Author Topic: Just how large?  (Read 472 times)
Offline Golddustpeak
Just how large?
« on: May 13, 2019, 03:04:50 PM »
Hi all,
I'm in the planning stage of my first DRSSTC system.
I'm planning on starting with a bridge of 4 FGH60N60SMD -or- FGA60N65SMD components as I want to stay with the TO-247 size for my first system.
My original desire was to use a 3 1/2 inch secondary coil form with a 1/4 inch copper tubing primary (which could be used for larger systems) but I'm wondering if this might be too large for my planned bridge.
In browsing the web I've found lots and lots of 2 3/8" dia. secondaries based on my choice of components and now I'm wondering if the 2 3/8" dia secondary might be the optional size.
So my question is just how large of a system will a bridge of 4 FGH60N60SMD -or- FGA60N65SMD support.
TNX
Offline Fumeaux
Re: Just how large?
« Reply #1 on: May 13, 2019, 03:17:50 PM »
I don't think there is a direct relationship between secondary diameter and igbts. But you should consider the switching frequency. If you use the fgh60n65smd with a 100kHz-secondary thats a waste of money (Loneoceans achieved 270kHz), as you could get away with some igbt that switches slower and therefore are cheaper. If you want some more "benchmarks" on what is possible read mads drsstc guide http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/. You should read the third article "IGBTs".
Re: Just how large?
Today at 10:36:18 AM
post Re: Current Sense transformer trouble
Today at 12:48:13 AM
post compact midi interrupter
TmaxElectronics
Today at 12:17:38 AM
TmaxElectronics
June 06, 2020, 11:48:59 PM
[Radioactive Sources]
TheMaxii2007
June 06, 2020, 10:44:15 PM
post Re: Vacuum capacitor circuit advice
June 06, 2020, 08:19:44 PM
June 06, 2020, 08:11:13 PM
June 06, 2020, 07:59:11 PM
post Re: SSTC DRIVER WITH NON FUNCTIONAL ENABLE PIN FOLLOWUP
June 06, 2020, 07:32:49 PM
post Re: Any good suggestions for our QCW "sword sparks" mechanism research?
June 06, 2020, 07:11:56 PM
June 06, 2020, 06:46:57 PM
post Current Sense transformer trouble
TmaxElectronics
June 06, 2020, 05:46:56 PM
HiVi
June 06, 2020, 11:53:55 AM
Martin hughes
June 06, 2020, 11:03:13 AM
Nijin
June 06, 2020, 10:20:31 AM
prabhatkumar
June 06, 2020, 10:10:59 AM
June 06, 2020, 01:01:27 AM
June 05, 2020, 06:18:16 PM
June 05, 2020, 06:08:18 PM
June 05, 2020, 06:00:25 PM
June 05, 2020, 11:17:05 AM
HiVi
June 05, 2020, 10:02:02 AM
June 05, 2020, 12:54:06 AM
June 04, 2020, 08:14:58 AM
June 04, 2020, 06:30:09 AM
post Re: Datasheet Question
June 03, 2020, 08:01:53 PM
June 03, 2020, 03:04:11 PM
June 03, 2020, 02:54:04 PM
June 03, 2020, 02:27:26 PM
June 03, 2020, 02:19:32 PM
June 03, 2020, 02:10:57 PM
arctichominid
June 03, 2020, 02:10:18 PM
post Re: New projet OmegaDR
Mugi30
June 03, 2020, 12:27:06 PM
post Datasheet Question
June 03, 2020, 08:10:27 AM
June 03, 2020, 07:57:48 AM
June 03, 2020, 07:01:44 AM
June 03, 2020, 01:01:25 AM
June 03, 2020, 12:50:28 AM
June 03, 2020, 12:35:11 AM
09d08
June 03, 2020, 12:22:31 AM
June 02, 2020, 09:25:51 PM
09d08
June 02, 2020, 03:58:49 PM
June 02, 2020, 06:50:52 AM
TheMaxii2007
June 02, 2020, 05:52:14 AM
June 02, 2020, 04:53:24 AM
TheMaxii2007
June 02, 2020, 04:19:02 AM
post Re: Neon transformer
June 01, 2020, 11:55:28 PM
June 01, 2020, 08:34:10 PM
June 01, 2020, 07:58:20 PM
June 01, 2020, 05:50:47 PM
