Author Topic: Van de Graaf is leaking charge  (Read 668 times)
Offline Patric
« on: August 14, 2019, 09:22:21 AM »
Dear all,
my Van de Graaf had been working flawlessly. I was able to pull 40cm coronal discharges from it.
Here is a long exposure:
The column is made from 160mm diameter PVC pipe.
After half a year of non operation I brought it back to life and I now have some severe problems. When it starts up it nicely charges the top load as usual, but after about 30 secs there is charge leaking from the column. In the dark you can clearly see several jets coming out of the side of the column. The origins of the jets seem to be arranged along a line parallel to the column. I cannot take pictures but here is a sketch:
I already checked in the outside and inside of the column for any contamination or damages. Nothing, all looks smooth. Really scratching my head about this.
The column is a sandwich from PVC and foam. Looks like this:
If anyone has got some ideas, let me know!
Cheers Patric
Offline ElectroXa
Re: Van de Graaf is leaking charge
« Reply #1 on: August 14, 2019, 01:42:21 PM »
Was the Van de graaf stored in a moist place?
Because the foam can retain moisture, so it becomes conductive and thus cause current leaks.
Offline Patric
« Reply #2 on: August 14, 2019, 02:56:49 PM »
No not really, always sat in the workshop which is not humid. (ok, the laundry room is next door...  ???)
I will take it apart and try to dry it, maybe run the hair dryer for some time.
My next VDG is planned to feature a transparent acrylic column. Those shouldnt be prone to take on moisture.
Offline nik282000
« Reply #3 on: October 22, 2019, 04:56:19 PM »
I have had good luck using only a hair dryer to get my leaky VDG running.
After A year or two in the basement it tends to work very poorly if I don't blow it down, both inside and out with a hair dryer for about 10 minutes. It seems to remove any accumulated surface moisture and lets it run even on humid days.
Hope that helps.
Today at 02:25:42 AM
post Re: Seeking to build a 400+kHz IH, ZVS platform, high performance components
July 14, 2020, 11:33:09 PM
post Re: Different styles of HV electrodes
July 14, 2020, 09:48:39 PM
post Different styles of HV electrodes
July 14, 2020, 09:34:39 PM
July 14, 2020, 09:19:11 PM
July 14, 2020, 09:06:21 PM
post Seeking to build a 400+kHz IH, ZVS platform, high performance components
JimOB
July 14, 2020, 05:15:03 PM
July 14, 2020, 07:27:18 AM
post Re: Drsstc tank Cap testing
July 14, 2020, 07:02:44 AM
post Drsstc tank Cap testing
July 14, 2020, 05:56:46 AM
July 14, 2020, 12:03:47 AM
July 13, 2020, 01:08:35 PM
July 13, 2020, 08:30:46 AM
post Re: Capacitors and arcs
Paradox
July 13, 2020, 01:59:09 AM
July 13, 2020, 01:20:59 AM
July 12, 2020, 05:06:10 AM
July 11, 2020, 10:23:24 PM
July 11, 2020, 09:36:02 PM
July 11, 2020, 07:36:23 PM
July 11, 2020, 04:45:18 PM
July 11, 2020, 01:26:41 PM
July 11, 2020, 07:53:04 AM
July 11, 2020, 06:37:03 AM
July 11, 2020, 04:18:29 AM
July 11, 2020, 01:35:07 AM
July 10, 2020, 11:35:05 PM
Morvandium
July 10, 2020, 11:10:57 PM
Morvandium
July 10, 2020, 11:06:07 PM
k42
July 10, 2020, 08:53:06 PM
July 10, 2020, 07:20:48 PM
Morvandium
July 10, 2020, 04:45:43 PM
July 10, 2020, 10:57:29 AM
July 10, 2020, 08:55:30 AM
July 10, 2020, 08:48:33 AM
July 10, 2020, 07:00:13 AM
July 10, 2020, 06:57:36 AM
July 10, 2020, 05:44:54 AM
July 09, 2020, 09:23:38 PM
July 09, 2020, 09:09:08 PM
July 09, 2020, 07:00:49 PM
July 09, 2020, 02:33:38 PM
July 09, 2020, 12:16:32 PM
July 09, 2020, 11:46:10 AM
July 09, 2020, 10:56:18 AM
July 09, 2020, 08:37:52 AM
July 09, 2020, 06:45:18 AM
July 09, 2020, 02:36:22 AM
July 08, 2020, 09:43:20 PM
Morvandium
July 08, 2020, 09:33:35 PM
July 08, 2020, 09:23:14 PM
