Author Topic: DRSSTC Driver Logic  (Read 1113 times)
Online Laci
DRSSTC Driver Logic
« on: March 10, 2019, 04:40:30 PM »
I start this topic to understand the logic part of the universal DRSSTC drivers.The idea is to build the well known UD1.3 then upgrade it with digital phase lead control and freeweeling current limiter.In addition I'd like to make a bluetooth or ethernet interrupter.
The core of my design is a CY8CKIT-059 prototyping kit.
So far my driver looks similar to the UD1.3,expect one little bug:overcurrent has on direct effect on the output.Basically whatever I do at the CLR pin(13)it doesn't change the output.Only interrupter input at CLK pin(11) changes it,while I thought a logic high at CLR(overcurrent)should immediately turn off the drive at least for the set time constant(100us in my case and in case of the UD2.7).Is my theory right and my schematic wrong?
I think my code has no problems as it's really simple,just starting the DACs,comparators and the interrupt for the time constant.
My driver:
The internal of FliPC,which I made as a 74HC74 equivalent:
...and the UD1.3:
Offline sjsimmo
  • Australia
Re: DRSSTC Driver Logic
« Reply #1 on: March 11, 2019, 12:59:16 AM »
Hi Laci,  :)
Not sure if this is what's causing your problem, but your FliPC looks like it would update its output whenever the CLK pin is high. Whereas the 74HC74 is edge triggered, meaning that it will only update as the CLK pin changes from a low signal to a high signal. As for CLR signals, a logical LOW on the CLR' pin should cause the flip-flop to output 0 instantaneously (since the PRE/CLR inputs are inverted for both your schematic and the 74HC74).
Generally the OCD should actually disable the driver output on the next ZCS point (the same effect as the interrupter turning off), otherwise the IGBT would have to switch with the full peak current. I think that's what your circuit would do too, if the flip-flops were edge triggered.
Hope this helps,  :)
-sjsimmo
« Reply #2 on: March 11, 2019, 09:19:30 AM »
Is there a reason why you did not use a standard D Flip Flop w/ Enable like this? https://www.cypress.com/documentation/component-datasheets/d-flip-flop-wenable
Keep in mind that some Set-Reset function blocks have different priorities, most has Reset prioritized higher than Set.
While looking for this flip-flip, I came across this problem with edge triggered signals that might be a help to you: https://community.cypress.com/message/2120#2120
Offline Netzpfuscher
« Reply #3 on: March 11, 2019, 09:35:45 AM »
What's the reason not to use the UD3? The logic is tested and I had no IGBT failures since I use the UD3. With a simple modification to the logic you can add a simple external interrupter, if you want this.
« Reply #4 on: March 11, 2019, 05:24:10 PM »
The only purpace of the flip flop is to interupt your on time from the fiber reciever. It will stop the primary current from going higher than your mosfets can handle. the OC LED should show this on the board
Online Laci
« Reply #5 on: March 11, 2019, 11:21:24 PM »
Hi Laci,  :)
Hope this helps,  :)
-sjsimmo
Thanks,sjsimmo!I'll read a few more times your suggestions and hopefully realise what's wrong with my logic when I'll have some time.
Thanks,Mads.I saw that D flip flop with enable but I only had a day to work with my design,not much time to understand every component's logic.Also that one has 3 inputs,while a 74HC74 has 4.Do you know about some additional logic to make it the same?
Netzpfuscher,I really like the multifunctionality of your driver,but I didn't find the settings and it seemed far too complex to modify it so I gave up and started building a simpler,while also learning in PSoC Creator.I tried to follow the instructions on Steve's spec sheet,however I couldn't find the variables.
If I'm wrong please correct me or tell the settings file location. :)
Teravolt,I can hardly understand what you mean.The OCD comparator is connected to the CLR input of the flip flop,so it should have some effect on it.I mean the OC LED does light up when an overcurrent occours so the Q output in case of an overcurrent is always low,right?!
Offline sjsimmo
  • Australia
« Reply #6 on: March 12, 2019, 06:35:17 AM »
You could also use the standard D Flip Flop without enable (instead of the D flip flop w/ enable): https://www.cypress.com/documentation/component-datasheets/d-flip-flop
It can be configured to have both PRE and reset (CLR) inputs (see datasheet linked).
Just note that you'll have to add inverters to the PRE and CLR inputs, to make it logically identical to the 74hc74 (which has the PRE and CLR inputs inverted).
« Last Edit: March 12, 2019, 08:54:13 AM by sjsimmo »
« Reply #7 on: March 12, 2019, 07:00:08 AM »
I think I must write a getting started in the next days^^
The software side of the UD3 is a nearly complete rewrite, the spec sheet from steve is obsolete.
1. Compile
2. Flash
3. Connect micro USB
4. Open putty with the new USB COM-port
5. type help for a list of commands or get for list of parameters
6. set the start freq with "set start_freq 65.6" (in kHz)
7. Configure the CT (windings, OCD, Shunt resistor)
8. save everything with "eeprom save"
9. connect a midi player to the USB Midi port
10. play a midi and type in the pulsewidth "pw 50" (µs)
Online Laci
« Reply #8 on: March 13, 2019, 04:51:18 PM »
1. Compile
2. Flash
Could you tell me the settings in putty?I get infinite cycle putting out random characters on serial.
« Reply #9 on: March 13, 2019, 05:11:05 PM »
The settings are not relevant. You can use any baudrate, it is ignored and the communication is at max USB speed.
Make sure you are not connected to the KitProg COM-Port of the Debugger. It only works over the Micro USB at the right side.
Have you checked out the latest version in the git (Mar 11, 2019)?
If you are connected and type "cls" then you should see:
If you type "get" you should see:
https://github.com/Netzpfuscher/UD3/wiki/Commands
« Last Edit: March 13, 2019, 05:17:32 PM by Netzpfuscher »
Online Laci
« Reply #10 on: March 13, 2019, 05:22:42 PM »
Thank you,it works!I tried previously to connect it via micro usb,but didn't see the COM changing.  ::)
I'm going to test the driver in a few days and try to include the bluetooth module in your design,so probably some questions incoming. :)
« Reply #11 on: March 13, 2019, 05:33:22 PM »
If it is a Bluetooth to Serial module (Warning the psoc puts out 5V at the UART not 3,3V) you can connect it without modifications.
TX from Bluetooth to Pin 3.4 of the Psoc
RX from Bluetooth to Pin 3.0 of the Psoc
In the configuration set min_enable to 0.
If the Bluetooth Module not supports 2Mbit on Serial, you must change the baudrate in psoc creator.
Change the clock to internal
Set the Baudrate
Delete the clock connection
The schematic for the external circuit. The minimum you need is the CT circuit and the two gatedrives. The Pinout in the Schematic is for the TQFP Version it is not compatible with the dev Kit. Use the pinout from psoc creator!
* Schematic.pdf
« Last Edit: March 13, 2019, 05:40:14 PM by Netzpfuscher »
Online Laci
« Reply #12 on: March 17, 2019, 01:54:47 PM »
Thanks to your detailed instructions I managed to make your UD3 bluetooth controlled via a bluetooth - serial android app.The next thing I'd like to do is to make it interrupted from the same bluetooth module.Is this possible?I plan to make an app which can change the settings and work as an interrupter.So far I couldn't connect to my fake HM-10 BLE4.0 module from any simple app I made...
« Reply #13 on: March 17, 2019, 04:08:33 PM »
You can use the internal interrupter of the UD3.
"tr start" or "tr stop" start the classic interrupter
"pw xxx" or "pwd xxx" for the on and offtime
"bon xxx" or "boff xxx" for the burst mode
if you want MIDI just send the MIDI notes over the same serial connection.
Or you can use TeslaTerm. It is still in heavy development, but it works.
https://github.com/Netzpfuscher/Teslaterm
to start it install nw.js (https://nwjs.io/) and make a shortcut like this: "C:\nwjs\nw.exe c:\git\teslaterm"
Online Laci
« Reply #14 on: March 24, 2019, 02:59:48 PM »
So I made a basic UD3 controller application which sends commands over bluetooth low energy to a target UD3 device.While testing I connected the BLE module to an arduino nano and used the serial monitor of arduino IDE and everything worked.After connecting the module to the PSoC dev.kit the received data isn't what I wanted.When the app sends a command ex. get offtime the received data isn't something like offtime=2.Instead,I receive the same commands that were sent four times,then it glitches and receives the same command until the dev.kit gets restarted.Is this how it's supposed to work and the settings can only be modified over PC connection and only the interrupter works this way?
« Reply #15 on: March 24, 2019, 09:54:54 PM »
I don't really understand the problem.
Have you terminated the command with a CR LF?
The UD3 has a Terminal like SSH. It echoes every char back, autocompletion with tab,...
You can take a look in the UD3 Terminal "Teslaterm" how everything works. There is also a binary mode for the settings and the telemetry.
The offtime parameter is not the normal offtime. It is the minimal offtime between two midi note pulses. Polyphonic notes are not simply mixed with a or.
You can change every parameter or configuration over the terminal. It doesn't matter over which connection.
« Last Edit: March 24, 2019, 10:07:13 PM by Netzpfuscher »
Online Laci
« Reply #16 on: March 24, 2019, 10:43:55 PM »
My problem is this:when I press a configuration button from the list in the app,it sends its name to the UD3 in form of a command(ex.when I press the offtime button it sends the get offtime command).After pressing the button the app waits for a serial response from the UD3.The received data should be the value of the required configuration and it gets monitored in a text box(2nd picture,to the left of the SET button).However this data isn't what it's supposed to be,on the 2nd picture you can see that it's "get offtime" not the value of the offtime.It should be something like "offtime=2".
What is CR LF?Not terminating the command like you said might explain why the commands aren't getting registered and I get incorrect response.
Another question:can I test the UD3 with a function generator?If yes the only thing I should do is connect the FG(how?),start the interrupter with tr start,set pw and pwd and scope the GD outputs?
« Last Edit: March 24, 2019, 10:45:35 PM by Laci »
« Reply #17 on: March 24, 2019, 11:02:51 PM »
CR LF is what you get, if you press enter. Without enter the command is not processed. That you get the same back what you send is because of the echo, without that the user will not see what he is typing.
If you send a string like "get offtime\r" you should get a response. But this response should be like "get offtime\r\nofftime=2" because auf the echo. (\r is carriage return and \n is line feed)
I haven't yet connected a function generator directly to the dev board, the signal is differential. I must take a look at the schematic to give you a proper answer.
Edit:
With the command "config_get" you can dump the complete configuration to the terminal. I've documented the protocol here: https://github.com/Netzpfuscher/UD3/wiki/Telemetry-protocol
After you send "config_get" you get a bunch of telegrams:
1 byte start: 0xFF
1 byte length
1 byte type: TT_CONFIG_GET
x bytes help text
1 byte: ';'
x bytes values (all values as string): [param name];[value];[type];[size];[min];[max]
and after the last config telegram you get:
1 byte start: 0xFF
1 byte length
x bytes: "NULL;NULL"
« Last Edit: March 25, 2019, 07:53:42 AM by Netzpfuscher »
Online Laci
Re: DRSSTC Driver Logic (UD3 Bluetooth Controller Application)
« Reply #18 on: April 03, 2019, 10:58:29 PM »
I completed my UD3 BLE(Bluetooth Low Energy)Controller Application.The only reason to use a low energy module was that I had one available.
The application can modify the configuration and parameters of the UD3 and work as an interrupter via serial commands.It is good to make small modifications in the settings,but does not contain all of the UD3 features!
The app is not tested with a working Tesla coil yet.See attachments for screenshots about the app.
If anyone is more interested in the app,feel free to send me a message or reply in this topic.
Thanks Netzpfuscher for all the help and the UD3!
The used Bluetooth 4.0 BLE Module:
« Last Edit: April 03, 2019, 11:17:07 PM by Laci »
Online Laci
« Reply #19 on: April 04, 2019, 09:01:55 PM »
While building the hardware I found some new questions:
-Feedback and OC comes from the same CT?
-Can I swap around the pins in PSoC without ruining other stuff,like swap GD1A and GD2A with Relay1 and Relay2 to have all of the GD outputs next to eachother?
About extending the app:is the transpose command used to send a midi notes or something else?If yes,what do the values exactly mean?
post Re: New DRSSTC broken - Help
MEROVINGO85
Today at 11:35:29 AM
Laci
Today at 09:41:43 AM
post Let's study DRSSTC, how does it work by running ORCAD simulation
VNTC
Today at 06:09:00 AM
post Re: Strange GDT signals (need to help)
VNTC
Today at 03:39:48 AM
MEROVINGO85
Today at 01:19:22 AM
[Electronic circuits]
hightemp1
May 23, 2019, 11:20:08 PM
badpeter
May 23, 2019, 09:54:18 PM
May 23, 2019, 09:19:34 PM
May 23, 2019, 09:01:24 PM
post New DRSSTC broken - Help
MEROVINGO85
May 23, 2019, 08:18:56 PM
May 23, 2019, 05:36:38 PM
hightemp1
May 23, 2019, 04:56:10 PM
Phoenix
May 23, 2019, 11:55:27 AM
hightemp1
May 23, 2019, 05:51:09 AM
May 23, 2019, 04:07:17 AM
post Strange GDT signals (need to help)
VNTC
May 23, 2019, 02:19:24 AM
post Re: Easy access to optimal resonance frequency but the benefit is quite small
VNTC
May 23, 2019, 02:00:48 AM
post Re: Strange gdt waveforms
VNTC
May 23, 2019, 01:33:56 AM
May 22, 2019, 08:31:55 PM
May 22, 2019, 08:31:51 PM
post Easy access to optimal resonance frequency but the benefit is quite small
VNTC
May 21, 2019, 11:35:57 PM
post Re: Offgrid 48V solar to 24V battery setup
May 21, 2019, 09:59:54 PM
post Re: General Oscilloscope Probing Techniques for (DR)SSTC h-bridge
May 21, 2019, 09:51:27 PM
post Re: ZVS Mazzilli circ with active gate driver - what causes ringing?
May 21, 2019, 09:49:03 PM
82026
May 21, 2019, 09:02:10 PM
Vaclav
May 21, 2019, 08:59:57 PM
May 21, 2019, 08:28:43 PM
post Re: Identification of unknown embedded computer, help needed.
May 21, 2019, 08:22:28 PM
Vaclav
May 21, 2019, 06:21:37 PM
May 21, 2019, 06:12:55 PM
May 21, 2019, 04:06:38 PM
Vaclav
May 21, 2019, 03:56:56 PM
Vaclav
May 21, 2019, 03:46:56 PM
May 21, 2019, 02:32:59 PM
May 21, 2019, 06:12:18 AM
May 20, 2019, 11:30:34 PM
post DRSSTC design questions + project progress
Vaclav
May 20, 2019, 06:38:54 PM
May 20, 2019, 06:33:49 PM
82026
May 20, 2019, 02:27:59 PM
hightemp1
May 20, 2019, 02:57:46 AM
May 20, 2019, 01:06:27 AM
82026
May 19, 2019, 09:14:59 PM
May 19, 2019, 06:40:41 PM
flyrod
May 19, 2019, 04:04:12 PM
May 19, 2019, 11:24:46 AM
flyrod
May 19, 2019, 03:22:54 AM
post Re: Are bleeder resistors necessary if I can easily discharge my capacitor?
[Spark gap Tesla coils]
May 19, 2019, 03:18:52 AM
May 18, 2019, 10:48:59 PM
post Re: Is one of these good?
Golddustpeak
May 18, 2019, 04:19:11 PM
May 17, 2019, 10:57:17 PM
