Author Topic: safty gap resisitor  (Read 137 times)
Offline thedoc298
safty gap resisitor
« on: October 10, 2019, 06:54:46 PM »
I was reading back a few months and someone mentioned,"don't forget your safty gap resisitor, few ohms would be good". This would be so your cap is not doing a direct short which make sence. I am going to use a 100watt 4 ohm. The question is are you guys out their doing this and what value are you using. Thanks
Re: safty gap resisitor
« Reply #1 on: October 10, 2019, 08:38:04 PM »
The purpose of the safety gap is to protect the transformer, not the capacitor. If the capacitor is suitably rated in voltage (at least 2.5x) that should be protection enough for it.
Since the safety gap is there to protect the transformer, the safety gap should be connected in parallel with the normal spark gap. Because of this there is no need for a resistor because the discharge is still into the tesla primary coil which will oscillate with the capacitor as with the normal firing.
I have seen a circuit with the safety gap in series with a resistor connected across the capacitor but this makes no sense to me unless it is an attempt to protect an under-rated capacitor.
My safety gap is connected in parallel with my SRSG as with all other RSGTCs I have seen.
« Last Edit: October 10, 2019, 09:28:51 PM by MRMILSTAR »
Offline thedoc298
« Reply #2 on: October 11, 2019, 01:09:18 AM »
[/quote
yea I just looked again and when the safty fires it is not dead shorting the cap which is what I thought. The primary is in series with it with the cap so no short.
When I looked at my papers I kept seeing the safty across the cap dead shorting when it would fire, but it was across the main spark gap. Anyway all is well and you fixed a problem that did not exist. Cant believe how my eyes were playing tricks. The whole problem is i drew the cap and the safty gap the same.
She is about ready to fire, just got to put the terry filter stuff in, kind of forgot that stuff, so a little backtracking. Thanks again I feel better now.
post Re: CW multiplier resistor string suggestions
Today at 09:57:51 PM
Today at 05:28:09 PM
post Aethra CCD Webcam Teardown - From Back When Streaming Was Expensive!
Today at 01:33:30 PM
post Platter resistance & inductance
Today at 11:41:00 AM
Today at 06:50:11 AM
Today at 12:00:00 AM
post CW multiplier resistor string suggestions
December 07, 2019, 11:32:49 PM
December 07, 2019, 09:54:31 PM
jturnerkc
December 07, 2019, 09:48:21 PM
December 07, 2019, 08:59:57 PM
post Re: Cost reduction in consumer electrics
December 06, 2019, 08:35:29 PM
post Re: Full bridge showing half the voltage
December 06, 2019, 05:19:26 AM
December 06, 2019, 03:48:34 AM
the_anomaly
December 06, 2019, 03:35:39 AM
December 06, 2019, 01:27:03 AM
December 05, 2019, 11:38:59 PM
December 05, 2019, 07:33:01 PM
sjsimmo
December 05, 2019, 11:09:20 AM
post Cost reduction in consumer electrics
December 05, 2019, 07:25:20 AM
post Re: HV resistor in oil
December 05, 2019, 05:52:11 AM
December 05, 2019, 05:21:07 AM
December 04, 2019, 06:05:11 PM
December 04, 2019, 02:57:02 PM
December 04, 2019, 12:40:51 PM
December 04, 2019, 11:20:25 AM
December 04, 2019, 08:28:15 AM
December 04, 2019, 07:41:21 AM
December 04, 2019, 05:15:49 AM
December 04, 2019, 05:06:39 AM
December 04, 2019, 04:31:16 AM
December 04, 2019, 04:26:38 AM
December 04, 2019, 04:10:16 AM
December 04, 2019, 12:28:15 AM
December 04, 2019, 12:11:32 AM
December 03, 2019, 07:58:41 PM
post Re: Driving Nixie-tubes with arduino
December 03, 2019, 07:54:08 PM
December 03, 2019, 07:41:00 PM
December 03, 2019, 02:14:00 PM
December 03, 2019, 01:24:00 PM
December 03, 2019, 10:45:58 AM
post Driving Nixie-tubes with arduino
December 03, 2019, 09:04:42 AM
December 03, 2019, 07:29:48 AM
December 03, 2019, 05:07:28 AM
December 03, 2019, 04:34:46 AM
December 02, 2019, 09:06:07 PM
December 02, 2019, 10:51:33 AM
jturnerkc
December 02, 2019, 05:49:05 AM
December 02, 2019, 04:10:14 AM
December 02, 2019, 04:09:37 AM
December 02, 2019, 03:42:16 AM
