Author Topic: Flat Secondary Coil on PCB?  (Read 1812 times)
« on: May 01, 2019, 05:54:26 PM »
I was thinking about designing a small kit-based Tesla coil where rather than the seconary coil being a solenoid, it is a flat spiral.  Of course the secondary inductance goes down, but is there any reason this shouldn't work?  Flat spirals are already used for resonant power transfer applications (e.g. wireless charging and induction cookers).
The board I designed has (I calculate) about 1 mH of inductance.  It is about 150 turns of 0.13 mm wide traces separated by 0.15 mm.  This is the thinnest I could fit in the design rules of the process.
Anyways I was up late last night and drew up a PCB.  The hole in the middle is for a post to put the topload on sticking up from the PCB.  The hole on the edge is to connect the ground.  There is a six turn coil on the back that is used to sense the current in the secondary for feedback purposes.
I was thinking too that I could stack the boards to get more turns and place a thick HDPE insulator between them.    The center of each coil would be connected to the ground of the next in series, and these would be stacked as to be placed over the primary coil  so that the board would intersect  the magnetic field lines of the primary coil.
Here is what I drew up last night:
Any comments about this design?  I want to call it the "Conversation Piece" which would be a little tabletop SSTC coil.  It would be powered by 12-30 VAC.
Offline Phoenix
Re: Flat Secondary Coil on PCB?
« Reply #2 on: May 01, 2019, 07:34:33 PM »
You wouldn't happen to know of a video of it in use?  I am curious to see how they work.  I was thinking of adding a buck converter before the half/full bridge so that I could modulate the power with an audio signal.
Hello
I know that such tesla coils work, because they are sold commercially: https://highvoltageshop.com/epages/b73088c0-9f9a-4230-9ffc-4fd5c619abc4.sf/de_DE/?ObjectPath=/Shops/b73088c0-9f9a-4230-9ffc-4fd5c619abc4/Products/TESLA_MINI_v1.2_
In the description you can see the technical data of the coil, it has 120 turns: https://highvoltageshop.com/epages/b73088c0-9f9a-4230-9ffc-4fd5c619abc4.sf/de_DE/?ObjectPath=/Shops/b73088c0-9f9a-4230-9ffc-4fd5c619abc4/Products/TC12_flach
Greetings
Offline Phoenix
« Reply #3 on: May 01, 2019, 08:17:27 PM »
No, i do not have a video about this coil. But if you look at the image from the second link, you can see that the primary is on the same PCB as the secondary. There are 2 bigger traces after the secondary coil.
The description says that this is a class E SSTC. I think you could use any normal Audio PLL Class E SSTC schematic and simply hook this coil up instead of a classical resonator: http://uzzors2k.4hv.org/projectfiles/classesstc1/classE_SSTC.GIF
Maybe you need to adjust some component values according to your resonant frequency, but the basic principle is the same.
Greetings
« Reply #4 on: May 02, 2019, 01:24:07 AM »
The only thing I can offer here is another reference. This coil is still early days but it is a drsstc.
https://hackaday.io/project/165112-pcbtc-gan-edition
« Reply #5 on: May 02, 2019, 02:06:27 AM »
Thanks for the link.  That looks like an awesome project.
Thanks to you both for the info.  It gives food for thought.  I didn't think I was the only one who thought of this, but obviously there's been some movement here. :)
I was thinking of keeping the primary and secondary on separate PCBs so I could stack several secondaries to get more turns, and also I put the sense coil on the other side of the secondary board so that it there is less of a chance of having a coil strike damage the circuity (if it is possible to have a streamer that long).
dan
« Reply #6 on: June 04, 2019, 09:04:46 AM »
You could stack multiply PCBs as its done with planar transformers where the PCB are connected with VIA and the primary/secondary are interleaved for highest possible coupling.
I know this might not work as well with a high voltage output like this, but at least it is a common used practise to make these electronic layer cakes.
Offline nick
« Reply #7 on: November 22, 2019, 12:04:52 PM »
I coincidentally came across the project below today while looking for something else. Your post immediately rang a bell. Maybe some of his info is helpful.
http://www.megavolts.nl/en/projects/tesla-coils/201-pcb-spiral-teslacoil-en
Online klugesmith
« Reply #8 on: November 22, 2019, 06:59:51 PM »
Dan, what's your estimate of the DC resistance, and resulting effect on Q of primary circuit?
A simple rule of thumb: Sheet resistance is about 1/2 milliohm per square for 1 ounce copper foil (about 35 um thick).  The resistance of your fine-pitch spiral can be a good indicator of actual trace width after etching.
[edit] Oops, you were proposing the flat spiral coil for _secondary_ TC winding.  Point still stands:  Resistive damping is strong unless L/R (in seconds) is large compared to period of oscillation.
« Last Edit: November 23, 2019, 02:50:35 AM by klugesmith »
Today at 06:37:03 AM
Today at 04:18:29 AM
Today at 01:35:07 AM
July 10, 2020, 11:35:05 PM
post Re: Capacitors and arcs
Morvandium
July 10, 2020, 11:10:57 PM
Morvandium
July 10, 2020, 11:06:07 PM
k42
July 10, 2020, 08:53:06 PM
July 10, 2020, 07:20:48 PM
Morvandium
July 10, 2020, 04:45:43 PM
July 10, 2020, 10:57:29 AM
July 10, 2020, 08:55:30 AM
July 10, 2020, 08:48:33 AM
July 10, 2020, 07:00:13 AM
July 10, 2020, 06:57:36 AM
July 10, 2020, 05:44:54 AM
July 09, 2020, 09:23:38 PM
July 09, 2020, 09:09:08 PM
July 09, 2020, 07:00:49 PM
July 09, 2020, 02:33:38 PM
July 09, 2020, 12:16:32 PM
July 09, 2020, 11:46:10 AM
July 09, 2020, 10:56:18 AM
July 09, 2020, 08:37:52 AM
July 09, 2020, 06:45:18 AM
July 09, 2020, 02:36:22 AM
July 08, 2020, 09:43:20 PM
Morvandium
July 08, 2020, 09:33:35 PM
July 08, 2020, 09:23:14 PM
July 08, 2020, 09:16:42 PM
July 08, 2020, 09:00:04 PM
July 08, 2020, 04:25:53 PM
July 08, 2020, 10:03:25 AM
July 08, 2020, 08:39:10 AM
July 08, 2020, 08:34:02 AM
July 08, 2020, 04:39:10 AM
post Measuring LED efficiency
July 08, 2020, 12:46:23 AM
July 07, 2020, 10:28:37 PM
July 07, 2020, 10:09:22 PM
July 07, 2020, 09:36:53 PM
July 07, 2020, 09:20:12 PM
July 07, 2020, 09:07:10 PM
July 06, 2020, 10:29:17 PM
July 06, 2020, 06:53:26 PM
July 06, 2020, 01:18:03 PM
July 06, 2020, 01:05:32 PM
July 06, 2020, 06:14:56 AM
July 05, 2020, 06:31:21 PM
HiVi
July 05, 2020, 12:30:02 PM
July 04, 2020, 10:35:50 PM
July 04, 2020, 08:56:15 PM
