Author Topic: Car starter on PWM  (Read 1072 times)
Offline AndreiRS
Car starter on PWM
« on: April 06, 2019, 02:59:17 AM »
Hi all. Oooof I have been away for a while. Not really doing much on electronics or HV, just renovating the house and working a bit. I also had to put my TC on the shelf because capacitors are not available here for a decent price. Then I got back to building a diy jet engine lol. But I did a project on electronics and today I remembered I should share it. ;D
So I got a normal PWM circuit, like the one you would get on ebay, it uses a LM324 as signal generator. 555 generators used to burn mosfets for some reason. Then I just removed the IRF540 from PWM board and put a mosfet push-pull driver there. Just a NPN and PNP transistors in series.
But instead of 1 mosfet, I used 4 IRF3205 in parallel, which should be capable of 110A each. And I think one 10ohm resistor on each gate. Yeah they will probably explode a lot earlier before those 110 amps hahah. But they are doing good till now. I started using 3600Hz as calculated using some "motor constant", it didn't work well. Latter I lowered it to 500Hz to have more torque available.
I'm kinda quiet here on the forum, I just don't have anything good to post and I don't know a thing about SSTCs. I will read other people post, maybe I can help someone a bit.
The plan is to use this on a electric bike. I just don't like "torqueless" brushless DC motors. Brushed motors from car engine starters are way more crazy haha. I had to remove all the front part of the car starter. Then I bought another rear end cover from the same model and used it as front cover too. Video is in portuguese but I said there about the same I said here. The 2.5mm² wires got warm with this small test. But it was just a test. I will use 10mm² wires.
« Last Edit: April 06, 2019, 03:06:44 AM by AndreiRS »
Re: Car starter on PWM
« Reply #1 on: April 06, 2019, 09:04:32 AM »
No catch diodes across the motor? :o
Offline AndreiRS
« Reply #2 on: April 06, 2019, 03:43:45 PM »
I have a MUR1620 in parallel, but it is at the connector part. ::)
« Reply #3 on: April 06, 2019, 04:22:50 PM »
I didn't think that car starters were rated for continuous duty.  is this one different?
Offline AndreiRS
« Reply #4 on: April 06, 2019, 05:47:37 PM »
It is just like all others. But I will "drop" it inside a small radiator fluid tank. I have seen some people do that, it works. Then the sprocket will come out from the top.
post Re: SSTC Micro
Today at 04:59:02 AM
Today at 04:32:26 AM
post Re: SSTC Micro
Rowdy
Today at 04:12:23 AM
Rowdy
Today at 03:41:17 AM
Rowdy
Today at 03:40:25 AM
post Re: SSTC Micro
jockoFergy
Today at 02:42:23 AM
May 27, 2020, 06:21:39 PM
fnordest
May 27, 2020, 12:11:06 PM
May 27, 2020, 11:51:19 AM
May 26, 2020, 07:55:03 PM
May 26, 2020, 07:40:48 PM
iraquois
May 26, 2020, 05:12:42 PM
May 26, 2020, 03:57:04 PM
May 26, 2020, 01:52:26 PM
May 26, 2020, 11:52:33 AM
May 26, 2020, 09:40:52 AM
May 26, 2020, 08:56:01 AM
May 26, 2020, 08:45:40 AM
May 26, 2020, 08:27:58 AM
May 26, 2020, 06:31:59 AM
May 26, 2020, 05:24:41 AM
May 26, 2020, 02:01:33 AM
iraquois
May 26, 2020, 01:12:46 AM
May 26, 2020, 12:37:32 AM
May 25, 2020, 10:35:49 PM
May 25, 2020, 09:30:41 PM
May 25, 2020, 08:17:18 PM
iraquois
May 25, 2020, 07:43:30 PM
May 25, 2020, 03:32:54 PM
May 25, 2020, 12:52:38 PM
May 25, 2020, 10:34:56 AM
kilohercas
May 25, 2020, 06:38:15 AM
May 25, 2020, 03:24:49 AM
post Re: SSTC Micro
May 25, 2020, 03:24:20 AM
Rowdy
May 25, 2020, 03:23:33 AM
May 25, 2020, 03:06:20 AM
May 25, 2020, 01:33:47 AM
post MMC for a 32kvac load
Rowdy
May 25, 2020, 01:02:34 AM
Rowdy
May 24, 2020, 11:47:26 PM
post Re: GDT cable specs
May 24, 2020, 11:09:44 PM
Rowdy
May 24, 2020, 10:39:45 PM
station240
May 24, 2020, 09:55:49 PM
May 24, 2020, 09:55:48 PM
May 24, 2020, 08:16:40 PM
thecyberman
May 24, 2020, 05:38:27 PM
Rowdy
May 24, 2020, 02:33:55 PM
hip424
May 24, 2020, 02:31:39 PM
iraquois
May 24, 2020, 02:08:53 PM
May 24, 2020, 12:12:36 PM
May 24, 2020, 07:56:21 AM
