Author Topic: [Development] Project of an SSTC driver.  (Read 1590 times)
Offline Bambinz
« on: April 29, 2019, 08:25:46 PM »
Dear all,
I am developing a new SSTC driver to drive my small teslacoil, because the current driver is not very reliable.
The characteristic will be the followings:
   - Half-bridge configuration
   - Feedback on the secondary with an current trasformer.
   - 2x Separated Board: 1 board for the driver and one board for the half bridge
   - Measure of the primary current
   - Measure of the switch frequency
   - Measure of the mosfet temperature
   - UVLO (under voltage protection)
   - Mosfet protection (Gate protection with zener, Drain-Source protection with snubber and TVS)
   - Minimized connection inductance to allow high current switching at high frequency.
   - Microcontroller STM32F103 to acquire the data, enable/disable the driver in the case of fault condition and generate the interrupt signal.
   - Wi-Fi connect with an ESP32 to send all acquired data to an computer software and to receive the Frequency and duty-cycle of the interrupter, in addition in future to stream the music
If you have any suggestion please write me!!!
I have completed the bridge schematic, tomorrow I will post them.
Re: [Development] Project of an SSTC driver.
« Reply #1 on: April 30, 2019, 11:05:17 AM »
Sounds like an interesting project. I'm assuming your going to measure the switching frequency from secondary current feedback?
Offline Bambinz
« Reply #2 on: April 30, 2019, 12:48:21 PM »
Yes, I will read the switching frequency from the secondary current feedback, that will be also the driving signal for the driver.
In addition, I would try to implement a ZCS (Zero-current-switch) by reading the primary current and then by using a zero zero cross detector to enable the driver only near the zero current. But i think that will be difficult at 1MHz.
Offline Netzpfuscher
« Reply #3 on: April 30, 2019, 01:04:44 PM »
If you are planning to have a PC application you can take a look at our Teslaterm: https://github.com/Netzpfuscher/Teslaterm/tree/typescript
I also have a ESP32 Interface: https://github.com/Netzpfuscher/UD3_ESP32
Teslaterm is very flexible. It's not specifically designed for UD3. You can send text to the terminal window and use the c library to send telemetry like scope data or data for the gauges. I even have simple graphics functions for sending text/lines/colors from the microcontroller to the terminal screen.
Offline Bambinz
« Reply #4 on: April 30, 2019, 06:22:36 PM »
Thank you very much for the indication. The software is fantastic!
I will try to adapt the software with my data.
Eventually, I will rebuild a simplified interface with python :)
Offline Bambinz
« Reply #5 on: May 03, 2019, 07:52:19 PM »
This is the schematic of the half-bridge:
Offline Bambinz
« Reply #6 on: May 05, 2019, 01:33:37 PM »
I would like to make some changes in the driver.
I have found a 440VA 53VAC transformer that I would like to use for the next teslacoil.
Therefore VDC will be +- 75V (that can reach +-90 without load), therefore I have choosed a mosfet of 250Vds ->  IRFB4229
With a very short and semplified thermal calculation, result that can handle about 55A with the interrupter set to 20Hz and duty-cycle of 5% (Setted as worst case).
I would like to have the same carachteristic of the small coil with an high peak current and a low duty-cycle to have an low mean power and an high pulse power.
Thereticaly the small teslacoil have an peak current of about 30A, with a 24V supply and a push-pull driver will results in a 30A*24V*2= 1440W (peak power) and an average power of 40W. The results is about 7-8cm of spark.
Therefore the average current will be about: 55A * 0.05 = 2.75A with an average power of 75V*2.75 = 206W. And a Peak power of about 75V*55A =4125W
Therefore we will have a 4x power therefore I will expect a sparklength in the range of 30cm. Can be correct?
Offline Bambinz
« Reply #7 on: August 08, 2019, 11:56:51 AM »
I have just ordered the board from PCBWay for the driver. I hope that all works good xD
In the next day I will post the complete schematic :)
« Reply #8 on: August 16, 2019, 10:07:31 PM »
Spark length estimation for SSTC was never really linear in my experiments, it felt more like that I could just keep adding topload capacitance to get longer arcs :)
July 10, 2020, 11:35:05 PM
Morvandium
July 10, 2020, 11:10:57 PM
Morvandium
July 10, 2020, 11:06:07 PM
July 10, 2020, 08:53:06 PM
July 10, 2020, 07:20:48 PM
Morvandium
July 10, 2020, 04:45:43 PM
July 10, 2020, 10:57:29 AM
July 10, 2020, 08:55:30 AM
July 10, 2020, 08:48:33 AM
July 10, 2020, 07:00:13 AM
July 10, 2020, 06:57:36 AM
July 10, 2020, 05:44:54 AM
July 09, 2020, 09:23:38 PM
July 09, 2020, 09:09:08 PM
July 09, 2020, 07:00:49 PM
July 09, 2020, 02:33:38 PM
July 09, 2020, 12:16:32 PM
July 09, 2020, 11:46:10 AM
July 09, 2020, 10:56:18 AM
July 09, 2020, 08:37:52 AM
July 09, 2020, 06:45:18 AM
July 09, 2020, 02:36:22 AM
July 08, 2020, 09:43:20 PM
Morvandium
July 08, 2020, 09:33:35 PM
July 08, 2020, 09:23:14 PM
July 08, 2020, 09:16:42 PM
July 08, 2020, 09:00:04 PM
July 08, 2020, 04:25:53 PM
July 08, 2020, 10:03:25 AM
July 08, 2020, 08:39:10 AM
July 08, 2020, 08:34:02 AM
July 08, 2020, 04:39:10 AM
post Measuring LED efficiency
July 08, 2020, 12:46:23 AM
July 07, 2020, 10:28:37 PM
July 07, 2020, 10:09:22 PM
July 07, 2020, 09:36:53 PM
July 07, 2020, 09:20:12 PM
July 07, 2020, 09:07:10 PM
July 06, 2020, 10:29:17 PM
July 06, 2020, 06:53:26 PM
July 06, 2020, 01:18:03 PM
July 06, 2020, 01:05:32 PM
July 06, 2020, 06:14:56 AM
July 05, 2020, 06:31:21 PM
HiVi
July 05, 2020, 12:30:02 PM
July 04, 2020, 10:35:50 PM
July 04, 2020, 08:56:15 PM
July 04, 2020, 04:37:32 PM
July 04, 2020, 04:14:44 PM
July 04, 2020, 01:52:14 PM
