Author Topic: [Development] Project of an SSTC driver.  (Read 1254 times)
Offline Bambinz
« on: April 29, 2019, 08:25:46 PM »
Dear all,
I am developing a new SSTC driver to drive my small teslacoil, because the current driver is not very reliable.
The characteristic will be the followings:
   - Half-bridge configuration
   - Feedback on the secondary with an current trasformer.
   - 2x Separated Board: 1 board for the driver and one board for the half bridge
   - Measure of the primary current
   - Measure of the switch frequency
   - Measure of the mosfet temperature
   - UVLO (under voltage protection)
   - Mosfet protection (Gate protection with zener, Drain-Source protection with snubber and TVS)
   - Minimized connection inductance to allow high current switching at high frequency.
   - Microcontroller STM32F103 to acquire the data, enable/disable the driver in the case of fault condition and generate the interrupt signal.
   - Wi-Fi connect with an ESP32 to send all acquired data to an computer software and to receive the Frequency and duty-cycle of the interrupter, in addition in future to stream the music
If you have any suggestion please write me!!!
I have completed the bridge schematic, tomorrow I will post them.
Re: [Development] Project of an SSTC driver.
« Reply #1 on: April 30, 2019, 11:05:17 AM »
Sounds like an interesting project. I'm assuming your going to measure the switching frequency from secondary current feedback?
Offline Bambinz
« Reply #2 on: April 30, 2019, 12:48:21 PM »
Yes, I will read the switching frequency from the secondary current feedback, that will be also the driving signal for the driver.
In addition, I would try to implement a ZCS (Zero-current-switch) by reading the primary current and then by using a zero zero cross detector to enable the driver only near the zero current. But i think that will be difficult at 1MHz.
Offline Netzpfuscher
« Reply #3 on: April 30, 2019, 01:04:44 PM »
If you are planning to have a PC application you can take a look at our Teslaterm: https://github.com/Netzpfuscher/Teslaterm/tree/typescript
I also have a ESP32 Interface: https://github.com/Netzpfuscher/UD3_ESP32
Teslaterm is very flexible. It's not specifically designed for UD3. You can send text to the terminal window and use the c library to send telemetry like scope data or data for the gauges. I even have simple graphics functions for sending text/lines/colors from the microcontroller to the terminal screen.
Offline Bambinz
« Reply #4 on: April 30, 2019, 06:22:36 PM »
Thank you very much for the indication. The software is fantastic!
I will try to adapt the software with my data.
Eventually, I will rebuild a simplified interface with python :)
Offline Bambinz
« Reply #5 on: May 03, 2019, 07:52:19 PM »
This is the schematic of the half-bridge:
Offline Bambinz
« Reply #6 on: May 05, 2019, 01:33:37 PM »
I would like to make some changes in the driver.
I have found a 440VA 53VAC transformer that I would like to use for the next teslacoil.
Therefore VDC will be +- 75V (that can reach +-90 without load), therefore I have choosed a mosfet of 250Vds ->  IRFB4229
With a very short and semplified thermal calculation, result that can handle about 55A with the interrupter set to 20Hz and duty-cycle of 5% (Setted as worst case).
I would like to have the same carachteristic of the small coil with an high peak current and a low duty-cycle to have an low mean power and an high pulse power.
Thereticaly the small teslacoil have an peak current of about 30A, with a 24V supply and a push-pull driver will results in a 30A*24V*2= 1440W (peak power) and an average power of 40W. The results is about 7-8cm of spark.
Therefore the average current will be about: 55A * 0.05 = 2.75A with an average power of 75V*2.75 = 206W. And a Peak power of about 75V*55A =4125W
Therefore we will have a 4x power therefore I will expect a sparklength in the range of 30cm. Can be correct?
Offline Bambinz
« Reply #7 on: August 08, 2019, 11:56:51 AM »
I have just ordered the board from PCBWay for the driver. I hope that all works good xD
In the next day I will post the complete schematic :)
« Reply #8 on: August 16, 2019, 10:07:31 PM »
Spark length estimation for SSTC was never really linear in my experiments, it felt more like that I could just keep adding topload capacitance to get longer arcs :)
Today at 08:20:25 PM
DJthefirst
Today at 08:20:07 PM
Today at 08:09:29 PM
Today at 02:53:24 PM
Today at 11:46:07 AM
Today at 11:40:55 AM
Today at 11:32:19 AM
Today at 03:48:55 AM
April 01, 2020, 09:47:42 PM
April 01, 2020, 09:31:49 PM
April 01, 2020, 08:47:11 PM
[Static Electricity]
April 01, 2020, 08:45:14 PM
April 01, 2020, 08:37:29 PM
April 01, 2020, 08:24:06 PM
post Re: Pt100 oddities
April 01, 2020, 08:16:59 PM
April 01, 2020, 07:50:16 PM
April 01, 2020, 07:42:47 PM
April 01, 2020, 07:39:48 PM
April 01, 2020, 06:07:44 PM
[DSLR]
April 01, 2020, 05:17:04 PM
April 01, 2020, 02:01:30 PM
April 01, 2020, 01:38:47 PM
April 01, 2020, 12:49:21 PM
April 01, 2020, 10:29:06 AM
post Pt100 oddities
April 01, 2020, 09:48:37 AM
April 01, 2020, 07:01:51 AM
April 01, 2020, 04:15:41 AM
April 01, 2020, 04:05:20 AM
April 01, 2020, 01:51:05 AM
April 01, 2020, 01:32:54 AM
March 31, 2020, 11:03:36 PM
March 31, 2020, 10:13:13 PM
post Class E SSTC Topology
March 31, 2020, 09:15:23 PM
March 31, 2020, 12:05:40 PM
March 31, 2020, 08:54:35 AM
March 31, 2020, 04:58:16 AM
March 31, 2020, 04:44:05 AM
March 31, 2020, 01:33:16 AM
March 31, 2020, 12:48:56 AM
March 30, 2020, 08:08:54 PM
March 30, 2020, 07:20:08 PM
March 30, 2020, 06:46:02 PM
March 30, 2020, 06:35:13 PM
March 30, 2020, 05:00:11 PM
March 30, 2020, 04:30:55 PM
March 30, 2020, 01:16:47 PM
Acid Byte
March 30, 2020, 07:23:21 AM
March 30, 2020, 06:13:52 AM
March 30, 2020, 05:31:27 AM
March 30, 2020, 02:55:41 AM
