 04:47:32 AM
dreamth
March 03, 2021, 11:20:38 PM
AeraCura_
March 03, 2021, 11:15:32 PM
March 03, 2021, 10:30:40 PM
dreamth
March 03, 2021, 10:03:26 PM
post Re: Need Help w/Build - Lightning Pulse Generator
March 03, 2021, 09:45:28 PM
March 03, 2021, 09:44:17 PM
post First power on tests
March 03, 2021, 06:26:23 PM
March 03, 2021, 05:54:58 PM
dreamth
March 03, 2021, 03:13:30 PM
dreamth
March 03, 2021, 01:18:22 PM
dreamth
March 03, 2021, 12:25:52 PM
dreamth
March 03, 2021, 12:24:40 PM
ChrisBlis
March 03, 2021, 10:43:20 AM
March 03, 2021, 09:05:02 AM
March 03, 2021, 05:53:33 AM
March 03, 2021, 04:22:01 AM
March 03, 2021, 04:00:14 AM
March 03, 2021, 01:21:15 AM
post Re: Just a noob with some HV concerns...
March 03, 2021, 12:36:05 AM
dreamth
March 03, 2021, 12:35:57 AM
March 02, 2021, 11:40:16 PM
dreamth
March 02, 2021, 11:29:28 PM
March 02, 2021, 10:48:04 PM
March 02, 2021, 10:33:13 PM
dreamth
March 02, 2021, 10:20:22 PM
March 02, 2021, 10:18:05 PM
March 02, 2021, 09:38:45 PM
March 02, 2021, 08:54:33 PM
post Re: WTS [EU] Vici DM4070 LCR meter with SMD tweezers
March 02, 2021, 08:53:31 PM
March 02, 2021, 05:04:44 PM
March 02, 2021, 03:16:25 PM
March 02, 2021, 09:41:31 AM
ChrisBlis
March 02, 2021, 08:26:30 AM
hightemp1
March 02, 2021, 07:05:01 AM
March 02, 2021, 06:22:52 AM
post Re: Interesting RF air-core transformer construction
March 02, 2021, 05:24:46 AM
hightemp1
March 02, 2021, 05:21:16 AM
March 02, 2021, 04:37:50 AM
hightemp1
March 02, 2021, 01:26:36 AM
March 01, 2021, 11:07:01 PM
