Author Topic: Analyzed a Tesla coil, simulating by Orcaad software (part_1_SGTC)  (Read 387 times)
Offline VNTC
 Used a schematic of a medium small size Tesla coil with all parameters:
L1=7uH
C1=200nf
L2=72mH
C2=15pf
DC bus 5000V
Every running simulating this schematic one time we can get many information of a spark gape tesla coil (SGTC) by hanging the marker probe  at any test point in the circuit, for example V,I,W. . .
   Figuer1: schematic equivalent circuit of a SGTC
*Switch U1represent the charge circuit for C2
 *Switch U2disconect the oscillation circuit with the charger circuit while the coil works.
 *Switch U3 represents the spark gape
 *R2 equivalent resistor of spark of the gape
*R3 equivalent resistor of spark at toroid
Result
Voltage
   Figure2: voltage wave form at L1.Base on it we can determine dynamic primary resonance frequency Fd1=. . . . (in coupled)
   Figure3: voltage waveform at L2. Base on it we can determine dynamic secondary resonance frequency Fd2= . . . (in coupled)
We will see the dynamic frequencies are floating and change by the K and load resistor R3that reflect the situation of the spark (heavy or light)
By formula we can calculate static primary resonance frequency Fs1=134.5 kHz
And static secondary resonance frequency Fs2=153.1 kHz
  Current
 Figure 4: is primary current  wave that created by capacitor C2 discharge all its electrostatic emery  in halt cycle to L1 as power pack1 and then  going back from L1 and forth to C1 become power pack2; power pack3; power pack4; power pack5 from 11us to 32us, they gradually become smaller. This action  transfer  energy from primary to secondary coil form the ring up wave continue in 6 cycle until 63uswith the amplitude 150kV peak max in figure 3. (Remember that energy transfer by current and magnetic field from primary coil to secondary coil)
We see the V gain factor =√(L2/L1)=30
So the max. peak output voltage =150KV
Power
Figure 5: in primary a halt red cycle
WC2=1/2 V^2 C=2.5Joule (all the power in C2 is only 45% of this because loss 55% in the spark gap or much more if resistor of the gap >1 ohm?)
Figure 6: energy transfer from primary to secondary in the case K=.5 and in the case K=.15 (this figure show K=.15K=.2 is the best)
Figure 7: power in primary coil (peak power 1.7Mw)+ power in secondary coil (peak power 200Kw)
Figure 8:  power in the spark (peak power 54Kw)
And some data more
The equivalent resistor R3 is important if its values only 1 ohm the efficiency of the coil drop 50% approx.
   This information s shows us very clearly how the SGTC work. Especially it indicates the static resonance frequency (independent resonance frequency) and dynamic resonance frequency (resonance frequency in coupled) here we identify 2frequencies are constant and 2 other are float while running in a tesla coils.
With the patient and meticulous analyses this tool can help us a lot for design and tuning the coil.
 This tool also leads me to another tool can helpful for DRSSTC. I will introduce that tool in a new topic.
Re: Analyzed a Tesla coil, simulating by Orcaad software (part_1_SGTC)
« Reply #1 on: April 30, 2019, 01:55:21 PM »
Welcome to the community of TC theoreticians.
I find, that the most difficult part in simulations is to get the loading of the coil by the arc right. A static model, like a RC circuit, is probably ok for a SGTC, although the values of R and C depend strongly on the power and the frequency of the coil. For a DRSSTC R and C (if modelled like this) change during arc growth. That can affect significantly e.g. the currents in the primary tank.
Talking about power _in_ the secondary tank is a bit confusing. You probably mean energy, but then the units are Joules.
I'm also confused about the figures here. Have you shown both cases and can you point me there?
Today at 07:22:17 AM
Today at 06:15:28 AM
Today at 05:27:56 AM
Today at 05:15:44 AM
Today at 03:27:07 AM
warmania
warmania
post Re: FPS4000
post Re: NST
post FPS4000
Hoser415
spacecabbie
