Author Topic: Last question  (Read 195 times)
Offline thedoc298
Last question
« on: May 09, 2019, 03:25:01 AM »
Im starting to dive into the bits of Synchronous Verses Asynchronous for my spark gap. Some say the best is Asynchronous and some say Synchronous. From what I have read the Synchronous would lock on at 120, 240 ....and such. But how is Asynchronous lined up to fire at the correct time, I don't seem to fully comprehend the Asynchronous spark gap and the pro's and con's of both.
Re: Last question
« Reply #1 on: June 15, 2019, 06:00:36 AM »
The short answer to your question is that there are no fixed firing points for an asynchronous RSG. The firing points will wander slowly through the sine wave as the motor RPM drifts with time.
The primary advantage of a ARSG (asynchronous) over a SRSG (synchronous) is simplicity. In order to make a SRSG, you need a synchronous motor powerful enough to spin the disk. These are usually made from regular non-synchronous induction motors by grinding either 2 flat spots (for a 3450 RPM motor) or 4 flat spots (for a 1725 RPM motor) on the armature. This will then make the motor synchronous at either 3600 RPM or 1800 RPM. Then you have to phase the motor disk so that the spark gap electrodes fire at the peak points of the sine wave (60 Hz or 50 Hz) charging the capacitor for 120 BPS (60 Hz) or fire at the peak sine wave points and the zero-crossing points for 240 BPS (60 Hz). The reason for doing all this is to make the firing points correspond to the maximum charge on the capacitor. This results in the maximum power delivered to the primary coil per bang.
The ARSG is much simpler. It just uses a regular induction motor with no modifications. The firing points happen at arbitrary points along the capacitor-charging sine wave. Thus the amount of power per bang delivered to the primary coil changes and drifts with time as the motor RPM wanders. With only 2 or 4 flying electrodes, you can even experience variation in streamer length and sound volume as the firing wanders along the sine wave.
With greater than 4 flying electrodes the difference between the SRSG and ARSG diminishes and the synchronism is of little value.
I built my SRSG from a 1/2 HP 3450 RPM induction motor by grinding 2 flats 180 degrees apart on the armature. It now runs synchronously at 3600 RPM. I set the firing points using an optical detector on the disk along with an oscilloscope to monitor the firing points. I rotated the motor until I got the firing points that I wanted. Then I locked down the motor. I use 4 flying electrodes so I get 240 BPS firing at 0 degrees, 90 degrees, 180 degrees, and 270 degrees on the sine wave.
« Last Edit: June 16, 2019, 05:27:45 AM by MRMILSTAR »
Offline thedoc298
Re: Last question
« Reply #2 on: June 16, 2019, 03:44:43 AM »
Thanks very much for the clear explanation.
Re: Last question
Bert911
Today at 11:19:45 AM
Today at 03:36:44 AM
DICKEYBIRD
Today at 03:24:38 AM
Today at 02:23:29 AM
DICKEYBIRD
Today at 01:06:44 AM
post Re: Floppiclene! A Electronics Cleaning Relic of the Past.
Justin
July 18, 2019, 10:29:32 PM
July 18, 2019, 08:52:35 AM
July 18, 2019, 05:49:27 AM
post A new quick way to get into tune a DRSSTC
July 18, 2019, 03:13:27 AM
July 18, 2019, 12:06:53 AM
July 17, 2019, 07:56:41 PM
post Floppiclene! A Electronics Cleaning Relic of the Past.
July 17, 2019, 11:25:22 AM
July 16, 2019, 07:39:33 AM
post Re: What is the true in tuning guide?
July 16, 2019, 05:11:21 AM
July 16, 2019, 04:05:07 AM
post Re: DRSSTC in brust mode
SAMGO
July 16, 2019, 02:25:27 AM
July 16, 2019, 01:54:30 AM
July 15, 2019, 02:51:26 PM
July 15, 2019, 02:48:02 PM
post Re: A problem solved with hand tools
July 15, 2019, 01:48:08 PM
post Re: Kaizer half bridge driver
July 15, 2019, 01:45:00 PM
July 15, 2019, 11:21:29 AM
post What is the true in tuning guide?
July 15, 2019, 10:01:21 AM
post A problem solved with hand tools
July 15, 2019, 07:52:41 AM
July 15, 2019, 07:33:30 AM
post Re: tesla coil varnish is dumb
July 14, 2019, 10:49:03 PM
July 14, 2019, 09:59:40 PM
July 14, 2019, 08:20:52 PM
July 14, 2019, 06:06:30 PM
post tesla coil varnish is dumb
July 14, 2019, 05:29:10 PM
post Led Closeups with Mobile phone and lens .
[Smart phones]
July 14, 2019, 03:00:09 PM
post Re: Drsstc 3
July 14, 2019, 02:06:26 PM
July 14, 2019, 02:04:22 PM
post Re: Twin System Build
July 14, 2019, 01:27:18 AM
July 14, 2019, 01:22:15 AM
post Re: Drsstc 3
July 13, 2019, 03:48:54 PM
post DRSSTC in brust mode
SAMGO
July 13, 2019, 04:17:55 AM
donnersm
July 12, 2019, 08:54:54 PM
July 12, 2019, 07:16:40 PM
July 12, 2019, 06:33:00 PM
post Smooth corona or heavy spark, RF wave radiation frequency of Tesla coil drops ve
July 12, 2019, 11:09:28 AM
post Re: Drsstc 3
July 12, 2019, 09:56:38 AM
post Re: Drsstc 3
July 12, 2019, 01:23:58 AM
post Re: Completed my pulsed power generator
July 11, 2019, 05:48:27 PM
July 11, 2019, 02:58:13 PM
July 11, 2019, 02:45:24 PM
post Kaizer half bridge driver
donnersm
July 11, 2019, 06:59:01 AM
post Completed my pulsed power generator
July 11, 2019, 05:43:31 AM
fnordest
July 11, 2019, 01:05:42 AM
[Vacuum tube Tesla coils]
Avenger
July 09, 2019, 07:31:37 PM
