Author Topic: How do I test the max. Ipk of IBGT  (Read 293 times)
Offline VNTC
« on: February 16, 2019, 05:03:21 AM »
After make a test Ipk of IBGT 60N60 by the common driver used UCC27321+UCC27322 with Transformer-Coupled gate drive. The coupling capacitor caused the ripple at the beginning and at the end of the burn pulses. I am so sorry about this, i was wrong here i just saw the fact of the matter is the energy in the secondary of the GDT and tthe input capaciance of the IBGT build this rear ripple not because the coupling capacitor that cause the front ripple. A trouble occur like this: for example the interrupt give 1 pulse of 100Khz to switching on the transistor in 5us but it has 1 more pulse 25us long after. (Figure 1 load hundred Ω )And more serious, this pulse is the result of a control signal <10v approx.(Figure 2,Vce) So the transistor turn on at the linear operation, this matter can causes the transistor failure with low load resistor. We can say this way cannot used to test max. Ipk of the transistor.
So I used the Bipolar Totem-Pole Driver circuit as in the schematic in figure3 with 1 pair of Tip 2N122+Tip127. I see this circuit is very strong driver x2 or x3 time than UCC27322 ?the square wave drive signal change the shape very little by the load. And also by this circuit we can adjust the amplitude and frequency of the drive signal.
Load reistor .3Ω made by 2 carbon cores of the AAA zinc battery in serial and dipped them in water.
The drive signals is: 4usx100signals/s.
I used the low price 60N60 China product it has the input capacitance too high > 25nf and the test gives some result:
*At 200A ; Vce(sat)=2V approx.( fig.3)
*Then I adjust the amplitude of the gate drive signal drop to 20V signal Vce(sat) look-like no change. Is it means the internal inductance of S pin no effect on the gate drive signal?? So may we use zener clamping diode 25V at the gate is enough instead of 33V??. How guys think?
I think in DRSSTC, transistor work as soft switching because it switches near the zero cross and the current wave is sinusoidal.
10 pieces 1F35AHFGH60N60SFD come ,these foots so thin. But Vce(sat) bretty good 2V at 200A ( brobe must be hooked directly on the foots of transistor to get correct signals )
these are Chinese's low prices products 1USD/1piece for uesing in welding machine should be good.
But in DRSSTC, let i see how much max Ipk they can run later.
« Last Edit: April 24, 2019, 04:03:27 AM by VNTC »
Re: How do I test the max. Ipk of IBGT
« Reply #1 on: February 16, 2019, 12:47:45 PM »
How was the heat dissipation during these tests?
You should really build a LC resonant load instead of a pure resistive, this would give you a more precise picture of how it will do as soft switching, as you also mention. Those Vce(sat) values and current should have made those poor IGBTs burn, but you only tested single pulses?
Just two days ago I blew up my DRSSTC1 full-bridge of 60N60, I will post about that when I got time, right now im just busy getting it to run again before I need it functional here on the 25th Feb.
Offline VNTC
« Reply #2 on: February 17, 2019, 03:16:00 AM »
Mr Mads Barnob,
In this test resistor .3 Ωmade by 2 carbon core of the AAA battery in serial and embedded in water. Power consumption for 100x single pulse/s 600A/200VDC is about 100w.
500A/170VDC 100x10 pulses/s  300w
Yes, You say exactly I intend to do so, i will test L1C1(without L2C2) at resonance when components that  i order arrive.
Offline VNTC
« Reply #3 on: February 19, 2019, 04:54:44 AM »
In every interrupt, long or short time always has the front ripple and the rear ripple.
The front ripples cause by the coupling capacitor and the primary inductance of the GDT. The rear ripples cause by the input capacitor of IGBT and the secondary inductance of the GDT. At that moment they make the signals become bad even very bad. I hate them and try to remove them but so hard!
When used direct coupling without GDT this matter will not present.
post Re: New DRSSTC broken - Help
MEROVINGO85
Today at 11:35:29 AM
Laci
Today at 09:41:43 AM
post Let's study DRSSTC, how does it work by running ORCAD simulation
VNTC
Today at 06:09:00 AM
post Re: Strange GDT signals (need to help)
VNTC
Today at 03:39:48 AM
MEROVINGO85
Today at 01:19:22 AM
[Electronic circuits]
hightemp1
May 23, 2019, 11:20:08 PM
badpeter
May 23, 2019, 09:54:18 PM
May 23, 2019, 09:19:34 PM
May 23, 2019, 09:01:24 PM
post New DRSSTC broken - Help
MEROVINGO85
May 23, 2019, 08:18:56 PM
May 23, 2019, 05:36:38 PM
hightemp1
May 23, 2019, 04:56:10 PM
Phoenix
May 23, 2019, 11:55:27 AM
hightemp1
May 23, 2019, 05:51:09 AM
May 23, 2019, 04:07:17 AM
post Strange GDT signals (need to help)
VNTC
May 23, 2019, 02:19:24 AM
post Re: Easy access to optimal resonance frequency but the benefit is quite small
VNTC
May 23, 2019, 02:00:48 AM
post Re: Strange gdt waveforms
VNTC
May 23, 2019, 01:33:56 AM
May 22, 2019, 08:31:55 PM
May 22, 2019, 08:31:51 PM
post Easy access to optimal resonance frequency but the benefit is quite small
VNTC
May 21, 2019, 11:35:57 PM
post Re: Offgrid 48V solar to 24V battery setup
May 21, 2019, 09:59:54 PM
post Re: General Oscilloscope Probing Techniques for (DR)SSTC h-bridge
May 21, 2019, 09:51:27 PM
post Re: ZVS Mazzilli circ with active gate driver - what causes ringing?
May 21, 2019, 09:49:03 PM
82026
May 21, 2019, 09:02:10 PM
Vaclav
May 21, 2019, 08:59:57 PM
May 21, 2019, 08:28:43 PM
post Re: Identification of unknown embedded computer, help needed.
May 21, 2019, 08:22:28 PM
Vaclav
May 21, 2019, 06:21:37 PM
May 21, 2019, 06:12:55 PM
May 21, 2019, 04:06:38 PM
Vaclav
May 21, 2019, 03:56:56 PM
Vaclav
May 21, 2019, 03:46:56 PM
May 21, 2019, 02:32:59 PM
May 21, 2019, 06:12:18 AM
May 20, 2019, 11:30:34 PM
post DRSSTC design questions + project progress
Vaclav
May 20, 2019, 06:38:54 PM
May 20, 2019, 06:33:49 PM
82026
May 20, 2019, 02:27:59 PM
hightemp1
May 20, 2019, 02:57:46 AM
May 20, 2019, 01:06:27 AM
82026
May 19, 2019, 09:14:59 PM
May 19, 2019, 06:40:41 PM
flyrod
May 19, 2019, 04:04:12 PM
May 19, 2019, 11:24:46 AM
flyrod
May 19, 2019, 03:22:54 AM
post Re: Are bleeder resistors necessary if I can easily discharge my capacitor?
[Spark gap Tesla coils]
May 19, 2019, 03:18:52 AM
May 18, 2019, 10:48:59 PM
post Re: Is one of these good?
Golddustpeak
May 18, 2019, 04:19:11 PM
May 17, 2019, 10:57:17 PM
