Author Topic: DRSSTC feedback issue  (Read 288 times)
Offline Radek
« on: April 04, 2019, 11:21:48 PM »
I've been working on my medium-sized DRSSTC for a while. Currently, I'm trying to tune the primary LC circuit with the iron load. However, I've been struggling with the ud2.7C that is unable to tune to the feedback signal. I tried to increase the Vbus high enough to get about 50 mA on the secondary of feedback CT which should make about 3 V sinusoidal signal on the feedback input (considering the 51 R resistor on the ud board), but it still did not help. So the only signal I've got on the IGBT gates is from the interrupter (tried to increase the ontime, but it has no effect when no feedback). The CT ratio is 1:200. I scope on the extra CT with 5,1 R resistor connected to its secondary. OCD is set to 1 V (equals to about 45 apk).
Do you have any ideas why the ud is unable to tune to the primary LC resonant frequency?
Thank you in advance.
I attach the CT output wave (150 mV) with the gate wave (52 V pk-pk).
Offline Fumeaux
Re: DRSSTC feedback issue
« Reply #1 on: April 05, 2019, 08:59:16 AM »
There is one problem. The UD2.X are intended to work with primary feedback and not with secondary feedback. On loneoceans schematic it doesn't say so, but im sure on his post about the UD2.7 he said it somewhere.
There it does:
I can advise you to read the whole aticle before continuing http://www.loneoceans.com/labs/ud27/
« Last Edit: April 05, 2019, 01:27:58 PM by Fumeaux »
Offline dexter
« Reply #2 on: April 05, 2019, 10:58:12 AM »
Test the UD with a signal generator on feedback CT pins, maybe is something wrong with your board.
My coil also uses 1:200 CT's and i had to increase Vbus over 50V for the UD to tune to the feedback signal
Offline Radek
« Reply #3 on: April 05, 2019, 05:50:54 PM »
There it does:
I forgot to mention. Of course, I use the primary feedback. As I said, the secondary coil is not in place while tunning. I’ve studied how does ud2.7C work, but still cannot find out what problem I’m dealing with atm.
I tested the UD with 555 generator to choose a proper value of gate resistor at resonant frequency. Therefore I dont expect there is a problem with the board itself. Only if the type of the signal mattered, because the 555 output signal is a square and fb is obviously sinusoidal.
In my case I put Vbus up to 200 VDC and still did not caught the feedback. I also tried to reverse the FB, still without a result.
« Reply #4 on: April 08, 2019, 08:25:32 AM »
Hi Radek and welcome to HVF!
This sound like a very low peak current unless its a QCW? I think you have a too weak feedback or wrong phased feedback/output from GDT.
You have to bench test this with a couple of function generators to make both feedback, interrupter and OCD signal, alternatively you can just use a power supply on the OCD input to simulate the threshold level, but then you got no test if it can catch the peaks of a sinusoidal waveform.
Offline Radek
« Reply #5 on: April 08, 2019, 08:42:46 AM »
45 apk is only a safe current for the testing. The nominal primary current will be obviously higher. I think, for tuning this current should be sufficient.
I tried to reverse the FB so that wont be the problem. GDT is phased properly too. That was checked by the scope at both gates.
I recently found out by scoping the ud, that there is 500 mV pk-pk signal at the TL3116 input (when about 10 V pk-pk at the FB input/51 R resistor). The output of this comparator is just a constant of 5 V. Have you ever measured the TL input? Is the signal too low or can the TL be damaged somehow?
« Reply #6 on: April 08, 2019, 04:13:52 PM »
I would suggest also looking at the other (reference) input of the comparator to sanity check things - if the input voltage crosses the reference voltage and there is still no output then the comparator has an issue.
Offline Radek
« Reply #7 on: April 08, 2019, 04:33:50 PM »
I've already checked the reference input (voltage divider). There is 1,6 V as expected. The other (FB) input reaches about 500 mV pk-pk as its maximum (even at about 200 VDC on the bus). So it is understandable that it cannot set the comparator. However, I don't understand why there is such a low signal when at the FB input itself (CT secondary) is more than 10 V pk-pk. The higher current won't make it any better I think. I cannot let through the feedback approx. 0,5 A when the ud is not tuned yet. That would make such a high current when there is a nominal primary current (let's say 200 apk).
There is a comparison of the signal at FB input (14,8 V pk-pk) and comparator input (480 mV pk-pk).
« Reply #8 on: April 08, 2019, 07:55:49 PM »
The 500mV swing is expected - there is a series resistor and clamping diodes which limit it after the burden resistor. It should actually swing above/below the same ~1.6V as the reference input uses.
Offline Radek
« Reply #9 on: April 08, 2019, 08:06:11 PM »
Well, so do I understand it properly that the issue is due to the comparator itself then?
« Reply #10 on: April 08, 2019, 09:01:06 PM »
It may not be the comparator. Have a read up about how they work - they switch when the relative polarity at the two inputs changes. That's why I asked about both inputs and what voltage they were.
If they are not both approx 1.6V (e.g. one is near zero like your scope trace suggests) with no feedback input then something else is incorrect in your input circuitry.
Offline Radek
« Reply #11 on: April 08, 2019, 09:34:38 PM »
The reference input should be a constant of 1.6 V, am I right?
post Troubleshooting my first SSTC
[Solid state Tesla coils]
Seb555
Today at 08:14:08 AM
post Re: Secondary Design Tool
April 18, 2019, 10:33:01 PM
post Re: New small SSTC
April 18, 2019, 10:28:28 PM
April 18, 2019, 10:24:33 PM
[Electronic circuits]
April 18, 2019, 10:13:06 PM
April 18, 2019, 09:51:49 PM
post Re: Question about secondary
[Spark gap Tesla coils]
April 18, 2019, 09:26:14 PM
April 18, 2019, 09:20:15 PM
post Which way would be correct (for primary)
April 18, 2019, 09:10:30 PM
April 18, 2019, 08:01:36 PM
April 18, 2019, 07:04:40 PM
post Question about secondary
April 18, 2019, 06:32:18 PM
DICKEYBIRD
April 18, 2019, 04:32:55 PM
post Re: Resisitors
April 17, 2019, 11:12:06 PM
April 17, 2019, 10:44:02 PM
Laci
April 17, 2019, 09:38:39 PM
April 17, 2019, 09:29:05 PM
post Re: Would this be about right or not.
April 17, 2019, 09:22:07 PM
April 17, 2019, 09:08:08 PM
Laci
April 17, 2019, 09:01:40 PM
Laci
April 17, 2019, 08:55:48 PM
April 17, 2019, 08:51:47 PM
April 17, 2019, 08:42:33 PM
Laci
April 17, 2019, 08:34:44 PM
April 17, 2019, 08:22:30 PM
April 17, 2019, 08:16:07 PM
Laci
April 17, 2019, 08:14:52 PM
April 17, 2019, 07:55:29 PM
post Teach your kids electronics
April 17, 2019, 11:51:59 AM
April 17, 2019, 09:53:36 AM
Laci
April 16, 2019, 08:46:05 PM
April 16, 2019, 06:55:02 PM
April 16, 2019, 06:45:24 PM
post Re: Hi Uspring, please show me . . .
April 16, 2019, 03:06:02 PM
April 16, 2019, 03:26:34 AM
April 16, 2019, 01:20:34 AM
April 15, 2019, 10:02:19 PM
Laci
April 15, 2019, 09:28:09 PM
Laci
April 14, 2019, 09:20:52 PM
April 14, 2019, 07:56:40 PM
April 14, 2019, 03:00:18 PM
post Secondary Design Tool
April 14, 2019, 08:00:59 AM
DICKEYBIRD
April 14, 2019, 03:58:34 AM
April 14, 2019, 12:23:14 AM
post One trace illustrate 2 resonance frequency
VNTC
April 14, 2019, 12:15:19 AM
April 13, 2019, 11:16:20 PM
Laci
April 13, 2019, 09:40:09 PM
April 13, 2019, 06:00:05 PM
post Re: Hi Steve, would you please explain . . . .
Rafferty
April 13, 2019, 02:45:11 PM
Laci
April 13, 2019, 09:54:41 AM
