Author Topic: Transistors good for DRSSTC?  (Read 392 times)
Offline ritaismyconscience
« on: September 12, 2019, 05:53:51 AM »
So I found a good deal for these transistors:
https://www.mouser.com/datasheet/2/240/ixys_ds99525cixgq24n30pbix5187-1547450.pdf
The main problem I see with using this in a Tesla coil is that it's only rated for 300V. However, it can handle quite a bit of current. Is there anything I should be aware of before buying?
Re: Transistors good for DRSSTC?
« Reply #1 on: September 12, 2019, 08:44:48 AM »
The low voltage rating would be rather limiting, but the other issue I can see is the lack of an anti parallel diode, which is necessary for drsstc use. In theory an external diode could be used, but it's not worth the hassle when good IGBTs are available with them already integrated.
On another note, does anyone know what these parts are actually intended for (datasheet says "For PDP Applications")? The 300V limit is unusually low for an igbt!
Edit: PDP of course means plasma display panel, never mind my question!
« Last Edit: September 12, 2019, 08:46:46 AM by Hydron »
« Reply #2 on: September 12, 2019, 11:07:39 AM »
While they do look interesting to use in 120VAC countries there seems to be more cons than pros, simply due to the IGBTs getting destroyed from heat.
The 500Apeak rating is only specified for 10uS pulses
The legs are derated to a mere 75A
It is worth looking into paralleling these, obvious nice looking specs are gate charge, switching speed and Vce(sat)
I would worry the most about the Fmax2 calculation due to thermal limitations on this part, guide to calculate Fmax2: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/igbts/
« Reply #3 on: September 12, 2019, 12:47:03 PM »
Remember that these 75A are Arms. With 10% duty this equals around 580Apk (Source) - should be enough. Maybe for a 120V table top DRSSTC they work?
« Reply #4 on: September 13, 2019, 05:50:53 AM »
I can also get these:
https://www.infineon.com/dgdl/Infineon-IKW75N60T-DS-v02_08-en.pdf?fileId=db3a304412b407950112b42890113e25
for about a third of the price. Seems like a better idea?
post Re: Cost reduction in consumer electrics
Today at 07:33:01 PM
sjsimmo
Today at 11:09:20 AM
post Cost reduction in consumer electrics
Today at 07:25:20 AM
post Re: HV resistor in oil
Today at 05:52:11 AM
Today at 05:21:07 AM
December 04, 2019, 06:05:11 PM
post Re: Full bridge showing half the voltage
December 04, 2019, 02:57:02 PM
December 04, 2019, 12:40:51 PM
December 04, 2019, 11:20:25 AM
December 04, 2019, 08:28:15 AM
December 04, 2019, 07:41:21 AM
December 04, 2019, 05:15:49 AM
December 04, 2019, 05:06:39 AM
December 04, 2019, 04:31:16 AM
December 04, 2019, 04:26:38 AM
December 04, 2019, 04:10:16 AM
December 04, 2019, 12:28:15 AM
December 04, 2019, 12:11:32 AM
December 03, 2019, 07:58:41 PM
post Re: Driving Nixie-tubes with arduino
December 03, 2019, 07:54:08 PM
December 03, 2019, 07:41:00 PM
December 03, 2019, 02:14:00 PM
December 03, 2019, 01:24:00 PM
December 03, 2019, 10:45:58 AM
post Driving Nixie-tubes with arduino
December 03, 2019, 09:04:42 AM
December 03, 2019, 07:29:48 AM
December 03, 2019, 05:07:28 AM
December 03, 2019, 04:34:46 AM
December 02, 2019, 09:06:07 PM
December 02, 2019, 10:51:33 AM
jturnerkc
December 02, 2019, 05:49:05 AM
December 02, 2019, 04:10:14 AM
December 02, 2019, 04:09:37 AM
December 02, 2019, 03:42:16 AM
December 01, 2019, 10:47:18 PM
December 01, 2019, 09:17:38 PM
post HV resistor in oil
December 01, 2019, 08:51:31 PM
jturnerkc
December 01, 2019, 07:32:44 PM
post Re: Corona on the.... GDT??
December 01, 2019, 12:14:57 PM
post Re: SSTC low voltage at gate transformer and heating drivers
December 01, 2019, 04:30:10 AM
December 01, 2019, 02:56:39 AM
post Re: New to tesla coils, some questions before I start building a SSTC
Blin
November 30, 2019, 10:28:56 PM
jturnerkc
November 30, 2019, 09:41:17 PM
post Re: QCW ramp generator
November 30, 2019, 06:12:28 PM
November 30, 2019, 04:28:34 PM
November 30, 2019, 02:26:53 PM
November 30, 2019, 12:45:22 PM
post Re: Suggestions for CW HV feed-through
November 30, 2019, 06:45:09 AM
post Full bridge showing half the voltage
November 30, 2019, 06:42:20 AM
November 30, 2019, 05:24:50 AM
