Author Topic: New to tesla coils, some questions before I start building a SSTC  (Read 267 times)
Offline Blin
Hello all!
Newbie in tesla coils (and in electronics) here, I want to build a SSTC (not a DRSSTC - I want to keep it as simple as possible for now). I think I understand most of the circuits around here, but I have some questions before I start building.
I plan to start with a single MOSFET SSTC to keep things simple (later I'll build a half bridge, then full bridge).
I've seen this design from E-Schmok and I want to build something similar, but I want to be sure I understand the purpose of some components in this circuit.
I got the interrupter part figured out already, my questions are about the power part:
* Can the power supply which powers the primary and MOSFET be a regulated switch mode power supply?
* What's the purpose of R13 and C23? Looks like a RC snubber?
* What's the purpose of D5 and D6? I guess it's to clamp the voltage to the MOSFET gate but 15v should be harmless for an IRFP540, so I'm wondering.
* Any reason to have 2 push-pull stages (Q5-Q6 and Q7-Q8)? Would a single one be enough?
* What's the purpose of C19 and C20?
I'm also a bit lost about the secondary design. I've seen different advices, sometimes contradictory. I've put some values in JavaTC and got a diameter, height and number of turns, but I don't want to make a secondary that won't produce sparks with my single transistor design. Is there a rule of thumb for secondary designs? How much does it depend on the power circuit?
The transistor I plan to use is a fcp20n60 (600V, 60A pulsed, RDSon=0.15) so not the best one out there, but I've got quite a few and I don't care if I blow them up.
Thanks for your insight, I still have a lot to learn...
Offline FilipŠebík
Re: New to tesla coils, some questions before I start building a SSTC
« Reply #1 on: March 10, 2019, 08:21:47 PM »
Hello, to answer the questions first:
1. Yes, they can be driven/regulated using SMPS
2. Actually it is, so you are right
3. The zener diodes are there for gate protection and they should be used
4. Yeah it should be but the gain of just the BD139 and BD140 may not be high enough and can reduce the gate drive, which may not make the mosfet open fully but partialy and thus it will work in its linear region, in which losses are big, so you should use the first stage too
6. They are just used as a filters, to filter the voltage rail
The secondary could be any coil with 1000+ turns and it should be 1:5 width:Height for small coils under 30cm, 1:4 for bigger coils Under 1m and 1:3 for big coils 1m<
The fcp20n60 is ok to use here.
« Reply #2 on: March 11, 2019, 09:46:17 AM »
Hi Blin and welcome to HVF
Filip answered all your questions, so I just give a word on the secondary design.
For a DRSSTC it is my opponion, showed with calculations that the smaller coils, the smaller W:H ratios is possible. I like 1:4 to 1:5 for DRSSTCs, depending on the power level, simply because the most power the better it is to have some distance to earth so all strikes are not just to ground. See table 3 and 4 here: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/secondary-coil/
For a SSTC the W:H ratios should be smaller because a SSTC needs a much higher coupling to produce a fair amount of sparks. 1:2 to 1:3 for a SSTC is the optimal in my experience.
Offline Blin
« Reply #3 on: April 11, 2019, 10:18:07 PM »
Thanks so much for your answers.
I've been experimenting with the circuit and working on the PCB (which I'm all new to, so it's taken quite a bit of time). Now I need a good secondary...
Mads, I've read your guide, and decided to go for a 30 cm height, 8 cm diameter secondary and 800 to 1200 turns. Started looking for wire and then found a pre-wound secondary on ebay: https://www.ebay.com/itm/Teslaspule-32x7-5-cm-1000-Wdg-0-2mm-Tesla-Coil-Spule-TC-001-HVSHP/273279706078
Seems to be perfect for my usage, and to be honest I'd rather buy it pre-wound than do it myself. So I have a few more questions now :)
  • Is the secondary in the link above able to produce good sparks in my use case?
  • For the primary, I think I'll just use some insulated copper wire from an extension (rated 30 amps or so). Ok as well?
  • The grounding: I'd like to just use the earth connection from an extension. I suppose it's ok as well?
Thanks, and I'll post photos when I have something working (which might take quite some more time...).
Today at 05:51:09 AM
Today at 04:07:17 AM
Today at 02:19:24 AM
Today at 02:00:48 AM
Today at 01:33:56 AM
May 22, 2019, 08:31:55 PM
May 22, 2019, 08:31:51 PM
May 21, 2019, 11:35:57 PM
May 21, 2019, 09:59:54 PM
May 21, 2019, 09:51:27 PM
May 21, 2019, 09:49:03 PM
82026
May 21, 2019, 09:02:10 PM
Vaclav
May 21, 2019, 08:59:57 PM
May 21, 2019, 08:28:43 PM
May 21, 2019, 08:22:28 PM
Vaclav
May 21, 2019, 06:21:37 PM
May 21, 2019, 06:12:55 PM
May 21, 2019, 04:06:38 PM
Vaclav
May 21, 2019, 03:56:56 PM
Vaclav
May 21, 2019, 03:46:56 PM
May 21, 2019, 02:32:59 PM
May 21, 2019, 06:12:18 AM
May 20, 2019, 11:30:34 PM
Vaclav
May 20, 2019, 06:38:54 PM
May 20, 2019, 06:33:49 PM
82026
May 20, 2019, 02:27:59 PM
May 20, 2019, 02:57:46 AM
May 20, 2019, 01:06:27 AM
82026
May 19, 2019, 09:14:59 PM
May 19, 2019, 06:40:41 PM
May 19, 2019, 04:04:12 PM
May 19, 2019, 11:24:46 AM
May 19, 2019, 03:22:54 AM
May 19, 2019, 03:18:52 AM
May 18, 2019, 10:48:59 PM
Golddustpeak
May 18, 2019, 04:19:11 PM
May 17, 2019, 10:57:17 PM
jpb133
May 17, 2019, 09:41:56 PM
May 17, 2019, 12:41:17 PM
82026
May 16, 2019, 04:15:58 PM
May 16, 2019, 02:19:39 PM
Golddustpeak
May 16, 2019, 01:50:44 PM
May 16, 2019, 12:17:01 PM
May 16, 2019, 08:45:15 AM
May 15, 2019, 11:49:59 PM
May 15, 2019, 10:51:33 PM
May 15, 2019, 09:35:41 PM
Golddustpeak
May 15, 2019, 05:07:20 PM
May 15, 2019, 12:46:33 PM
May 15, 2019, 10:08:11 AM
