Author Topic: Driving Nixie-tubes with arduino  (Read 1114 times)
Offline kamelryttarn
« on: December 03, 2019, 09:04:42 AM »
There are many circuits out there using arduino and some extra components to drive nixie tubes but I am trying to figure out a cheap way that don't take up too much space so I would like to use ULN2003 if possible.
When looking at the IN12 Nixie tube drive voltage seem to be around 145V DC and recommended current is 2,5-3,5mA. Do these thing behave like a resistor? Can I assume each digit is like a ~48k resistor? If so I should be able to use a bussed resistor array with 7 pcs of 22k resistor to make sure the ULN2003 is never exposed to more than ~45V (50v is ABSOLUTE MAX according to the data sheet).
Assuming that the internal DC resistance of each digit is never LOWER than ~48k I should be safe right?
The other potential problem is the current when the digit is NOT lit. There will still be close to 2mA running through each digit. Will they be dark or will the probably be dimly lit?
Re: Driving Nixie-tubes with arduino
« Reply #1 on: December 03, 2019, 10:45:58 AM »
Nixie tube digits are not even close to constant-resistance devices.
The normal glowing state is much like a LED: small, and sometimes negative, voltage change with large current change.  There are 10s of volts of hysteresis at the off/on transition.
A digit with 2 mA will be seen as plenty On.
A Google search for ULN2003 Nixie revealed some circuits that work.
Your mission is to learn how they work.
« Last Edit: December 03, 2019, 11:09:37 AM by klugesmith »
« Reply #2 on: December 03, 2019, 01:24:00 PM »
When I built a Nixie tube clock I used common resistors for the Cathodes. I used high voltage NPN transistors MPSA42 to interface the 5V logic to driving the individual numbers.
http://kaizerpowerelectronics.dk/general-electronics/nixie-tube-clock/
« Reply #3 on: December 03, 2019, 02:14:00 PM »
Perhaps SN75468 with its 100V rating would work instead? A transistor array instead of using discrete transistors would save space and make it much easier to connect.
« Reply #4 on: December 03, 2019, 07:54:08 PM »
the best way is to find some 74141 ics that were designed to drive nixies direct from TTL logic
Today at 03:22:38 AM
post Re: Dual MOT tesla coil
August 05, 2020, 11:48:55 PM
August 05, 2020, 11:37:13 PM
August 05, 2020, 08:01:11 PM
Lightning On Demand
August 05, 2020, 06:34:08 PM
August 05, 2020, 12:56:32 PM
August 05, 2020, 12:55:52 PM
August 04, 2020, 09:21:09 PM
August 04, 2020, 09:16:55 PM
August 04, 2020, 05:53:03 PM
August 04, 2020, 05:51:03 PM
Lightning On Demand
August 04, 2020, 05:17:26 PM
August 04, 2020, 02:14:56 PM
August 04, 2020, 02:08:07 PM
August 04, 2020, 10:48:35 AM
UB_Serpent
August 04, 2020, 10:02:39 AM
August 04, 2020, 08:47:07 AM
August 04, 2020, 08:43:00 AM
August 04, 2020, 08:33:47 AM
August 04, 2020, 05:09:26 AM
August 04, 2020, 01:54:49 AM
post Fun with wireless power
Lightning On Demand
August 03, 2020, 11:55:41 PM
August 03, 2020, 09:17:40 PM
August 03, 2020, 08:30:38 PM
post Re: Budget USB cameras
missoum0514
August 03, 2020, 06:56:08 PM
August 03, 2020, 05:23:15 PM
nielsquake
August 03, 2020, 05:02:26 PM
August 03, 2020, 04:31:04 PM
August 03, 2020, 10:05:59 AM
August 03, 2020, 08:21:26 AM
nielsquake
August 02, 2020, 11:45:38 PM
August 02, 2020, 08:10:47 PM
August 02, 2020, 07:27:33 PM
August 02, 2020, 07:14:17 PM
nielsquake
August 02, 2020, 06:58:34 PM
August 02, 2020, 06:49:59 PM
August 02, 2020, 05:10:12 PM
August 02, 2020, 04:55:14 PM
UB_Serpent
August 02, 2020, 04:20:13 PM
UB_Serpent
August 02, 2020, 04:05:12 PM
post Dual MOT tesla coil
August 02, 2020, 01:07:54 PM
post current limiting to parallel resonance circuit
August 02, 2020, 07:13:54 AM
August 02, 2020, 02:26:11 AM
missoum0514
August 01, 2020, 11:57:24 PM
August 01, 2020, 10:24:21 PM
August 01, 2020, 03:59:43 PM
UB_Serpent
August 01, 2020, 06:22:53 AM
nielsquake
July 31, 2020, 07:32:09 PM
nielsquake
July 31, 2020, 06:15:27 PM
nielsquake
July 31, 2020, 05:38:49 PM
