Author Topic: Suitable capacitors and switches? 10kV  (Read 1639 times)
Offline MrFox
« on: August 16, 2019, 12:21:36 PM »
Hey all
Newbie here so if it's a stupid question please say...
I have been asked to build a device for testing materials for resistance against static electric discharge. The spec says 10kV and 4 Joules.
So 10kV and 100nF looks about the right region.
Questions:
1) What sort of caps can I use for this? Or specifically, can I run 10x 1uF 1000V in series? With balancing resistors?
2) Whats the best way to switch the impulse from the cap to the test area? I was asked to look at Hydrogen Thyrotrons but surely there's a better way? Series IGBTs? HV relays? (2A current limit?)
3) 10kV power supply - one of those neon transformers? A £400 DC-DC module? Build my own multiplier?
Thanks in advance!
Fox
Offline ElectroXa
Re: Suitable capacitors and switches? 10kV
« Reply #1 on: August 16, 2019, 09:17:04 PM »
Hello!
Stupid question does not exist,
1) the best capacitors for this application is pulse film capacitor, as they can handle high pulse current ;
2) I would use a HV relay because current can't leak, and it is simple of operation (only a coil to actuate)
3) For the power supply, I suggest using a small HV transformer, and hook the output to a voltage multiplier.
Hope this helps  :)
« Reply #2 on: August 16, 2019, 09:28:35 PM »
Does the spec give rise time and pulse width?  Does it conform to, or resemble, any existing standards e.g. IEC 61000-4-5?
Just dumping a capacitor, without any impedance controlling the waveform, is likely to give extremely destructive results!
You may also need a coupling network so as to apply it to active e.g. mains connections properly.
Calling it ESD sounds very peculiar; only surge has energy levels like this.  ESD as such is in the 10s mJ range (typically capacitors of 300 to 1500pF).
Offline MrFox
« Reply #3 on: August 21, 2019, 10:51:21 AM »
The standard is similar (apparently) to:
EN 13938-2 Part 2: Determination of resistance to electrostatic energy.
STANAG 4490: Electrostatic Discharge Sensitivity Tests
MIL-STD-1751A Safety and Performance Tests for the Qualification of Explosives - Methods 1031, 1032 & 1033.
But I am struggling to find the rise and fall times or impulse duration.
Any further ideas? Thx
« Reply #4 on: August 22, 2019, 09:38:27 PM »
I am not familiar with that standards and are not going to read them through for you.
But if you are struggling with rise/fall time and impulse duration, look into the design of heart-stoppers (defibrillators), this must be thoroughly documented which capacitance, impedance and output choke to form the desired pulse waveform and length.
Offline shrad
« Reply #5 on: September 04, 2019, 12:44:21 PM »
You can also document on blumlein lines and pulse forming networks
Today at 05:38:29 PM
kreasteve
Today at 02:56:13 AM
June 19, 2021, 05:30:28 PM
June 18, 2021, 07:48:01 PM
June 18, 2021, 02:48:57 AM
June 18, 2021, 01:22:10 AM
June 18, 2021, 01:21:53 AM
June 17, 2021, 08:27:10 PM
June 17, 2021, 08:23:57 PM
June 17, 2021, 02:51:45 PM
June 17, 2021, 02:01:23 PM
post LCR meter recommendation
the_anomaly
June 17, 2021, 01:58:48 PM
June 17, 2021, 12:42:03 PM
June 17, 2021, 02:49:00 AM
June 16, 2021, 08:54:32 PM
June 16, 2021, 08:00:50 PM
June 16, 2021, 05:40:40 PM
post Demo Coil Protection
June 16, 2021, 05:39:14 PM
June 16, 2021, 10:20:30 AM
June 16, 2021, 07:33:15 AM
June 15, 2021, 01:21:38 PM
Rapy2
June 15, 2021, 12:02:58 PM
June 15, 2021, 06:52:56 AM
June 15, 2021, 05:43:07 AM
June 15, 2021, 05:26:34 AM
June 15, 2021, 02:27:03 AM
Rapy2
June 14, 2021, 01:06:02 AM
June 14, 2021, 12:44:31 AM
Rapy2
June 14, 2021, 12:41:33 AM
Rapy2
June 14, 2021, 12:11:13 AM
June 13, 2021, 11:52:11 PM
Rapy2
June 13, 2021, 11:38:44 PM
Rapy2
June 13, 2021, 10:26:51 PM
June 13, 2021, 09:57:56 PM
Rapy2
June 13, 2021, 09:29:08 PM
June 13, 2021, 08:53:25 PM
Rapy2
June 13, 2021, 07:22:05 PM
June 13, 2021, 07:02:28 PM
June 13, 2021, 06:25:20 PM
Rapy2
June 13, 2021, 02:48:59 PM
gianpaolo
June 13, 2021, 12:00:09 PM
June 12, 2021, 07:28:03 PM
June 12, 2021, 07:23:12 PM
June 12, 2021, 12:24:06 PM
post Re: Nice PC Board Tesla
June 12, 2021, 10:06:18 AM
June 12, 2021, 10:01:29 AM
June 12, 2021, 08:47:08 AM
June 12, 2021, 07:03:10 AM
PEDRO HENRIQUE
June 12, 2021, 06:42:56 AM
June 12, 2021, 04:20:53 AM
