Author Topic: Primary-Strike Protection Grounding Scheme - Insanity?  (Read 889 times)
Offline nabzim
  • My full name is Adam Baltazar Mizban. Hello there!
    • My YouTube Channel
« on: February 18, 2019, 05:06:18 AM »
OK. So we are all familiar with the standard method of primary-strike protection, that is, connecting the RF-ground to the negative DC Bus via capacitive-coupling...
I have come to the realization, that this does NOT make sense.
If a streamer strikes your primary coil, the streamer-current must travel through one/both of your low-side IGBT's (full bridge), or through your low-side IGBT and/or Bus Capacitor (half bridge) to get from the Primary coil to the -Vbus rail.
Why is it not instead the standard to capacitively-couple the RF-ground directly to the Primary Coil? (a.k.a. the center-point, between high-side and low-side IGBT's)
This would keep the high-energy current from traveling through the semiconductor.
Are my assumptions here correct? If there is any logical reasoning behind the standard grounding-scheme (other than copying Steve Ward), then can someone please educate me? ???
Re: Primary-Strike Protection Grounding Scheme - Insanity?
« Reply #1 on: February 18, 2019, 08:44:19 AM »
Coupling the non-MMC end of the primary would put a significant load on the bridge - take a look at the impedance of the typical coupling caps (e.g. 0.1uF) at the switching frequency. I suspect it would also cause EMI and safety issues, as any current through this capacitor would have to flow via the mains wiring to wherever the earth-neutral bond point is.
Given that the issue doesn't seem to be the strike current (on the order of a few amps only) flowing through the igbts (which have anti parallel diodes included to provide a path when off) but was more about voltage stress between the bridge and heatsink (ground) when hit, the standard method seems to do the trick.
« Reply #2 on: February 18, 2019, 09:25:24 PM »
adding beafy varistors from the primary to ground should increase robustness and a decent strike rail to ground is common practice hear
Offline nabzim
« Reply #3 on: March 06, 2019, 08:33:48 AM »
Thank you. I'm most likely going with the negative rail.
Offline nabzim
« Reply #4 on: March 06, 2019, 08:47:41 AM »
MOV's in addition to the capacitor? and in parallel, I'm assuming?
Grounded strike rail is a certainty! It sure comes in handy on my spark-gap coil: youtu.be/3d4ZDvA5Kcc
Today at 04:15:12 AM
Today at 01:05:28 AM
Today at 12:53:15 AM
April 07, 2020, 10:54:57 PM
April 07, 2020, 10:24:16 PM
April 07, 2020, 09:22:16 PM
April 07, 2020, 09:04:34 PM
April 07, 2020, 08:48:01 PM
April 07, 2020, 08:15:43 PM
April 07, 2020, 06:23:47 PM
April 07, 2020, 05:59:09 PM
April 07, 2020, 04:30:26 PM
April 07, 2020, 01:10:30 PM
April 07, 2020, 12:44:56 PM
April 07, 2020, 07:05:30 AM
April 07, 2020, 06:40:02 AM
April 07, 2020, 05:07:31 AM
April 07, 2020, 03:38:12 AM
April 07, 2020, 03:21:55 AM
April 07, 2020, 02:59:28 AM
April 07, 2020, 02:52:19 AM
April 07, 2020, 02:29:21 AM
April 07, 2020, 02:21:55 AM
April 07, 2020, 02:00:26 AM
April 07, 2020, 01:25:47 AM
April 07, 2020, 12:38:59 AM
April 07, 2020, 12:13:11 AM
April 06, 2020, 10:07:59 PM
April 06, 2020, 10:07:11 PM
April 06, 2020, 09:57:29 PM
April 06, 2020, 08:04:52 PM
April 06, 2020, 07:49:30 PM
April 06, 2020, 06:30:24 PM
April 06, 2020, 06:23:27 PM
April 06, 2020, 02:10:18 PM
April 06, 2020, 10:21:47 AM
April 06, 2020, 09:56:07 AM
April 06, 2020, 05:09:29 AM
April 06, 2020, 02:26:28 AM
post Re: Skm100 coil
April 06, 2020, 02:16:56 AM
April 06, 2020, 12:43:50 AM
April 05, 2020, 10:47:07 PM
April 05, 2020, 10:46:48 PM
April 05, 2020, 10:09:40 PM
April 05, 2020, 09:55:33 PM
April 05, 2020, 06:53:57 PM
April 05, 2020, 06:18:50 PM
prabhatkumar
April 05, 2020, 05:20:57 PM
April 05, 2020, 08:20:08 AM
April 05, 2020, 07:49:27 AM
