Author Topic: Power supply for gas discharge tubes  (Read 672 times)
« on: September 29, 2019, 05:44:12 AM »
I bought several gas discharge tubes at a swap meet recently. They contain various gases such as krypton, helium, argon, and nitrogen. Each tube is made of glass and is about 12 inches long and 0.5 inch wide. There are leads protruding from each end. What is the best way to power these tubes to get good brightness without burning them out? What is a good voltage and current? I have on hand a NST and MOTs. I also have a variac to control the voltage if necessary. I also have various tesla coils but I wanted a power source independent of those.
« Last Edit: September 29, 2019, 05:16:57 PM by MRMILSTAR »
Re: Power supply for gas discharge tubes
« Reply #1 on: September 29, 2019, 08:57:03 AM »
Ooh, colors!  Do you have any sort of spectrometer, perhaps just a simple prism or diffraction grating?
If they're cold cathode tubes, you can't go wrong with a NST on a variac.  Operating current is determined by the variac setting. If the tubes came as a set, they're probably all OK with the same current, and could be connected in series and lit all together.  For a more compact power supply, I bet an inverter for driving CCFL lamp, such as those in laptop computer displays, would work
The advice would be different (and speculative) if there's a coiled tungsten filament at each tube end, like those in compact fluorescent lamps.  Even if not designed for electrical preheating, I think that kind of cathode wants enough arc current to keep it sort of hot.
« Last Edit: September 29, 2019, 09:10:33 AM by klugesmith »
« Reply #2 on: September 29, 2019, 05:27:23 PM »
I looked at the tubes. I see no filament so I assume that they are cold cathode tubes. I bought them as part of a set. Would it be better to connect them in series or in parallel?
I wonder if those E-Bay tubes you show use different gases to achieve the colors or just a filter.
I need to get a prism.
« Last Edit: September 29, 2019, 11:52:34 PM by MRMILSTAR »
Offline Twospoons
« Reply #3 on: September 29, 2019, 11:31:46 PM »
Series, definitely.  In parallel  the first one to strike will prevent the others from lighting up.
« Reply #4 on: September 30, 2019, 04:58:49 AM »
A bit of poking on EBay suggests they are indeed CCFLs, so based on mercury arc with phosphor coating on the inside of the glass, likely designed for 5mA.  The easiest is probably to buy some cheap CCFL drivers.  There are plenty available with 4 outputs for relatively little cost:
    https://www.ebay.com/itm/Inverter-Ballast-for-CCFL-Angel-Eyes-Halo-Rings-Kit-4-outputs-12V-Male-900V/362211813813?hash=item545581a9b5:g:SVgAAOSwM~taWS2F
    https://www.ebay.com/itm/Spare-Inverter-Ballast-for-CCFL-BMW-Angel-Eyes-Halo-Rings-Kit-4-outputs-Female/264317522214?hash=item3d8a8d5126:g:BFoAAOSwt~1c1bcS
for a couple examples.  There are bare boards for laptops and TVs available too
post Re: Linear Guide and Ball Screw
HiVi
Today at 11:53:55 AM
post Vacuum capacitor circuit advice
Martin hughes
Today at 11:03:13 AM
Nijin
Today at 10:20:31 AM
post SSTC DRIVER WITH NON FUNCTIONAL ENABLE PIN FOLLOWUP
prabhatkumar
Today at 10:10:59 AM
Today at 01:01:27 AM
k42
June 05, 2020, 06:18:16 PM
post Re: Ericsson Tower Mounted Amplifer Teardown and measurement
June 05, 2020, 06:08:18 PM
post Re: Any good suggestions for our QCW "sword arc" mechanism research?
k42
June 05, 2020, 06:00:25 PM
post Nokia Siemens Flexi 3x70W FXEA 1800MHz Base Station Teardown
June 05, 2020, 11:17:05 AM
HiVi
June 05, 2020, 10:02:02 AM
June 05, 2020, 12:54:06 AM
June 04, 2020, 08:14:58 AM
[Radioactive Sources]
June 04, 2020, 06:30:09 AM
post Re: Datasheet Question
June 03, 2020, 08:01:53 PM
June 03, 2020, 03:04:11 PM
June 03, 2020, 02:54:04 PM
June 03, 2020, 02:27:26 PM
June 03, 2020, 02:19:32 PM
June 03, 2020, 02:10:57 PM
arctichominid
June 03, 2020, 02:10:18 PM
June 03, 2020, 12:27:06 PM
post Datasheet Question
June 03, 2020, 08:10:27 AM
June 03, 2020, 07:57:48 AM
June 03, 2020, 07:01:44 AM
June 03, 2020, 01:01:25 AM
June 03, 2020, 12:50:28 AM
June 03, 2020, 12:35:11 AM
09d08
June 03, 2020, 12:22:31 AM
June 02, 2020, 09:25:51 PM
09d08
June 02, 2020, 03:58:49 PM
June 02, 2020, 06:50:52 AM
TheMaxii2007
June 02, 2020, 05:52:14 AM
June 02, 2020, 04:53:24 AM
TheMaxii2007
June 02, 2020, 04:19:02 AM
post Re: Neon transformer
June 01, 2020, 11:55:28 PM
June 01, 2020, 08:34:10 PM
June 01, 2020, 07:58:20 PM
June 01, 2020, 05:50:47 PM
June 01, 2020, 05:27:08 PM
post Neon transformer
Iyacht
June 01, 2020, 10:02:58 AM
June 01, 2020, 03:38:05 AM
June 01, 2020, 03:07:36 AM
May 31, 2020, 11:59:47 PM
erlendse
May 31, 2020, 11:05:19 PM
May 31, 2020, 11:03:45 PM
boxermick
May 31, 2020, 09:25:36 PM
May 31, 2020, 09:25:26 PM
May 31, 2020, 09:19:32 PM
May 31, 2020, 09:12:09 PM
May 31, 2020, 09:10:39 PM
