Author Topic: Mounting LCD CFL's around DRSSTC?  (Read 672 times)
Offline fafler
« on: May 13, 2019, 07:58:25 PM »
Hi. I have recently brought my very first DRSST, and want to build a nice base for it to make it look good and also make it easier to set up. I have some of those really thin CFL tubes used in LCD screens laying around that I would like to incorporate into the design. Is there anything that would make it a really bad idea so mount 6 or 8 of them vertically around the secondary from top to bottom, to have them light up when the tesla coil is active? Like they gonna burn out after a short while or mess with the resonance or whatever?
Also, which material is recommended for the base, containing the electronics? Is it preferable to shield it in metal or does it have to be something none-conducting?
Re: Mounting LCD CFL's around DRSSTC?
« Reply #1 on: May 15, 2019, 12:46:33 PM »
Anything in the vicinity of a Tesla coil will affect it resonant frequency.
You should place the tubes so far away from the secondary that no sparks will hit the tubes, else they will at some point punch through the thin glass.
I always use a non-conductive material for the base, most of it can be wood, directly contact to conductors should be plastic. Always put your sensitive driver circuits inside a metal enclosure for shielding for EMI. Inverter and power electronics can sit unshielded without problems.
You should read my DRSSTC design guide on my website, despite you bought a DRSSTC, there is still a lot to learn about how it works :)
Today at 10:36:18 AM
post Re: Current Sense transformer trouble
Today at 12:48:13 AM
post compact midi interrupter
TmaxElectronics
Today at 12:17:38 AM
TmaxElectronics
June 06, 2020, 11:48:59 PM
[Radioactive Sources]
TheMaxii2007
June 06, 2020, 10:44:15 PM
post Re: Vacuum capacitor circuit advice
June 06, 2020, 08:19:44 PM
June 06, 2020, 08:11:13 PM
June 06, 2020, 07:59:11 PM
post Re: SSTC DRIVER WITH NON FUNCTIONAL ENABLE PIN FOLLOWUP
June 06, 2020, 07:32:49 PM
post Re: Any good suggestions for our QCW "sword sparks" mechanism research?
June 06, 2020, 07:11:56 PM
June 06, 2020, 06:46:57 PM
post Current Sense transformer trouble
TmaxElectronics
June 06, 2020, 05:46:56 PM
HiVi
June 06, 2020, 11:53:55 AM
Martin hughes
June 06, 2020, 11:03:13 AM
Nijin
June 06, 2020, 10:20:31 AM
prabhatkumar
June 06, 2020, 10:10:59 AM
June 06, 2020, 01:01:27 AM
June 05, 2020, 06:18:16 PM
June 05, 2020, 06:08:18 PM
June 05, 2020, 06:00:25 PM
June 05, 2020, 11:17:05 AM
HiVi
June 05, 2020, 10:02:02 AM
June 05, 2020, 12:54:06 AM
June 04, 2020, 08:14:58 AM
June 04, 2020, 06:30:09 AM
post Re: Datasheet Question
June 03, 2020, 08:01:53 PM
June 03, 2020, 03:04:11 PM
June 03, 2020, 02:54:04 PM
June 03, 2020, 02:27:26 PM
June 03, 2020, 02:19:32 PM
June 03, 2020, 02:10:57 PM
arctichominid
June 03, 2020, 02:10:18 PM
post Re: New projet OmegaDR
Mugi30
June 03, 2020, 12:27:06 PM
post Datasheet Question
June 03, 2020, 08:10:27 AM
June 03, 2020, 07:57:48 AM
June 03, 2020, 07:01:44 AM
June 03, 2020, 01:01:25 AM
June 03, 2020, 12:50:28 AM
June 03, 2020, 12:35:11 AM
09d08
June 03, 2020, 12:22:31 AM
June 02, 2020, 09:25:51 PM
09d08
June 02, 2020, 03:58:49 PM
June 02, 2020, 06:50:52 AM
TheMaxii2007
June 02, 2020, 05:52:14 AM
June 02, 2020, 04:53:24 AM
TheMaxii2007
June 02, 2020, 04:19:02 AM
post Re: Neon transformer
June 01, 2020, 11:55:28 PM
June 01, 2020, 08:34:10 PM
June 01, 2020, 07:58:20 PM
June 01, 2020, 05:50:47 PM
