Author Topic: Benchtop power supply PCB  (Read 61 times)
« on: June 09, 2019, 04:28:29 PM »
I design a power supply PCB based on mixing the attributes of several designs floating around on the internet. You can find it at:
https://github.com/profdc9/LinearPS
The range is up to about 30 volts and the current with a single TIP3055 maximum is about 4 A, though if you run it at low voltage output and high voltage input, you probably want to use multiple TIP3055 to dissipate all that power.
It works. It is intended to take the output of a step-down AC transformer, and it provides constant voltage and constant current controls. It also provides sampled outputs of the actual voltage and current output to connect panel meters, and a low current (zener) +5V to supply digital LCD meters. It can be adjusted for different input AC voltages and different ranges of output voltages and currents using trimmers. Also, it can have up to four TO-220 output devices that can be mounted to a common heatsink (for example, TIP41C or TIP3055 devices) to achieve higher output current.
I made this so that old junk and surplus transformers can be turned into useful benchtop power supplies.
DC can also be input into the board, but the minimum limiting output current will be around 500 mA.
[Vacuum tube Tesla coils]
Avenger
Today at 03:18:07 PM
donnersm
Today at 03:18:03 PM
Today at 02:56:29 PM
Today at 11:46:44 AM
Today at 11:45:11 AM
Today at 11:40:18 AM
Today at 07:46:25 AM
post Re: Si-wafers, ideas?
Today at 07:07:57 AM
Today at 05:45:55 AM
June 24, 2019, 09:26:47 PM
Bert911
June 24, 2019, 04:58:39 PM
[Static electricity]
Doros
June 24, 2019, 01:56:17 PM
Avenger
June 24, 2019, 01:28:59 AM
June 24, 2019, 12:47:16 AM
juuzpo
June 23, 2019, 10:58:48 PM
Golddustpeak
June 23, 2019, 07:22:47 PM
Jeff B
June 23, 2019, 05:52:56 PM
dexter
June 23, 2019, 03:15:53 PM
donnersm
June 23, 2019, 10:09:40 AM
June 23, 2019, 10:07:04 AM
June 23, 2019, 08:50:14 AM
June 23, 2019, 01:28:20 AM
June 23, 2019, 01:17:50 AM
June 23, 2019, 01:04:13 AM
June 23, 2019, 01:02:55 AM
Coupling
June 22, 2019, 11:10:02 PM
June 22, 2019, 08:45:17 PM
June 22, 2019, 08:36:34 PM
June 22, 2019, 06:18:22 PM
June 22, 2019, 05:47:22 PM
June 22, 2019, 05:21:58 PM
June 22, 2019, 06:10:01 AM
June 21, 2019, 09:08:16 AM
June 20, 2019, 08:58:07 PM
badpeter
June 20, 2019, 07:28:00 PM
post Re: Ideas needed!
June 20, 2019, 05:13:57 PM
post Re: Why did 4HV die??
June 20, 2019, 05:07:41 PM
Bert911
June 20, 2019, 02:14:55 PM
June 20, 2019, 12:53:58 PM
June 20, 2019, 12:09:27 PM
post Choke-input DC-filter
June 20, 2019, 11:43:58 AM
June 20, 2019, 08:57:42 AM
June 20, 2019, 04:06:00 AM
June 20, 2019, 03:50:56 AM
June 19, 2019, 11:29:28 PM
June 19, 2019, 01:40:16 PM
June 19, 2019, 10:49:45 AM
June 19, 2019, 10:43:32 AM
[Light, lasers and optics]
June 19, 2019, 10:03:54 AM
June 19, 2019, 10:02:21 AM
