Author Topic: What is the advantage  (Read 1105 times)
Offline thedoc298
« on: July 28, 2019, 10:23:33 PM »
I see many coils with 2 toroids, one larger and one small. What is the advantage of this. Thanks again.
Online MRMILSTAR
Re: What is the advantage
« Reply #1 on: July 29, 2019, 03:41:48 PM »
There are two reasons. Most of the time, someone is just trying to add more capacitance to the top load without going to the trouble of building a single larger toroid. Another possible reason for adding a smaller toroid below a larger one is to bring the electromagnetic  field closer to the top of the secondary coil to provide protection against streamers being emitted from the top of the secondary coil windings.
« Last Edit: December 14, 2019, 11:45:41 PM by MRMILSTAR »
Offline thedoc298
« Reply #2 on: July 30, 2019, 12:13:47 AM »
That sounds reasonable. Thanks again.
« Reply #3 on: July 30, 2019, 07:40:44 PM »
A third reason is also to raise up the top toroid, to gain more distance between the toroid from where the streamers come out and the primary coil/strike rail/ground, a smaller diameter near the top of the secondary coil will also have a stronger electrical field that helps prevent corona discharge and streamers from the top turn of the secondary coil if there is a too large distance from that and topload.
Offline thedoc298
« Reply #4 on: July 31, 2019, 02:28:41 AM »
Thanks for another good tip, takes long time to fully understand all the in's and out's. Would it be like if at the top of the secondary I had a 10 inch giraffe neck that it would be to my advantage to have a smaller turtle neck below the bigh toroid on top of the 10 inch gap for the reasons you stated. Thanks.
« Last Edit: August 05, 2019, 08:42:45 AM by Mads Barnkob »
Online MRMILSTAR
« Reply #5 on: August 01, 2019, 06:00:24 PM »
Most people with SGTCs just use a single toroid mounted at the proper height to shield the top turns of the secondary from corona or sparks. My 8.6" pig-powered coil just has a single 30" x 9" aluminum toroid with no problem.
Online MRMILSTAR
« Reply #6 on: September 26, 2019, 09:15:36 PM »
JAVATC allows for multiple top loads in the input. You can try your different ideas and see what they do.
post Re: Dual MOT tesla coil
Today at 08:30:38 PM
post Re: Budget USB cameras
missoum0514
Today at 06:56:08 PM
Today at 05:23:15 PM
nielsquake
Today at 05:02:26 PM
Today at 04:31:04 PM
Today at 10:05:59 AM
Today at 08:21:26 AM
nielsquake
August 02, 2020, 11:45:38 PM
August 02, 2020, 08:10:47 PM
August 02, 2020, 07:27:33 PM
August 02, 2020, 07:14:17 PM
nielsquake
August 02, 2020, 06:58:34 PM
August 02, 2020, 06:49:59 PM
August 02, 2020, 05:10:12 PM
August 02, 2020, 04:55:14 PM
UB_Serpent
August 02, 2020, 04:20:13 PM
UB_Serpent
August 02, 2020, 04:05:12 PM
post Dual MOT tesla coil
August 02, 2020, 01:07:54 PM
August 02, 2020, 07:13:54 AM
August 02, 2020, 02:26:11 AM
missoum0514
August 01, 2020, 11:57:24 PM
August 01, 2020, 10:24:21 PM
August 01, 2020, 03:59:43 PM
UB_Serpent
August 01, 2020, 06:22:53 AM
nielsquake
July 31, 2020, 07:32:09 PM
nielsquake
July 31, 2020, 06:15:27 PM
nielsquake
July 31, 2020, 05:38:49 PM
July 31, 2020, 04:35:43 PM
July 31, 2020, 02:33:48 PM
post Re: IGBT Selection
July 31, 2020, 01:47:51 PM
July 31, 2020, 10:51:47 AM
July 31, 2020, 06:37:20 AM
UB_Serpent
July 31, 2020, 04:11:14 AM
nielsquake
July 31, 2020, 02:33:30 AM
Halfcorp
July 31, 2020, 01:29:05 AM
nielsquake
July 31, 2020, 12:38:28 AM
July 31, 2020, 12:13:43 AM
July 30, 2020, 09:51:25 PM
nielsquake
July 30, 2020, 09:50:16 PM
post How much is the voltage used in Corona Discharge tubes for ozone Generation?
UB_Serpent
July 30, 2020, 02:05:39 PM
July 30, 2020, 03:14:53 AM
July 29, 2020, 10:00:44 PM
July 29, 2020, 06:09:14 PM
July 29, 2020, 12:52:24 PM
July 29, 2020, 08:32:00 AM
July 29, 2020, 05:23:35 AM
July 29, 2020, 04:34:02 AM
post IGBT Selection
Halfcorp
July 29, 2020, 01:56:26 AM
post Re: my 4" coil turned to a 6" at 68"+ arcs
Bradselph
July 28, 2020, 10:33:09 PM
Halfcorp
July 28, 2020, 01:14:38 PM
