Author Topic: A new quick way to get into tune a DRSSTC  (Read 116 times)
Offline VNTC
« on: July 18, 2019, 03:13:27 AM »
Content in this topic overrides some of my old topics in the form of an update action
      Power output/primary current according ratio f2/f1preset
This table construct by run simulating 4 models of Tesla coil, remember that in 6 columns it always running in-tuned (frequency in L1=frequency inL2=ft) I have verifier once by my test coil in practice , It run immediately and pretty good at column 1 . All of 4 models give best performance at f2/f1=1(preset)
*In column1;4;6 first number is power output peak max at the end of burst duration, 2nd number is primary peak max Apk at according position.
While DRSSTC  running, it always in-tuned regardless of :
-   split frequency factor
-   Situation of  load “no load or full load”
Therefore, the meaning of the tuning is  preset f2 higher than F1 15% then it will be into tune when the sparks is stronger no longer trendy, now is the job of finding out which value of frequency split up factor should be preset, will give the best performance. It is best include the highest power output according to the power input ratio. The results are simple:
 “To get the best tuning, let refine f2 = f1”
For classic Tesla coil it is different
Note: Row3 first  number Kw peak max.  Second  number KA peak max
This table proved  that  why need to preset f2/f1=√1.3=1.148. Because it give best performance in this case.
And it also explain why during hundreds of years nobody has question about that.
May be at other of L1;L2 value this number change a little or not?
« Last Edit: July 18, 2019, 06:35:20 AM by VNTC »
post HV Pulser/Switcher
magnetic_fields
Today at 12:36:58 PM
Today at 07:55:15 AM
post Re: Suitable capacitors and switches? 10kV
MrFox
August 21, 2019, 10:51:21 AM
post Re: Drsstc 3
August 21, 2019, 03:59:47 AM
post Heavily improvised DRSSTC
Grzegorz2121
August 21, 2019, 01:36:21 AM
Grzegorz2121
August 21, 2019, 01:10:06 AM
August 20, 2019, 02:22:09 PM
August 19, 2019, 09:08:12 PM
post Re: Drsstc 3
August 19, 2019, 02:27:06 PM
post Flashing light prize 2019
Avalanche
August 19, 2019, 02:12:41 PM
post Re: Drsstc 3
August 19, 2019, 10:44:35 AM
post Re: Drsstc 3
August 19, 2019, 07:37:07 AM
post Re: Drsstc 3
August 19, 2019, 03:29:24 AM
post Re: My second DRSSTC
erdal
August 18, 2019, 05:05:24 PM
Bert911
August 18, 2019, 01:04:35 PM
post Re: You would think this would be easy to find.
August 17, 2019, 11:09:16 PM
August 17, 2019, 11:00:32 PM
August 17, 2019, 09:44:07 PM
post You would think this would be easy to find.
August 17, 2019, 09:01:00 PM
post Re: Twin System Build
August 17, 2019, 08:06:42 PM
Lane
August 17, 2019, 10:45:26 AM
Lane
August 17, 2019, 06:21:45 AM
August 17, 2019, 12:59:20 AM
fnordest
August 17, 2019, 12:18:48 AM
post Re: Drsstc 3
August 16, 2019, 10:34:46 PM
post Re: Teardown of Danfoss VLT6000 4kW Variable Frequency Drive
August 16, 2019, 10:26:19 PM
August 16, 2019, 10:19:18 PM
post Re: [Development] Project of an SSTC driver.
August 16, 2019, 10:07:31 PM
August 16, 2019, 09:28:35 PM
August 16, 2019, 09:17:04 PM
post Re: ESAB Power TIG 200 Welder Teardown
August 16, 2019, 09:14:36 PM
post ESAB Power TIG 200 Welder Teardown
August 16, 2019, 08:03:18 PM
August 16, 2019, 01:49:53 PM
post Suitable capacitors and switches? 10kV
MrFox
August 16, 2019, 12:21:36 PM
Lane
August 16, 2019, 11:22:45 AM
August 15, 2019, 06:23:40 PM
August 15, 2019, 06:17:55 PM
Lane
August 15, 2019, 01:51:04 PM
August 14, 2019, 07:05:57 PM
Bert911
August 14, 2019, 03:42:34 PM
post Re: Van de Graaf is leaking charge
[Static electricity]
Patric
August 14, 2019, 02:56:49 PM
August 14, 2019, 01:42:21 PM
erdal
August 14, 2019, 12:53:10 PM
post Van de Graaf is leaking charge
Patric
August 14, 2019, 09:22:21 AM
post Re: Drsstc 3
August 14, 2019, 04:39:11 AM
post Re: MMC orientation and variac
August 13, 2019, 07:10:31 PM
August 13, 2019, 05:17:23 AM
post MMC orientation and variac
August 12, 2019, 09:54:35 PM
erdal
August 12, 2019, 08:40:16 PM
August 12, 2019, 07:27:23 PM
