Author Topic: General Oscilloscope Probing Techniques for (DR)SSTC h-bridge  (Read 1095 times)
Offline L_Mangold
Hello everyone,
I wanted to get a few other peoples' input on probing techniques for troubleshooting (DR)SSTC H-bridge circuitry. Currently, I have been using a used analogue CRT scope from Tektronics for probing pretty much everything from my driver to the actual power side of the coil(s) that I've been working on. The benefit of the analogue scope has included being able to see very short/transient spikes, as well as the fact that it has an add feature that allows for differential (I believe) measurements. I've been able to tune my primary, probe current waveforms, and even turn phase lead on the driver, but I've been nervous about taking any measurements when powering the bridge via mains. I just bought a Hantek digital storage scope, and an additional 1-100X probe so my old scope will now be my back-up one and provide an additional 2 channels in case I need more than 2 for one test.
My question is simply to inquire as to how everyone else probes their bridge; particularly probing the high side IGBT's and tuning phase lead, and whether or not you use a high voltage differential probe.
Thank you kindly in advance!
Re: General Oscilloscope Probing Techniques for (DR)SSTC h-bridge
« Reply #1 on: May 15, 2019, 10:08:11 AM »
I use my DSO1054z with a range of different Pearson current monitors and a Tektronix P5100 differential probe for up to 1100V isolated measurements. I also have a 2ch Tektronix A6909 isolator for up to 600V.
I try to follow the guide on measurements found here: https://highvoltageforum.net/index.php?topic=2.0
Guides and tutorials
https://highvoltageforum.net/index.php?topic=111.0 - Tektronix 30-page guide to do CORRECT measurements on SMPS and Inverters
Offline Teravolt
« Reply #2 on: May 20, 2019, 06:33:49 PM »
invest in a isolation transformer so you can connect your scope common to your power sources common. reserch so you understand what you doing. I just use a dual winding 120 to 120 transformer. it does not have to be a expensive topaz transformer just something to seperate your mains refrance to ground. if you have 220 the same applies. it will be cheaper than a diferencial probe
« Reply #3 on: May 21, 2019, 09:51:27 PM »
Dave from EEVblog made a video long ago on oscilloscope grounding
Offline L_Mangold
« Reply #4 on: June 01, 2019, 12:23:13 AM »
I love Dave from EEVblog. Thank you very much for the input friends!
Today at 10:36:18 AM
Today at 12:48:13 AM
post compact midi interrupter
TmaxElectronics
Today at 12:17:38 AM
TmaxElectronics
June 06, 2020, 11:48:59 PM
[Radioactive Sources]
TheMaxii2007
June 06, 2020, 10:44:15 PM
June 06, 2020, 08:19:44 PM
June 06, 2020, 08:11:13 PM
June 06, 2020, 07:59:11 PM
June 06, 2020, 07:32:49 PM
June 06, 2020, 07:11:56 PM
June 06, 2020, 06:46:57 PM
TmaxElectronics
June 06, 2020, 05:46:56 PM
HiVi
June 06, 2020, 11:53:55 AM
Martin hughes
June 06, 2020, 11:03:13 AM
Nijin
June 06, 2020, 10:20:31 AM
June 06, 2020, 10:10:59 AM
June 06, 2020, 01:01:27 AM
k42
June 05, 2020, 06:18:16 PM
June 05, 2020, 06:08:18 PM
k42
June 05, 2020, 06:00:25 PM
June 05, 2020, 11:17:05 AM
HiVi
June 05, 2020, 10:02:02 AM
June 05, 2020, 12:54:06 AM
June 04, 2020, 08:14:58 AM
June 04, 2020, 06:30:09 AM
post Re: Datasheet Question
June 03, 2020, 08:01:53 PM
June 03, 2020, 03:04:11 PM
June 03, 2020, 02:54:04 PM
June 03, 2020, 02:27:26 PM
June 03, 2020, 02:19:32 PM
June 03, 2020, 02:10:57 PM
arctichominid
June 03, 2020, 02:10:18 PM
June 03, 2020, 12:27:06 PM
post Datasheet Question
June 03, 2020, 08:10:27 AM
June 03, 2020, 07:57:48 AM
June 03, 2020, 07:01:44 AM
June 03, 2020, 01:01:25 AM
June 03, 2020, 12:50:28 AM
June 03, 2020, 12:35:11 AM
09d08
June 03, 2020, 12:22:31 AM
June 02, 2020, 09:25:51 PM
09d08
June 02, 2020, 03:58:49 PM
June 02, 2020, 06:50:52 AM
TheMaxii2007
June 02, 2020, 05:52:14 AM
June 02, 2020, 04:53:24 AM
TheMaxii2007
June 02, 2020, 04:19:02 AM
post Re: Neon transformer
June 01, 2020, 11:55:28 PM
June 01, 2020, 08:34:10 PM
June 01, 2020, 07:58:20 PM
June 01, 2020, 05:50:47 PM
