Author Topic: Resistor tolerance?  (Read 89 times)
Offline kamelryttarn
Resistor tolerance?
« on: February 10, 2019, 05:46:39 PM »
I would like to user fixed resistors as calibration for a couple of Pt100 and Pt1000-to-4-20mA current loop converters and I was wondering if a fixed resistor (metal film or wire wound) with extremely low temperature coefficient changes value or if it can be considered stable?
For example, if I order a 0.1% resistor specified as 100 Ohm, the actual resistance may vary between 99,9 and 100,1 which isn't much but when translated to degrees Celsius it's roughly -0,2 to +0,2.
My question is: Apart from temperature drift, will a fixed resistor shift in resistance value or can I use a low ppm fixed resistor of any value and type and attach a small note to each stating the corresponding temperature once I have been able to accurately determine that?
Re: Resistor tolerance?
« Reply #1 on: February 14, 2019, 02:27:18 PM »
I made this spread sheet to try and visualize what impact the resistor tolerance has when using them as calibration points
https://docs.google.com/spreadsheets/d/1Cs-OpPVZ9Inlz1PG1GYzi1S5flYNSTyw2RnShtDgI1U/edit?usp=sharing
Rights are only granted for viewing for now
post Re: Bleed R's for MMC caps ?
pentode
Today at 08:36:58 AM
L_Mangold
Today at 02:40:13 AM
post Re: Kaizer DRSSTC1 bridge failure and repair, caught on video.
dexter
February 22, 2019, 07:47:34 PM
February 22, 2019, 06:10:35 PM
February 22, 2019, 04:34:54 PM
February 22, 2019, 04:34:14 PM
post Kaizer DRSSTC1 bridge failure and repair, caught on video.
February 22, 2019, 02:59:46 PM
pentode
February 22, 2019, 12:20:26 PM
February 22, 2019, 10:07:23 AM
pentode
February 22, 2019, 08:28:17 AM
post Re: TL494 Flyback driver oscillator section
setkiki
February 22, 2019, 04:28:24 AM
bogdan
February 21, 2019, 06:41:27 PM
February 21, 2019, 06:06:46 PM
February 21, 2019, 03:15:47 PM
post Bleed R's for MMC caps ?
pentode
February 21, 2019, 02:54:39 PM
February 21, 2019, 09:37:55 AM
post Re: 160mm PLL sstc
February 21, 2019, 04:44:03 AM
post Re: My X-Ray Machine
Agent Smith
February 20, 2019, 11:10:28 PM
February 20, 2019, 06:45:41 PM
bogdan
February 20, 2019, 03:20:24 PM
February 20, 2019, 10:02:24 AM
February 20, 2019, 08:42:24 AM
February 19, 2019, 08:48:51 AM
VNTC
February 19, 2019, 04:54:44 AM
nabzim
[Light, lasers and optics]
VNTC
VNTC
Thunderstruck
black.yang
post Re: Resistor tolerance?
TonyHV
TonyHV
black.yang
black.yang
pentode
TonyHV
TonyHV
