Author Topic: SGTC secondary used in SSTC mode?  (Read 629 times)
Offline Platinum
« on: January 24, 2019, 05:29:44 PM »
Hello HVF, recently I made a secondary coil using 110mmOD drain pipe, 0.24mm wire with about 1200 turns, height diameter ratio is about 1-4 as I originally intended to use it as a medium sized SGTC of around 3kw. Now I'd like to use it in solid state mode and was wondering if I could use it at all and would I run into any problems?
Also as a additional question is there any decent full bridge driver I could buy as I'm struggling for time to build one as I have a newborn daughter
Thanks in advance
Re: SGTC secondary used in SSTC mode?
« Reply #1 on: January 24, 2019, 05:43:25 PM »
Sounds like a reasonable secondary for a (DR)SSTC - you'll want to use reasonable fast IGBTs as it I estimate will resonate around 200-250kHz with a sensible size topload, but good TO-247 IGBTs should handle it OK (try FGY75N60SMD/FGA60N65SMD/FGH60N60SMD). There are some designs in this forum which could get you started with a full bridge PCB (order from a cheap chinese PCB house), and for a driver you could again use a design found here or get something off ebay/aliexpress (again, check the forum for reviews and options).
As you didn't mention having a toroid already, as an option I am happily using one of these with a secondary of the same 110mm diameter: https://www.ebay.co.uk/itm/Spun-Aluminium-Toroid-for-Tesla-Coil-HV-High-Voltage-300mm-by-75mm/113538948995
For that price it's not worth trying to DIY one! (Note comes in 2 halves, to hold it together either use the mounting bolt or roughen up the flat area on the inside and epoxy together).
Offline Platinum
« Reply #2 on: January 24, 2019, 08:24:49 PM »
Hi Hydron, thank you for the detailed and helpful reply, if I remember from JavaTC inputs the Fres was about 234khz, I have some spare 60H60 trench gate field stop IGBTs leftover from another full bridge build I done which is used to power a homemade flyback, I have had a look at the Chinese drivers but I am struggling to come to conclusion which one would be most appropriate as all the descriptions are meaningless to me, if I post a few could you help me make a decision?
As for the toroid, luckily I work in engineering and could have one made to spec for free, thanks for the heads up though.
Thank you 👍
Today at 08:09:29 PM
Today at 02:53:24 PM
Today at 11:46:07 AM
Today at 11:40:55 AM
Today at 11:32:19 AM
Today at 03:48:55 AM
April 01, 2020, 09:47:42 PM
April 01, 2020, 09:31:49 PM
April 01, 2020, 08:47:11 PM
[Static Electricity]
April 01, 2020, 08:45:14 PM
April 01, 2020, 08:37:29 PM
April 01, 2020, 08:24:06 PM
post Re: Pt100 oddities
April 01, 2020, 08:16:59 PM
April 01, 2020, 07:50:16 PM
April 01, 2020, 07:42:47 PM
April 01, 2020, 07:39:48 PM
April 01, 2020, 06:07:44 PM
[DSLR]
April 01, 2020, 05:17:04 PM
April 01, 2020, 02:01:30 PM
April 01, 2020, 01:38:47 PM
April 01, 2020, 12:49:21 PM
April 01, 2020, 10:29:06 AM
post Pt100 oddities
April 01, 2020, 09:48:37 AM
April 01, 2020, 07:01:51 AM
April 01, 2020, 04:15:41 AM
April 01, 2020, 04:05:20 AM
April 01, 2020, 01:51:05 AM
April 01, 2020, 01:32:54 AM
March 31, 2020, 11:03:36 PM
March 31, 2020, 10:13:13 PM
post Class E SSTC Topology
March 31, 2020, 09:15:23 PM
March 31, 2020, 12:05:40 PM
March 31, 2020, 08:54:35 AM
March 31, 2020, 04:58:16 AM
March 31, 2020, 04:44:05 AM
March 31, 2020, 01:33:16 AM
March 31, 2020, 12:48:56 AM
March 30, 2020, 08:08:54 PM
March 30, 2020, 07:20:08 PM
March 30, 2020, 06:46:02 PM
March 30, 2020, 06:35:13 PM
March 30, 2020, 05:00:11 PM
March 30, 2020, 04:30:55 PM
March 30, 2020, 01:16:47 PM
Acid Byte
March 30, 2020, 07:23:21 AM
March 30, 2020, 06:13:52 AM
March 30, 2020, 05:31:27 AM
March 30, 2020, 02:55:41 AM
March 30, 2020, 02:23:23 AM
post Re: Skm100 coil
March 30, 2020, 02:22:33 AM
