Author Topic: Which way would be correct (for primary)  (Read 499 times)
Offline thedoc298
« on: April 18, 2019, 09:10:30 PM »
I have read two different methods for the primary center hole, 1st  the hole 2 inches bigger than the secondary. The second method said primary as close to the secondary without shorting. Which one should be used. Thanks again.
Re: Which way would be correct (for primary)
« Reply #1 on: April 23, 2019, 08:54:37 AM »
There is only 2 things to consider when choosing the inner diameter of your primary coil.
- Preventing flash-over between primary coil and secondary base / earthing point
- Coupling between coils
Often the required coupling between the coils will force you to have enough space between the coils so that the first paragraph is not a problem.
I would go with minimum 5 cm / 2" which also leaves you with some room to work in, when everything is fitted too tight together there is no room for servicing.
Offline thedoc298
« Reply #2 on: April 23, 2019, 05:36:57 PM »
Thanks I went with 2". Got the secondary wound.
« Last Edit: April 23, 2019, 09:33:07 PM by Mads Barnkob »
Today at 12:54:42 AM
post Power diodes "hockey Puck"
January 26, 2020, 10:13:38 PM
January 26, 2020, 04:55:49 AM
January 25, 2020, 11:01:24 AM
January 25, 2020, 06:44:21 AM
January 25, 2020, 06:37:47 AM
January 25, 2020, 02:22:09 AM
January 25, 2020, 01:15:21 AM
January 24, 2020, 08:16:12 PM
January 23, 2020, 03:47:06 PM
January 23, 2020, 02:24:07 PM
January 23, 2020, 01:29:01 PM
January 23, 2020, 12:45:40 PM
January 23, 2020, 11:38:18 AM
January 23, 2020, 10:43:36 AM
January 23, 2020, 08:32:56 AM
January 23, 2020, 06:06:20 AM
January 23, 2020, 05:57:18 AM
post Doorknob vs Ceramic Disk
January 23, 2020, 03:57:09 AM
January 23, 2020, 12:33:44 AM
January 22, 2020, 11:45:26 PM
