Author Topic: making a useable induction forge.  (Read 2278 times)
Offline rustedone
Re: making a useable induction forge.
« Reply #20 on: October 21, 2019, 09:56:51 PM »
you can make the caps your self. with aluminum sheets.  the problem is. whatever induction heater circuit i find. people find tons of problem with it. so i thought . why not? and i think if you look for it you can find some solution for effectiveness
Offline rustedone
« Reply #21 on: October 21, 2019, 10:00:06 PM »
and of course maybe if you add one or two more isolation transformer in between to change the voltage and amperage to desired level . it can make things better.
Offline Weston
« Reply #22 on: October 22, 2019, 03:27:46 AM »
I am assuming you found these two webpages?
http://www.loneoceans.com/lo_main/labs_01/inductionheating/index.htm
http://www.powerlabs.org/indheating.htm
Using a spark gap induction heater is going to be a lot more dangerous as you need to insulate the coil to a much higher voltage. Additionally, it's going to be a less efficient and have limited output power. High power high voltage transformers are relatively uncommon and high power spark gaps are a bit tricky to get right and can be expensive.
I would strongly suggest you start with the induction heater kit on ebay. They work well and people on the forum know a lot about them, there is already a 10 page thread about the kit. At $30 it is also going to be a lot cheaper than any other option. Also, unlike the spark gap approach, they use a lower voltage, so it's a significantly reduced electrocution hazard.
Offline rustedone
« Reply #23 on: October 22, 2019, 08:38:14 AM »
eehh?! there is page like that ?! I just thought it myself ... but well. you see man. i need strong one . and need to work with it. it may look dangerous. but if you pick the parts right. then it simply becomes more dangerous to you and less to device. then you can isolated whole thing and control it from safe distance .
but it's not like i just want this. if you have idea for high power induction forge. lets hear it brother .  :)
Offline rustedone
« Reply #24 on: October 22, 2019, 05:56:52 PM »
so in the end i should use the first circuit with some improvements cause it's hard for tesla coil to lock on resonance frequency. then what about capacitor bank value . i doubt it's the bigger the better . or is it ?
Today at 05:06:10 AM
July 11, 2020, 10:23:24 PM
July 11, 2020, 09:36:02 PM
July 11, 2020, 07:36:23 PM
July 11, 2020, 04:45:18 PM
July 11, 2020, 01:26:41 PM
July 11, 2020, 07:53:04 AM
July 11, 2020, 06:37:03 AM
July 11, 2020, 04:18:29 AM
July 11, 2020, 01:35:07 AM
July 10, 2020, 11:35:05 PM
post Re: Capacitors and arcs
Morvandium
July 10, 2020, 11:10:57 PM
Morvandium
July 10, 2020, 11:06:07 PM
k42
July 10, 2020, 08:53:06 PM
July 10, 2020, 07:20:48 PM
Morvandium
July 10, 2020, 04:45:43 PM
July 10, 2020, 10:57:29 AM
July 10, 2020, 08:55:30 AM
July 10, 2020, 08:48:33 AM
July 10, 2020, 07:00:13 AM
July 10, 2020, 06:57:36 AM
July 10, 2020, 05:44:54 AM
July 09, 2020, 09:23:38 PM
July 09, 2020, 09:09:08 PM
July 09, 2020, 07:00:49 PM
July 09, 2020, 02:33:38 PM
July 09, 2020, 12:16:32 PM
July 09, 2020, 11:46:10 AM
July 09, 2020, 10:56:18 AM
July 09, 2020, 08:37:52 AM
July 09, 2020, 06:45:18 AM
July 09, 2020, 02:36:22 AM
July 08, 2020, 09:43:20 PM
Morvandium
July 08, 2020, 09:33:35 PM
July 08, 2020, 09:23:14 PM
July 08, 2020, 09:16:42 PM
July 08, 2020, 09:00:04 PM
July 08, 2020, 04:25:53 PM
July 08, 2020, 10:03:25 AM
July 08, 2020, 08:39:10 AM
July 08, 2020, 08:34:02 AM
July 08, 2020, 04:39:10 AM
post Measuring LED efficiency
July 08, 2020, 12:46:23 AM
July 07, 2020, 10:28:37 PM
July 07, 2020, 10:09:22 PM
July 07, 2020, 09:36:53 PM
July 07, 2020, 09:20:12 PM
July 07, 2020, 09:07:10 PM
July 06, 2020, 10:29:17 PM
July 06, 2020, 06:53:26 PM
