Author Topic: Transistors good for DRSSTC?  (Read 210 times)
Offline ritaismyconscience
« on: September 12, 2019, 05:53:51 AM »
So I found a good deal for these transistors:
https://www.mouser.com/datasheet/2/240/ixys_ds99525cixgq24n30pbix5187-1547450.pdf
The main problem I see with using this in a Tesla coil is that it's only rated for 300V. However, it can handle quite a bit of current. Is there anything I should be aware of before buying?
Re: Transistors good for DRSSTC?
« Reply #1 on: September 12, 2019, 08:44:48 AM »
The low voltage rating would be rather limiting, but the other issue I can see is the lack of an anti parallel diode, which is necessary for drsstc use. In theory an external diode could be used, but it's not worth the hassle when good IGBTs are available with them already integrated.
On another note, does anyone know what these parts are actually intended for (datasheet says "For PDP Applications")? The 300V limit is unusually low for an igbt!
Edit: PDP of course means plasma display panel, never mind my question!
« Last Edit: September 12, 2019, 08:46:46 AM by Hydron »
« Reply #2 on: September 12, 2019, 11:07:39 AM »
While they do look interesting to use in 120VAC countries there seems to be more cons than pros, simply due to the IGBTs getting destroyed from heat.
The 500Apeak rating is only specified for 10uS pulses
The legs are derated to a mere 75A
It is worth looking into paralleling these, obvious nice looking specs are gate charge, switching speed and Vce(sat)
I would worry the most about the Fmax2 calculation due to thermal limitations on this part, guide to calculate Fmax2: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/igbts/
Offline Max
« Reply #3 on: September 12, 2019, 12:47:03 PM »
Remember that these 75A are Arms. With 10% duty this equals around 580Apk (Source) - should be enough. Maybe for a 120V table top DRSSTC they work?
« Reply #4 on: September 13, 2019, 05:50:53 AM »
I can also get these:
https://www.infineon.com/dgdl/Infineon-IKW75N60T-DS-v02_08-en.pdf?fileId=db3a304412b407950112b42890113e25
for about a third of the price. Seems like a better idea?
Today at 07:37:55 AM
Today at 06:43:39 AM
Today at 01:45:37 AM
post Re: Breakout rod material and size vs streamer resuls
Today at 12:18:00 AM
post Re: My DRSSTC does not want to resonate at correct frequency
September 22, 2019, 10:16:26 PM
September 22, 2019, 05:40:52 PM
September 22, 2019, 06:43:46 AM
September 22, 2019, 12:36:23 AM
September 22, 2019, 12:03:43 AM
post My DRSSTC does not want to resonate at correct frequency
September 21, 2019, 09:01:48 PM
post Re: The new toy
[Laboratories ]
September 21, 2019, 05:54:03 PM
[Laboratories ]
September 21, 2019, 05:38:14 PM
[Laboratories ]
September 21, 2019, 04:55:44 PM
[Laboratories ]
September 21, 2019, 04:03:48 PM
[Laboratories ]
September 21, 2019, 03:57:22 PM
[Laboratories ]
September 21, 2019, 09:15:47 AM
[Laboratories ]
September 21, 2019, 09:11:18 AM
[Laboratories ]
AlexanderHun
September 21, 2019, 09:08:50 AM
[Laboratories ]
AlexanderHun
September 21, 2019, 08:59:41 AM
post Re: Blast from the past!
September 20, 2019, 11:32:35 PM
post Re: Help choosing a Hantek USB oscilloscope
September 20, 2019, 11:28:05 PM
[Laboratories ]
September 20, 2019, 11:20:21 PM
post Re: CM300 coil build questions
September 20, 2019, 11:10:54 PM
[Laboratories ]
AlexanderHun
September 20, 2019, 09:49:00 PM
[Laboratories ]
September 20, 2019, 08:17:36 PM
September 20, 2019, 08:06:32 PM
September 20, 2019, 05:43:13 PM
September 20, 2019, 01:32:30 PM
post Re: Adventures in induction heating
Coyote
September 20, 2019, 10:56:19 AM
September 20, 2019, 10:02:28 AM
September 20, 2019, 07:05:19 AM
September 19, 2019, 11:16:21 PM
[Laboratories ]
AlexanderHun
September 19, 2019, 09:49:30 PM
September 19, 2019, 09:49:15 PM
[Laboratories ]
September 19, 2019, 09:13:29 PM
September 19, 2019, 09:08:20 PM
September 19, 2019, 07:16:20 PM
post Help choosing a Hantek USB oscilloscope
September 19, 2019, 04:19:58 PM
post The new toy
[Laboratories ]
AlexanderHun
September 19, 2019, 09:01:46 AM
September 18, 2019, 07:27:46 PM
September 18, 2019, 06:56:20 PM
September 18, 2019, 05:08:06 PM
September 18, 2019, 01:35:58 PM
September 18, 2019, 05:54:23 AM
September 18, 2019, 05:05:55 AM
post Re: UD2.7 Gate Signals
coilinator
September 17, 2019, 08:24:59 PM
September 17, 2019, 08:19:45 PM
September 17, 2019, 06:53:52 PM
post Blast from the past!
September 17, 2019, 05:52:00 PM
September 17, 2019, 05:00:47 PM
