Author Topic: What is the advantage  (Read 643 times)
Offline thedoc298
« on: July 28, 2019, 10:23:33 PM »
I see many coils with 2 toroids, one larger and one small. What is the advantage of this. Thanks again.
Re: What is the advantage
« Reply #1 on: July 29, 2019, 03:41:48 PM »
There are two reasons. Most of the time, someone is just trying to add more capacitance to the top load without going to the trouble of building a single larger toroid. Another possible reason for adding a smaller toroid below a larger one is to bring the electromagnetic  field closer to the top of the secondary coil to provide protection against streamers being emitted from the top of the secondary coil windings.
« Last Edit: December 14, 2019, 11:45:41 PM by MRMILSTAR »
Offline thedoc298
« Reply #2 on: July 30, 2019, 12:13:47 AM »
That sounds reasonable. Thanks again.
« Reply #3 on: July 30, 2019, 07:40:44 PM »
A third reason is also to raise up the top toroid, to gain more distance between the toroid from where the streamers come out and the primary coil/strike rail/ground, a smaller diameter near the top of the secondary coil will also have a stronger electrical field that helps prevent corona discharge and streamers from the top turn of the secondary coil if there is a too large distance from that and topload.
Offline thedoc298
« Reply #4 on: July 31, 2019, 02:28:41 AM »
Thanks for another good tip, takes long time to fully understand all the in's and out's. Would it be like if at the top of the secondary I had a 10 inch giraffe neck that it would be to my advantage to have a smaller turtle neck below the bigh toroid on top of the 10 inch gap for the reasons you stated. Thanks.
« Last Edit: August 05, 2019, 08:42:45 AM by Mads Barnkob »
« Reply #5 on: August 01, 2019, 06:00:24 PM »
Most people with SGTCs just use a single toroid mounted at the proper height to shield the top turns of the secondary from corona or sparks. My 8.6" pig-powered coil just has a single 30" x 9" aluminum toroid with no problem.
« Reply #6 on: September 26, 2019, 09:15:36 PM »
JAVATC allows for multiple top loads in the input. You can try your different ideas and see what they do.
post Small DIY plasma globe using ZVS oscillator
Today at 06:21:31 AM
Today at 05:54:17 AM
Today at 05:45:43 AM
January 21, 2020, 10:54:44 PM
January 21, 2020, 08:05:20 PM
Mysteriousduck
January 21, 2020, 03:49:24 PM
January 21, 2020, 08:37:14 AM
January 20, 2020, 11:10:05 PM
January 20, 2020, 10:55:35 PM
January 20, 2020, 09:48:06 PM
January 20, 2020, 08:31:54 PM
January 20, 2020, 12:59:19 PM
post DSO138, Not Even Once
January 20, 2020, 11:13:23 AM
HVZapp
January 20, 2020, 10:23:03 AM
January 20, 2020, 05:55:07 AM
January 19, 2020, 09:43:26 PM
January 19, 2020, 09:07:51 PM
post JavaTC question
January 19, 2020, 09:01:06 PM
January 19, 2020, 01:08:17 PM
January 19, 2020, 12:36:56 PM
Mysteriousduck
January 19, 2020, 04:06:36 AM
rvpilot
January 19, 2020, 02:00:30 AM
January 18, 2020, 08:51:26 PM
January 18, 2020, 06:53:02 AM
Mysteriousduck
January 18, 2020, 05:19:49 AM
Mysteriousduck
January 18, 2020, 04:41:22 AM
January 18, 2020, 12:30:19 AM
Mysteriousduck
January 17, 2020, 11:17:33 PM
January 17, 2020, 08:55:37 PM
January 17, 2020, 04:01:23 PM
RobertL
January 17, 2020, 04:22:25 AM
January 17, 2020, 01:37:37 AM
post Energy and Efficiency
RobertL
January 16, 2020, 11:51:51 PM
January 16, 2020, 11:59:04 AM
January 16, 2020, 02:53:32 AM
January 15, 2020, 08:57:37 PM
January 15, 2020, 07:27:10 PM
January 15, 2020, 07:08:00 PM
January 15, 2020, 01:26:57 PM
January 15, 2020, 12:37:28 PM
January 15, 2020, 01:15:45 AM
January 14, 2020, 11:19:23 PM
Nicko
January 14, 2020, 10:50:54 PM
January 14, 2020, 08:24:10 PM
January 14, 2020, 07:36:14 PM
January 14, 2020, 12:51:32 PM
January 14, 2020, 05:27:11 AM
January 14, 2020, 02:27:54 AM
dj.cosmo.esq
January 13, 2020, 11:42:07 PM
January 13, 2020, 11:30:11 PM
