Author Topic: Drsstc 4, I'm never stopping  (Read 102 times)
« on: September 12, 2019, 02:36:00 AM »
With my 3rd drsstc coming to and end and the days getting longer it's time to build another indoor coil! Ever since I sold my first drsstc (a copy of mads drsstc ii) I always regretted it, i may rebuild it one day but for now I'm going to build something around the size of it.
Specs so far:
Secondary: 83mm diameter with a winding length of 220mm with about 1450t of 0.14mm wire (I'm assuming less turns because nothing is ever perfect). I'm estimating it will be about 180khz with a top load.
Bridge: I'm thinking about a dual full bridge of GP50B60 igbts. I've been working on a PCB that seems stable so this will be a test for it.
Driver: profdc9 tht ud2.7c. Dan if you're reading this I once again thank you. If it wasn't for you my builds couldn't happen, you've done outstanding work for the community.
Things I'm not sure of: I'm probably going to go way overkill with the mmc, bus capacitors will be ones I scrapped for solar inverters, unsure of primary form and am going to try smaller epocs n30 cores for the feedback and current CTS.
I'm hoping out of this I can improve my dual full-bridge board and be comfortable to release the design.
The only pic so far, I wish I got some better photos of when I was winding it. So far it has 3 coats of polyurethane, I'll apply another 3-4 coats and start sanding to get a smooth finish with a final coat to hopefully get a glass like finish.
« Last Edit: September 12, 2019, 02:44:35 AM by oneKone »
Phoenix
Today at 07:37:55 AM
post Re: Large Ferrite Core with IGBT-Brick Driver
[Transformer (ferrite core)]
Phoenix
Today at 06:43:39 AM
Today at 01:45:37 AM
post Re: Breakout rod material and size vs streamer resuls
Today at 12:18:00 AM
post Re: My DRSSTC does not want to resonate at correct frequency
September 22, 2019, 10:16:26 PM
September 22, 2019, 05:40:52 PM
September 22, 2019, 06:43:46 AM
September 22, 2019, 12:36:23 AM
September 22, 2019, 12:03:43 AM
post My DRSSTC does not want to resonate at correct frequency
September 21, 2019, 09:01:48 PM
post Re: The new toy
[Laboratories ]
DashApple
September 21, 2019, 05:54:03 PM
[Laboratories ]
September 21, 2019, 05:38:14 PM
[Laboratories ]
DashApple
September 21, 2019, 04:55:44 PM
[Laboratories ]
September 21, 2019, 04:03:48 PM
[Laboratories ]
September 21, 2019, 03:57:22 PM
[Laboratories ]
September 21, 2019, 09:15:47 AM
[Laboratories ]
September 21, 2019, 09:11:18 AM
[Laboratories ]
September 21, 2019, 09:08:50 AM
[Laboratories ]
September 21, 2019, 08:59:41 AM
post Re: Blast from the past!
September 20, 2019, 11:32:35 PM
post Re: Help choosing a Hantek USB oscilloscope
September 20, 2019, 11:28:05 PM
[Laboratories ]
September 20, 2019, 11:20:21 PM
post Re: CM300 coil build questions
September 20, 2019, 11:10:54 PM
[Laboratories ]
September 20, 2019, 09:49:00 PM
[Laboratories ]
DashApple
September 20, 2019, 08:17:36 PM
September 20, 2019, 08:06:32 PM
September 20, 2019, 05:43:13 PM
September 20, 2019, 01:32:30 PM
post Re: Adventures in induction heating
[Electronic circuits]
Coyote
September 20, 2019, 10:56:19 AM
September 20, 2019, 10:02:28 AM
September 20, 2019, 07:05:19 AM
September 19, 2019, 11:16:21 PM
[Laboratories ]
September 19, 2019, 09:49:30 PM
September 19, 2019, 09:49:15 PM
[Laboratories ]
September 19, 2019, 09:13:29 PM
September 19, 2019, 09:08:20 PM
September 19, 2019, 07:16:20 PM
post Help choosing a Hantek USB oscilloscope
September 19, 2019, 04:19:58 PM
post The new toy
[Laboratories ]
September 19, 2019, 09:01:46 AM
September 18, 2019, 07:27:46 PM
September 18, 2019, 06:56:20 PM
September 18, 2019, 05:08:06 PM
September 18, 2019, 01:35:58 PM
September 18, 2019, 05:54:23 AM
September 18, 2019, 05:05:55 AM
post Re: UD2.7 Gate Signals
coilinator
September 17, 2019, 08:24:59 PM
September 17, 2019, 08:19:45 PM
September 17, 2019, 06:53:52 PM
post Blast from the past!
September 17, 2019, 05:52:00 PM
September 17, 2019, 05:00:47 PM
