Author Topic: Cannot directly coupled to GDT even with symmetrical polarity square signal  (Read 137 times)
Offline VNTC
I focused on design electrical circuit that could create the burst pulses length look like ideal square wave as figure1 (Marty’s image, no ripple wave).
I spend a lot of time to exclude the ripples of GDT signals after try, try, but the result was a disastrous failure, but somehow managed to catch it a part.
What is a disastrous failure? Fist,I try to make a circuit can generate square wave symmetrical and try to coupling direct to GDT but cannot and several driver chip UCC37321 fail.
I am exasperated, so I run simulation to find out the reason.(image2)
The result of simulation shows that voltage wave look very good
but current is deviation to one side of polarities (image3) and seriously in the long duration signals (image4)
Then I must be used capacitor 1uf for DC cut (image 5) switchU1 start burst lengthU3 stop burst length, U2 switch simulate UCC37321 pull to GND. These switches simulate driver chips working in interrupt mode.
Right after the capacitor the ripples appear by 2 parts: front ripple and rear ripple they have the periods 160us . They created by capacitor 1.5uf and inductance 440uH.in serial circuit. (image5) reduce ripple circuit coupled.(parameter from my real circuit with the coil 5turns on ferrit core 5mmx12mm cross section)
Solution to reduce part 1 of ripple is rather simple the amplitude limiter used zener diode can gives good effect to do that (image6) reduce ripple circuit coupled, front ripple was almost excluded
Part2 of the ripple I not yet find out the way to reduce it. In practice it do not causes the bad effect to run Tesla coil.
« Last Edit: June 05, 2019, 03:15:28 PM by VNTC »
post Re: Tungsten
[Spark gap Tesla coils]
Today at 06:05:52 AM
[General chatting]
Seb555
Today at 01:17:41 AM
post Functioning limits of a SSTC interrupter duty cycle and frequency
[Solid state Tesla coils]
Seb555
August 24, 2019, 09:46:08 PM
post Tungsten
August 24, 2019, 03:44:17 PM
[Electronic circuits]
August 23, 2019, 06:56:08 PM
August 23, 2019, 05:04:39 PM
August 23, 2019, 04:07:38 PM
August 23, 2019, 03:59:53 PM
Lane
August 23, 2019, 09:29:02 AM
August 22, 2019, 09:47:58 PM
post Re: Suitable capacitors and switches? 10kV
[Capacitor banks]
August 22, 2019, 09:38:27 PM
post Re: HV Pulser/Switcher
August 22, 2019, 09:34:25 PM
post Re: Drsstc 3
August 22, 2019, 09:32:24 PM
post Re: Heavily improvised DRSSTC
August 22, 2019, 09:25:16 PM
[General chatting]
August 22, 2019, 09:13:44 PM
post HV Pulser/Switcher
magnetic_fields
August 22, 2019, 12:36:58 PM
August 22, 2019, 07:55:15 AM
[Capacitor banks]
MrFox
August 21, 2019, 10:51:21 AM
post Re: Drsstc 3
August 21, 2019, 03:59:47 AM
post Heavily improvised DRSSTC
Grzegorz2121
August 21, 2019, 01:36:21 AM
[General chatting]
Grzegorz2121
August 21, 2019, 01:10:06 AM
[Transformer (ferrite core)]
August 20, 2019, 02:22:09 PM
August 19, 2019, 09:08:12 PM
post Re: Drsstc 3
August 19, 2019, 02:27:06 PM
post Flashing light prize 2019
Avalanche
August 19, 2019, 02:12:41 PM
post Re: Drsstc 3
August 19, 2019, 10:44:35 AM
post Re: Drsstc 3
August 19, 2019, 07:37:07 AM
post Re: Drsstc 3
August 19, 2019, 03:29:24 AM
post Re: My second DRSSTC
erdal
August 18, 2019, 05:05:24 PM
Bert911
August 18, 2019, 01:04:35 PM
post Re: You would think this would be easy to find.
August 17, 2019, 11:09:16 PM
August 17, 2019, 11:00:32 PM
August 17, 2019, 09:44:07 PM
post You would think this would be easy to find.
August 17, 2019, 09:01:00 PM
post Re: Twin System Build
August 17, 2019, 08:06:42 PM
Lane
August 17, 2019, 10:45:26 AM
Lane
August 17, 2019, 06:21:45 AM
August 17, 2019, 12:59:20 AM
fnordest
August 17, 2019, 12:18:48 AM
post Re: Drsstc 3
August 16, 2019, 10:34:46 PM
post Re: Teardown of Danfoss VLT6000 4kW Variable Frequency Drive
August 16, 2019, 10:26:19 PM
August 16, 2019, 10:19:18 PM
post Re: [Development] Project of an SSTC driver.
August 16, 2019, 10:07:31 PM
[Capacitor banks]
August 16, 2019, 09:28:35 PM
[Capacitor banks]
August 16, 2019, 09:17:04 PM
post Re: ESAB Power TIG 200 Welder Teardown
August 16, 2019, 09:14:36 PM
post ESAB Power TIG 200 Welder Teardown
August 16, 2019, 08:03:18 PM
August 16, 2019, 01:49:53 PM
post Suitable capacitors and switches? 10kV
[Capacitor banks]
MrFox
August 16, 2019, 12:21:36 PM
Lane
August 16, 2019, 11:22:45 AM
