Author Topic: 30% power increase  (Read 357 times)
30% power increase
« on: August 06, 2019, 04:35:37 PM »
I recently increased the power of my big SGTC by about 30%, from 4.8 KVA to 6.5 KVA. This was very simple to do on my equipment. All I had to do was increase the air gap on my ballast very slightly. JAVATC predicted a 9-foot maximum streamer length. A neighbor took the attached picture. If I stretch out all of the kinks, the streamer length does indeed measure to about 9 feet. For reference the coil is 75" tall.
This is the maximum power that I can safely use with my current components. My weak link is my variac which is the largest General Radio variac available. It is rated for 240 volts at 25 amps continuous and up to 32 amps with cooling intervals. My current power level draws 27 amps, with PFC, through the variac. This is the maximum that I am comfortable with unless I want to make major modifications (2 ganged variacs and more capacitance).
Re: 30% power increase
« Reply #1 on: August 08, 2019, 08:33:01 AM »
I was never so bold to "stretch" out the spark for spark length measurements  :P
Most variacs are rated for 200-300% operation for very short periods, it will however hum violently, just if you wanted to push things a bit :)
« Reply #2 on: August 08, 2019, 04:18:09 PM »
The GR variacs also have an internal fuse which I believe is rated for 32 amps, so that is another limitation. I could just bypass the fuse since my control cabinet has a 40 amp breaker. However, going higher than 27 amps would be largely pointless without increasing the size of my primary circuit capacitance. With my 45 nF capacitance, JAVATC says that my capacitors are 95% charged at the start of each bang (240 BPS) with 27 amps. I could increase the capacitance to 60 nF since I do have additional Maxwell energy discharge capacitors. I might do that some day but for now, 9-foot streamers satisfy me.
My ultimate limit though are the 40 amp breakers in my distribution panel.
« Last Edit: August 08, 2019, 04:22:59 PM by MRMILSTAR »
AndreiRS
Today at 03:59:49 AM
post How do you keep in contact with forum people...?
AndreiRS
Today at 03:23:31 AM
Today at 12:16:53 AM
December 12, 2019, 08:35:24 PM
post Re: How To Make a Stencil For Spray Paint With Cheap Hand Tools
December 12, 2019, 07:53:35 PM
December 12, 2019, 02:52:58 PM
December 12, 2019, 02:42:19 PM
post Re: Full bridge much "weaker" than half bridge?
nick
December 12, 2019, 11:17:36 AM
December 12, 2019, 04:51:08 AM
December 12, 2019, 04:26:22 AM
AndreiRS
December 12, 2019, 01:21:35 AM
post Re: Using same winding on separate rails?
[Transformer (iron core)]
December 11, 2019, 10:49:04 PM
December 11, 2019, 05:28:46 PM
December 11, 2019, 03:11:42 PM
December 11, 2019, 02:22:10 PM
December 11, 2019, 02:09:19 PM
post Full bridge much "weaker" than half bridge?
nick
December 11, 2019, 01:10:57 PM
post Re: Possible use for large inductor (laminated core)
December 11, 2019, 08:48:36 AM
December 11, 2019, 06:08:48 AM
post Re: SSTC low voltage at gate transformer and heating drivers
December 11, 2019, 05:38:17 AM
December 11, 2019, 05:01:31 AM
December 11, 2019, 01:52:43 AM
December 11, 2019, 01:41:04 AM
post Re: Worlds Weirdest Microwave Oven, From A Weapons Factory - The Husqvarna Cupol
December 11, 2019, 01:37:13 AM
December 11, 2019, 01:19:58 AM
jturnerkc
December 11, 2019, 01:14:32 AM
December 11, 2019, 01:04:08 AM
babass
December 10, 2019, 11:24:50 PM
post Using same winding on separate rails?
December 10, 2019, 10:52:50 PM
December 10, 2019, 03:35:40 PM
post Re: Why did 4HV die??
December 10, 2019, 03:21:07 PM
December 10, 2019, 03:04:28 PM
December 10, 2019, 02:57:45 PM
December 10, 2019, 11:23:48 AM
December 10, 2019, 10:27:54 AM
December 10, 2019, 10:20:17 AM
December 10, 2019, 10:16:32 AM
December 10, 2019, 06:04:28 AM
December 10, 2019, 05:28:54 AM
December 10, 2019, 04:12:29 AM
post Duty cycle when driving a CRT TV flyback transformer
December 09, 2019, 10:52:59 PM
post Replacement guide for Windows Media Center
December 09, 2019, 08:29:16 PM
December 09, 2019, 04:23:33 PM
December 09, 2019, 03:59:02 PM
jturnerkc
December 09, 2019, 03:41:42 PM
post Possible use for large inductor (laminated core)
December 09, 2019, 09:43:11 AM
December 09, 2019, 12:53:57 AM
post Re: CW multiplier resistor string suggestions
December 08, 2019, 09:57:51 PM
December 08, 2019, 05:28:09 PM
post Aethra CCD Webcam Teardown - From Back When Streaming Was Expensive!
December 08, 2019, 01:33:30 PM
