Author Topic: Primary-Strike Protection Grounding Scheme - Insanity?  (Read 799 times)
Offline nabzim
    • My YouTube Channel
« on: February 18, 2019, 05:06:18 AM »
OK. So we are all familiar with the standard method of primary-strike protection, that is, connecting the RF-ground to the negative DC Bus via capacitive-coupling...
I have come to the realization, that this does NOT make sense.
If a streamer strikes your primary coil, the streamer-current must travel through one/both of your low-side IGBT's (full bridge), or through your low-side IGBT and/or Bus Capacitor (half bridge) to get from the Primary coil to the -Vbus rail.
Why is it not instead the standard to capacitively-couple the RF-ground directly to the Primary Coil? (a.k.a. the center-point, between high-side and low-side IGBT's)
This would keep the high-energy current from traveling through the semiconductor.
Are my assumptions here correct? If there is any logical reasoning behind the standard grounding-scheme (other than copying Steve Ward), then can someone please educate me? ???
Re: Primary-Strike Protection Grounding Scheme - Insanity?
« Reply #1 on: February 18, 2019, 08:44:19 AM »
Coupling the non-MMC end of the primary would put a significant load on the bridge - take a look at the impedance of the typical coupling caps (e.g. 0.1uF) at the switching frequency. I suspect it would also cause EMI and safety issues, as any current through this capacitor would have to flow via the mains wiring to wherever the earth-neutral bond point is.
Given that the issue doesn't seem to be the strike current (on the order of a few amps only) flowing through the igbts (which have anti parallel diodes included to provide a path when off) but was more about voltage stress between the bridge and heatsink (ground) when hit, the standard method seems to do the trick.
« Reply #2 on: February 18, 2019, 09:25:24 PM »
adding beafy varistors from the primary to ground should increase robustness and a decent strike rail to ground is common practice hear
Offline nabzim
« Reply #3 on: March 06, 2019, 08:33:48 AM »
Thank you. I'm most likely going with the negative rail.
Offline nabzim
« Reply #4 on: March 06, 2019, 08:47:41 AM »
MOV's in addition to the capacitor? and in parallel, I'm assuming?
Grounded strike rail is a certainty! It sure comes in handy on my spark-gap coil: youtu.be/3d4ZDvA5Kcc
Today at 07:22:17 AM
Today at 06:15:28 AM
Today at 05:27:56 AM
Today at 05:15:44 AM
Today at 03:27:07 AM
warmania
warmania
post Re: FPS4000
post Re: NST
post FPS4000
Hoser415
spacecabbie
