Author Topic: Full Bridge Inverter from bits and pieces  (Read 403 times)
Offline Thunderstruck
« on: April 07, 2019, 08:27:39 AM »
Originally I wanted to build Profdc9’s full bridge inverter, I also wanted to build it using parts listed in the BOM, I even filled a shopping cart at Mouser with all the necessary parts - about $120 worth...
Then the power and gas bills came together...  :-\
So, because I have to act as a responsible adult (BORING), hobby has to wait for funding to be available again.
Then I remebered that I have some bits n pieces left over from my first SSTC attempt that might work together to make a functioning bridge using Profdc9’s full bridge PCB.
I have:
- 4 IRFP460 FETs
- 4 MUR860 Fast Diodes
- 4 WIMA MKP10 0.68uF 630V Polypropylene Caps
I think that there is enough parts here to make a circuit based on Steve Ward’s mini SSTC half bridge inverter, but full bridge instead and using above mentioned PCB.
Maybe my thinking is wrong, but to me it looks like just a matter of doubling the number of the components, and of course driving the FETS in the correct sequence.
Drive would be provided by Profdc9’s SSTC Driver.
So far I mounted the parts together, not exacly as one would expect, but if everything works well I reckon it will make a neater build.
I cannot figure a couple things, one is due to inexperience in interpreting component data sheets:
1. What is the maximum Gate voltage on IRFP460 - I gather its about 10V but not sure
2. GDT from the driver outputs about 34V peak to peak, which is way too high for IRFP460,
    how do you bring the voltage down so it can be handled by the gate ? Only way I can think of is
    changing primary to secondary winding ratio.
I’d appreciate if someone could help with this - even if you tell me that this contraption will never work the way I imagined.
Image 1 Snip from Steve Ward’s schematic that i want to duplicate in a full bridge configuration
Image 2 Parts on hand
Image 3 Build so far - TVS diodes are bent like that because I wanted to put them under the board, but later realised it wouldn’t work  ::)
Image 4 This way FETS get a huge heatsink that can later serve as a base for the coil - of course keeping in mind that the transistors must be isolated from the heatsink, otherwise there will be a lot of angry Pixies in that sink, waiting to bite.
Offline Fumeaux
Re: Full Bridge Inverter from bits and pieces
« Reply #1 on: April 07, 2019, 08:50:09 AM »
2. GDT from the driver outputs about 34V peak to peak, which is way too high for IRFP460, how do you bring the voltage down so it can be handled by the gate ? Only way I can think of is changing primary to secondary winding ratio.
1) The gatevoltage for the IRFP460 is +-20V. (+- mean you can put everything between 20V and -20V on the gate)
* 91237.pdf
2) 34Vpp (Peak to Peak) means 17Vp (one Peak) or +-17V which is smaller than +-20V. So you are fine as it is.
You could bring it down either by lowering the secondary turns or lowering the gdt driver voltage (which may or may not be possible).
« Reply #2 on: April 07, 2019, 08:58:01 AM »
* 91237.pdf
Two birds with one stone ! Thanks Fumeaux !
So, Vgs is what I needed... well I suppose now I know  :)
I tried lowering GDT driver voltage - it doesn’t like it, gets emotional very quickly
But, GDT output voltage is not an issue any more.
Online Laci
« Reply #3 on: April 07, 2019, 09:01:39 AM »
MUR860s are not TVS diodes,but ultrafast recovery and works as freewheeling diodes. ;)
« Reply #4 on: April 07, 2019, 09:05:48 AM »
Yes, that... what you said  ;D
But they deal with the same thing, right ? Feedback from an inductive load ?
Online Laci
« Reply #5 on: April 07, 2019, 09:17:34 AM »
TVS diodes are more likely used in high inductance bridge design,where high voltages are generated due to parasitic inductances,which they clamp to a safe level.
Offline Fumeaux
« Reply #6 on: April 07, 2019, 09:32:35 AM »
Point is: they are not ideal, but I do think that they are good enough for a SSTC. TVS diodes are essential for DRSSTCs or I guess when you want a 3kW SSTC, but most schematics online for normal SSTCs don't feature TVS diodes.
« Reply #7 on: April 09, 2019, 05:01:38 AM »
the diode conducts only one direction and a tvs conducts in two directions like a big Zenar diode. The reason for them is to protect the internal diode in the mosfet during times of hard switching. If your switching ZCS timing is in phase and or on time they will never conduct.
Today at 11:46:44 AM
Today at 11:45:11 AM
[Vacuum tube Tesla coils]
Today at 11:40:18 AM
Today at 07:46:25 AM
post Re: Si-wafers, ideas?
Today at 07:07:57 AM
Today at 05:45:55 AM
June 24, 2019, 09:26:47 PM
Bert911
June 24, 2019, 04:58:39 PM
[Static electricity]
Doros
June 24, 2019, 01:56:17 PM
Avenger
June 24, 2019, 01:28:59 AM
June 24, 2019, 12:47:16 AM
juuzpo
June 23, 2019, 10:58:48 PM
Golddustpeak
June 23, 2019, 07:22:47 PM
Jeff B
June 23, 2019, 05:52:56 PM
dexter
June 23, 2019, 03:15:53 PM
donnersm
June 23, 2019, 10:09:40 AM
June 23, 2019, 10:07:04 AM
June 23, 2019, 08:50:14 AM
June 23, 2019, 01:28:20 AM
June 23, 2019, 01:17:50 AM
June 23, 2019, 01:04:13 AM
June 23, 2019, 01:02:55 AM
Coupling
June 22, 2019, 11:10:02 PM
June 22, 2019, 08:45:17 PM
June 22, 2019, 08:36:34 PM
June 22, 2019, 06:18:22 PM
June 22, 2019, 05:47:22 PM
June 22, 2019, 05:21:58 PM
June 22, 2019, 06:10:01 AM
June 21, 2019, 09:08:16 AM
June 20, 2019, 08:58:07 PM
badpeter
June 20, 2019, 07:28:00 PM
post Re: Ideas needed!
June 20, 2019, 05:13:57 PM
post Re: Why did 4HV die??
June 20, 2019, 05:07:41 PM
Bert911
June 20, 2019, 02:14:55 PM
June 20, 2019, 12:53:58 PM
June 20, 2019, 12:09:27 PM
post Choke-input DC-filter
June 20, 2019, 11:43:58 AM
June 20, 2019, 08:57:42 AM
June 20, 2019, 04:06:00 AM
June 20, 2019, 03:50:56 AM
June 19, 2019, 11:29:28 PM
June 19, 2019, 01:40:16 PM
June 19, 2019, 10:49:45 AM
June 19, 2019, 10:43:32 AM
[Light, lasers and optics]
June 19, 2019, 10:03:54 AM
June 19, 2019, 10:02:21 AM
June 19, 2019, 09:35:52 AM
badpeter
June 18, 2019, 11:35:16 PM
June 18, 2019, 08:22:23 PM
