Author Topic: A new quick way to get into tune a DRSSTC  (Read 304 times)
Offline VNTC
« on: July 18, 2019, 03:13:27 AM »
Content in this topic overrides some of my old topics in the form of an update action
      Power output/primary current according ratio f2/f1preset
This table construct by run simulating 4 models of Tesla coil, remember that in 6 columns it always running in-tuned (frequency in L1=frequency inL2=ft) I have verifier once by my test coil in practice , It run immediately and pretty good at column 1 . All of 4 models give best performance at f2/f1=1(preset)
*In column1;4;6 first number is power output peak max at the end of burst duration, 2nd number is primary peak max Apk at according position.
While DRSSTC  running, it always in-tuned regardless of :
-   split frequency factor
-   Situation of  load “no load or full load”
Therefore, the meaning of the tuning is  preset f2 higher than F1 15% then it will be into tune when the sparks is stronger no longer trendy, now is the job of finding out which value of frequency split up factor should be preset, will give the best performance. It is best include the highest power output according to the power input ratio. The results are simple:
 “To get the best tuning, let refine f2 = f1”
For classic Tesla coil it is different
Note: Row3 first  number Kw peak max.  Second  number KA peak max
This table proved  that  why need to preset f2/f1=√1.3=1.148. Because it give best performance in this case.
And it also explain why during hundreds of years nobody has question about that.
May be at other of L1;L2 value this number change a little or not?
« Last Edit: July 18, 2019, 06:35:20 AM by VNTC »
January 25, 2020, 11:01:24 AM
January 25, 2020, 06:44:21 AM
January 25, 2020, 06:37:47 AM
January 25, 2020, 02:22:09 AM
January 25, 2020, 01:15:21 AM
January 24, 2020, 08:16:12 PM
January 23, 2020, 03:47:06 PM
January 23, 2020, 02:24:07 PM
January 23, 2020, 01:29:01 PM
January 23, 2020, 12:45:40 PM
January 23, 2020, 11:38:18 AM
January 23, 2020, 10:43:36 AM
January 23, 2020, 08:32:56 AM
January 23, 2020, 06:06:20 AM
January 23, 2020, 05:57:18 AM
post Doorknob vs Ceramic Disk
January 23, 2020, 03:57:09 AM
January 23, 2020, 12:33:44 AM
January 22, 2020, 11:45:26 PM
January 22, 2020, 11:30:26 PM
January 22, 2020, 06:21:31 AM
January 22, 2020, 05:54:17 AM
