Author Topic: Transistors good for DRSSTC?  (Read 738 times)
Offline ritaismyconscience
« on: September 12, 2019, 05:53:51 AM »
So I found a good deal for these transistors:
https://www.mouser.com/datasheet/2/240/ixys_ds99525cixgq24n30pbix5187-1547450.pdf
The main problem I see with using this in a Tesla coil is that it's only rated for 300V. However, it can handle quite a bit of current. Is there anything I should be aware of before buying?
Re: Transistors good for DRSSTC?
« Reply #1 on: September 12, 2019, 08:44:48 AM »
The low voltage rating would be rather limiting, but the other issue I can see is the lack of an anti parallel diode, which is necessary for drsstc use. In theory an external diode could be used, but it's not worth the hassle when good IGBTs are available with them already integrated.
On another note, does anyone know what these parts are actually intended for (datasheet says "For PDP Applications")? The 300V limit is unusually low for an igbt!
Edit: PDP of course means plasma display panel, never mind my question!
« Last Edit: September 12, 2019, 08:46:46 AM by Hydron »
« Reply #2 on: September 12, 2019, 11:07:39 AM »
While they do look interesting to use in 120VAC countries there seems to be more cons than pros, simply due to the IGBTs getting destroyed from heat.
The 500Apeak rating is only specified for 10uS pulses
The legs are derated to a mere 75A
It is worth looking into paralleling these, obvious nice looking specs are gate charge, switching speed and Vce(sat)
I would worry the most about the Fmax2 calculation due to thermal limitations on this part, guide to calculate Fmax2: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/igbts/
« Reply #3 on: September 12, 2019, 12:47:03 PM »
Remember that these 75A are Arms. With 10% duty this equals around 580Apk (Source) - should be enough. Maybe for a 120V table top DRSSTC they work?
« Reply #4 on: September 13, 2019, 05:50:53 AM »
I can also get these:
https://www.infineon.com/dgdl/Infineon-IKW75N60T-DS-v02_08-en.pdf?fileId=db3a304412b407950112b42890113e25
for about a third of the price. Seems like a better idea?
Today at 03:55:56 PM
Today at 10:25:50 AM
post Re: SSTC Micro
Today at 04:59:02 AM
Today at 04:32:26 AM
post Re: SSTC Micro
Rowdy
Today at 04:12:23 AM
Rowdy
Today at 03:41:17 AM
Rowdy
Today at 03:40:25 AM
post Re: SSTC Micro
jockoFergy
Today at 02:42:23 AM
May 27, 2020, 06:21:39 PM
fnordest
May 27, 2020, 12:11:06 PM
May 27, 2020, 11:51:19 AM
May 26, 2020, 07:55:03 PM
May 26, 2020, 07:40:48 PM
iraquois
May 26, 2020, 05:12:42 PM
May 26, 2020, 03:57:04 PM
May 26, 2020, 01:52:26 PM
May 26, 2020, 11:52:33 AM
May 26, 2020, 09:40:52 AM
May 26, 2020, 08:56:01 AM
May 26, 2020, 08:45:40 AM
May 26, 2020, 08:27:58 AM
May 26, 2020, 06:31:59 AM
May 26, 2020, 05:24:41 AM
May 26, 2020, 02:01:33 AM
iraquois
May 26, 2020, 01:12:46 AM
May 26, 2020, 12:37:32 AM
May 25, 2020, 10:35:49 PM
May 25, 2020, 09:30:41 PM
May 25, 2020, 08:17:18 PM
iraquois
May 25, 2020, 07:43:30 PM
May 25, 2020, 03:32:54 PM
May 25, 2020, 12:52:38 PM
May 25, 2020, 10:34:56 AM
kilohercas
May 25, 2020, 06:38:15 AM
May 25, 2020, 03:24:49 AM
post Re: SSTC Micro
May 25, 2020, 03:24:20 AM
Rowdy
May 25, 2020, 03:23:33 AM
May 25, 2020, 03:06:20 AM
May 25, 2020, 01:33:47 AM
post MMC for a 32kvac load
Rowdy
May 25, 2020, 01:02:34 AM
Rowdy
May 24, 2020, 11:47:26 PM
post Re: GDT cable specs
May 24, 2020, 11:09:44 PM
Rowdy
May 24, 2020, 10:39:45 PM
station240
May 24, 2020, 09:55:49 PM
May 24, 2020, 09:55:48 PM
May 24, 2020, 08:16:40 PM
thecyberman
May 24, 2020, 05:38:27 PM
Rowdy
May 24, 2020, 02:33:55 PM
hip424
May 24, 2020, 02:31:39 PM
iraquois
May 24, 2020, 02:08:53 PM
