Author Topic: Small Phase change build R600a  (Read 822 times)
Offline DashApple
« on: August 05, 2019, 06:16:35 PM »
Hi All .
This was my first attempt at building a small phase change system and want to share the results
There was no real gain to be made from this on the CPU other than for the building experience : ) .
Specs are -
Secop 30AA 3cc R600a compressor
2.8m 0.8mm Capillary tube .
120mm 13W AC fan and 120x120x50mm condenser .
CPU is a i5 3470 ( around 85 - 90W Load )
The evaporator is a copper plate with 1/4" copper pipe coiled and brazed to it .  Under no load evap is -6C , Low side is 1PSI ( -10C Boiling point on R600a ) , Suction line 6" from compressor is -1 to -2 C so superheat is around 8C under no load .
Loaded 100% the temperatures are -1C to 0C evap and 18C reported by the CPU .
PCB is full coated in varnish on both side around and under the CPU socket , Then filled with silicone grease and lined around it with armaflex insulation ( still need to do some more insulating ) .
Not the best looking but i am happy with the results for a first attempt : ) .
IMG_20190805_132413 by TwirlyWhirly555, on Flickr
Re: Small Phase change build R600a
« Reply #1 on: August 12, 2019, 07:27:23 PM »
Wow, missed this thread before - looks like quite a fun and successful first build! I'd love to have the knowledge and time to build something like this - I remember reading some very interesting threads years ago (on Xtreme systems or something) about people building multi stage phase change systems, so it seems the rabbit hole goes a bit deeper yet.
Offline DashApple
« Reply #2 on: August 15, 2019, 06:23:40 PM »
Thanks : ) , There was a few issues to get through but in the end it turned out well .
Xtreme systems was and still is a very good place to go for phase change , there is a massive section full of builds and info threads , alot of what i learned was from there : ) .
Some of the cascade and auto cascades on there are crazy , I too would love to be able to do that but for now the simple single stage is where i will probably stay .
« Reply #3 on: August 26, 2019, 06:19:05 AM »
Very nice.
Is "Phase change" a buzz word these days, for a way to cool overclocked CPU's?  Does pressurized refrigerant circulate inside heat-sink parts and boil right there?
« Reply #4 on: August 26, 2019, 03:32:48 PM »
Very nice.
Seems to be a buzz word for a vapor compression cycle that is carried out by a refrigerant system: https://www.es.aau.dk/sections-labs/Automation-and-Control/Laboratory+facilities/refrigeration/refrigeration-cycle/
Today at 02:25:42 AM
July 14, 2020, 11:33:09 PM
July 14, 2020, 09:48:39 PM
July 14, 2020, 09:34:39 PM
July 14, 2020, 09:19:11 PM
July 14, 2020, 09:06:21 PM
JimOB
July 14, 2020, 05:15:03 PM
July 14, 2020, 07:27:18 AM
July 14, 2020, 07:02:44 AM
post Drsstc tank Cap testing
July 14, 2020, 05:56:46 AM
July 14, 2020, 12:03:47 AM
station240
July 13, 2020, 01:08:35 PM
July 13, 2020, 08:30:46 AM
post Re: Capacitors and arcs
Paradox
July 13, 2020, 01:59:09 AM
July 13, 2020, 01:20:59 AM
July 12, 2020, 05:06:10 AM
July 11, 2020, 10:23:24 PM
July 11, 2020, 09:36:02 PM
July 11, 2020, 07:36:23 PM
July 11, 2020, 04:45:18 PM
July 11, 2020, 01:26:41 PM
July 11, 2020, 07:53:04 AM
July 11, 2020, 06:37:03 AM
July 11, 2020, 04:18:29 AM
July 11, 2020, 01:35:07 AM
July 10, 2020, 11:35:05 PM
Morvandium
July 10, 2020, 11:10:57 PM
Morvandium
July 10, 2020, 11:06:07 PM
k42
July 10, 2020, 08:53:06 PM
July 10, 2020, 07:20:48 PM
Morvandium
July 10, 2020, 04:45:43 PM
July 10, 2020, 10:57:29 AM
July 10, 2020, 08:55:30 AM
July 10, 2020, 08:48:33 AM
July 10, 2020, 07:00:13 AM
July 10, 2020, 06:57:36 AM
July 10, 2020, 05:44:54 AM
July 09, 2020, 09:23:38 PM
July 09, 2020, 09:09:08 PM
July 09, 2020, 07:00:49 PM
July 09, 2020, 02:33:38 PM
July 09, 2020, 12:16:32 PM
July 09, 2020, 11:46:10 AM
July 09, 2020, 10:56:18 AM
July 09, 2020, 08:37:52 AM
July 09, 2020, 06:45:18 AM
July 09, 2020, 02:36:22 AM
July 08, 2020, 09:43:20 PM
Morvandium
July 08, 2020, 09:33:35 PM
July 08, 2020, 09:23:14 PM
